Valve size in inches for DN 40 with 44.8 mm internal thread diameter?
balonika3 86295 13
What inch size corresponds to a DN 40 valve with an internal thread diameter of about 44.8 mm?
A DN 40 valve corresponds to 1 1/2 inch, and the inch marking is a nominal pipe/thread standard rather than the exact measured inner diameter [#11055819][#11056151] A 1 1/2 inch pipe/thread is around 38.1 mm nominal, while the threaded outside diameter is about 48.5 mm, so a measured 44.8 mm internal thread diameter is still in that size range [#11056151] Pipe sizes do not match the actual bore exactly because wall thickness varies and the standard uses fixed Whitworth tube thread dimensions [#11056151][#11056719] That is why a 1/2 inch pipe can have an inside diameter around 16 mm instead of 12.5 mm [#11056719][#11061326]
  • #1 11055761
    balonika3
    Help: 1336
    Rate: 3759
    Hello. As I am not an eagle from the inch nomenclature, I ask the question - what is the size of this valve? The internal diameter of the thread is approx. 44.8. How many inches are "hydraulic"?
    There is also DN 40 on the other side of the valve.
  • #2 11055819
    mariuszspa
    Help: 32
    Rate: 78
    1.1 / 2 inch. DN 40 is the diameter of the valve ball bore.
  • #3 11055914
    balonika3
    Help: 1336
    Rate: 3759
    Thank you. But how do the inch and a half to the diameter of the "hole" in the valve? I'm not questioning the answer - I just don't get it. There is, for example, a 1/2 inch pipe that has much more inside than the 12.5mm. What's going on?
  • #4 11055969
    karolark
    Help: 702
    Rate: 2516
    I also can't keep up with the plumbers for them 32 mm is an inch :D
  • #5 11055976
    balonika3
    Help: 1336
    Rate: 3759
    It works out because, as I remember, a half-inch tube has just 16mm inside.
  • #6 11055993
    mariuszspa
    Help: 32
    Rate: 78
    The pipe thread size in inches is the lumen diameter of the pipe. With a thin-walled pipe, there is a difference between what should be and what is.
  • #7 11056039
    balonika3
    Help: 1336
    Rate: 3759
    Well, but what has "thin-walled" or "thick-walled" to the diameter of the light itself? Besides, in my valve, the hole in the ball is about 35mm, so it has nothing to do with the 1 1/2 inch. I'm still not questioning knowledge, just trying to make sense of it.
  • #8 11056151
    mariuszspa
    Help: 32
    Rate: 78
    1.1 / 2 inch is 38.1mm, pipe and 1.1 / 2 "thread has a diameter of 48.5 (approx.). Plumbing pipes have a wall thickness of about 2.5mm to 5.5mm. The rest is easy to understand, thread has a constant dimension according to the standard, it is a cylindrical Whitworth TUBE thread, it can also be tapered.
  • #9 11056300
    balonika3
    Help: 1336
    Rate: 3759
    Thanks. But why is a 1/2 "pipe about 16mm inside?
  • #11 11061326
    saskia
    Help: 174
    Rate: 1086
    An inch is one of the measurement units and amounts to 25.4 mm and the "tubular inch" is not a unit of measure but a conventional and standard thread dimensions needed to connect individual pipe dimensions, which are still given in inches, and the designation inch is "by number, often with a fraction e.g. 1 1/2 ", 2" 1/2 "
    the 16 mm in the 1/2 "pipe, I mean it," the roughness allowance inside the pipe and, to some extent, the dependence between the individual pipe sizes.
    I have to add that the pitch of the pipe threads is also in inches, i.e. it specifies the number of thread turns at 1 "and is marked e.g. 1" 12 TPI (threads per inch), although on pipes it is standard and the same diameters have the same thread pitch, worse with screws.
  • #12 11062873
    zimny8
    Help: 26
    Rate: 503
    The external dimensions of the pipes are and must be constant due to the threads, and now if the wall thickness of the pipe changes, the "light" of the pipe also changes.
    I remember that once these dimensions ext. pipes were closer to the "truth" or actual inch dimensions.
  • #13 11063954
    balonika3
    Help: 1336
    Rate: 3759
    Thank you, the topic is exhausted. You can close.
  • #14 17270073
    lordkaramba
    Rate: 22
    Google ---> Table of preliminary thread recognition
The discussion revolves around determining the valve size in inches based on the internal diameter of the thread, which is approximately 44.8 mm. Participants clarify that a DN 40 designation corresponds to a valve ball bore diameter. The conversation highlights the confusion surrounding the relationship between nominal pipe sizes and actual internal diameters, noting that a 1/2 inch pipe has an internal diameter of about 16 mm due to wall thickness. The standardization of pipe threads and the impact of wall thickness on the internal diameter are also discussed, emphasizing that the "tubular inch" is a conventional measurement rather than a direct unit of measure.
