Valve Replacement: Screw-On Butterfly to Ball Valve - Sizing, Measurements, and Identifying Marks
Slavko252 56031 8
  • #1 17047474
    Slavko252
    Rate: 14
    Hello. I need to replace the screw-on butterfly valve because it leaks, I note that it is without the so-called choke, i.e. nothing more can be done with it anymore. I want to replace it with a ball valve, ie with a red wajchą. The pipes are to be screwed into it, i.e. it has internal threads. My only problem is to determine the size.
    Is, for example, 1/2 inch the inner or outer diameter of the pipe? I need to unscrew the valve first to check it?
    How do you call plumbers, you just enter the room and you know what size it is?
    Do you have any way to measure it?
    Or maybe there are some markings on the valve itself, how many inches? Some valves have a number of 15 or 20.
    Immediately I say that it is not possible to unscrew the valve, go to the store with him and buy the same, it will be hard to do without water at home. Thanks in advance to the expert.
  • #3 17047522
    mychaj
    Help: 214
    Rate: 941
    They are often marked as 3/8, 1/2 or 3/4 (the most common sizes).
    Cal is 25.4 mm or the diameter of the thread (internal or external does not matter).
    And from this we have: 3/8 inch to 9.5mm (found as under-counter valves for washbasins)
    1/2 inch is 12.7 (valves for sinks, cisterns)
    3/4 inch is 19mm (main valves before and after counters).
    Drop in to the market / store and pick up 3 nipples or 3/8 1/2 3/4 muffs compare and catch what a camel. :-)
  • #4 17047583
  • #5 17047611
    mychaj
    Help: 214
    Rate: 941
    Cool luuuz - dude just wants to recognize the thread, do not write a doctorate. :-)
  • #6 17047660
    ls_77
    Help: 500
    Rate: 947
    Some valves are marked as: DN (nominal diameter), e.g.
    DN15 = 1/2 "
    DN20 = 3/4 "
    DN25 = 1 "
    or mark in inches.
    The "DN" marking is not to be confused with the nominal pressure, i.e. "PN" :idea:
    If there is no sign on the valve, it is best to measure "something" that is screwed into this valve: pipe, nipple - outside diameter. Go to the hydraulic store and explain where we measured the diameter. It should be remembered that the same thread marked in inches, eg 1/2 "measured inside the valve will be smaller in millimeters than the 1/2" thread measured with a measuring tape or a vernier caliper outside the pipe or nipple. :!:
    Measure the total length of the valve so that you can have enough space later.
  • #7 17047783
  • #8 17047881
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    As already written, this dimension in inches is the inner diameter of the pipe (approximately) and not the diameter of the thread. Valves always (or almost always) have a size designation, but they can be in inches or in millimeters. 15 is the size of 1/2 ", 20 is 3/4". You have to write down the name on the old valve.
  • #9 17048051
    Slavko252
    Rate: 14
    In this case, my valve is 1/2 inch, because it has a casting number of 15, the diameter of the pipe screwed into the valve is about 21-22mm, and its length is 6.1 cm. Thanks for help, gentlemen.
The discussion revolves around replacing a leaking screw-on butterfly valve with a ball valve. The main concern is determining the correct size for the new valve, specifically whether the 1/2 inch measurement refers to the inner or outer diameter of the pipe. Participants clarify that the nominal size typically refers to the inner diameter of the pipe, with common sizes being 3/8, 1/2, and 3/4 inches. They suggest checking for markings on the valve, such as DN (nominal diameter) designations, where DN15 corresponds to 1/2 inch and DN20 to 3/4 inch. If markings are absent, measuring the outer diameter of the pipe or nipple connected to the valve is recommended. The discussion also emphasizes the importance of measuring the total length of the valve for proper fitting.
