Makita GA 5030 Angle Grinder: Struggling to Unscrew Disc Nut & Broken Spindle Lock Button
lako60 49898 15
How can I unscrew the disc nut on a Makita GA 5030 angle grinder, and what should I do after breaking the spindle lock button?
Unscrew it counterclockwise with the proper wrench; if the nut is seized, clamp the grinder in a vice, warm the nut gently with an LPG burner, and try again [#15018179] If the spindle lock button/pin is broken, you will need to open the gearbox and remove the broken lock pin from inside; also check whether the lock seat in the gearbox body was damaged [#11058679][#15021709] The nut can become too tight if the disc was overloaded or clamped during cutting, so check the nut for burrs and the disc mounting for damage [#15021709][#15056855] When reassembling, mount the disc with the printed side up / aluminum washer toward the nut so it does not bite into the disc ring, and lightly lubricate the spindle threads each time you change a worn disc [#15028156][#15028225][#15018179]
  • #1 11058661
    lako60
    Hello! I have a makita GA 5030 angle grinder, it works great, but there was a problem with changing the disc. pressing the spindle lock button and trying to unscrew the disc nut I can't do it for any treasures. Not only that, I broke the spindle lock button. I locked the spindle with a wrench and it broke! How to unscrew this nut to change discs? What did I do wrong that this happened?? maybe it's best to go to the site only if it's worth it.
  • #2 11058679
    mipix
    Help: 495
    Rate: 1483
    I would turn it counterclockwise.
    There is nothing left now but to open the gearbox and remove the broken key from it.
    You might even have to break the shield to do it. 2 pipe clamps should help unscrew.
  • #3 11058689
    krys06
    Help: 97
    Rate: 190
    The nut should be tapped hard, definitely once, twice .... then after locking, unscrew ... remembering the direction (look at the twist of the thread on the screw)
  • #4 11058729
    lako60
    I unscrewed the broken pin lock and got rid of it from the inside. I replaced the spindle lock with the "Romet" bicycle wrench and turned it counterclockwise with the grinder wrench, but it didn't budge and the "Romet" wrench itself broke! maybe spray it with wd40, wait a few days and unscrew it?
  • #5 11060923
    iku18
    Level 19  
    Help: 31
    Rate: 111
    Waste of your time and nerves. use another grinder to cut the mounting plate at the thread itself so as not to damage the thread. The rest is easy to unscrew. Unfortunately, a throwable shield.
  • #6 11065871
    andy1978
    Rate: 66
    I do it this way. I clamp the grinder in a vice by the friction disc, then I hit the fastening nut with a hammer through the pin. Goes first/second time. But the shield is throwable. You can also insert a flat spanner, probably 22 or 24 between the shield and the head and use it as a counter.
  • #7 14642560
    Mellucci
    Rate: 57
    I have the same problem with my grinder, one time in a row.
    Is there any way to keep it from getting so tight?
    I do not tighten on the "stick shield" when it pulls it will stop, but I can never unscrew it.
    Maybe I would have to use something somewhere, e.g. a copper washer? Will anything help?
  • #8 14642685
    zbich70
    Help: 1171
    Rate: 6663
    Using grinders from Bosch, Makita, Metabo and other brands (even no-names) I never had problems with unscrewing the disc. Without any wrenches or hammers, just by hand.
    But I also saw many "magic" hammer and chisel in the opposite direction to the direction of unscrewing ... :D
    Or maybe the difficulty with unscrewing the shield is a signal not to "slaughter" the machine, not to squeeze the last forces out of it, not to tick the shields, not to overload until the smoke goes away...
    So what if you have more strength in your hands than this angle, if you drive it ...? Are you "big" because you're stronger than a grinder? Prove your strength in the gym.
    If properly used, the equipment will last for many years...
    But the condition - skillfully ...
  • #9 15018138
    jaktom3
    Recently, while cutting an angle iron, the disc on my angle grinder clamped and chipped. When trying to replace it, it turned out that it was impossible to unscrew the disk that holds the disc. After one of the attempts, the key bent, the attempt to unscrew it with a hydraulic wrench did not help, similarly turning the disk in a vice (after breaking what was left of the disk) and turning with an angle saw did not help either, of course, using a cutter inserted into the hole in the disk and pounding with a hammer. I tried all these methods also after flooding the thread and the disc contact with oil. Nothing helped. I found a video on the net in which someone using a second grinder cuts out the remains of the disc under the nut, and then unscrews it without any problems. Of course, the nut is suitable for knocking out. Due to the lack of a second grinder, I slightly modified the idea. I screwed the bow of the metal saw into the vice with the blade up, turned on the grinder and with the removed cover and the remnants of the disc under the nut, I ground the blade until it was completely worn out. When only the metal ring was left of the dial, the nut was unscrewed with the fingers. You must wear safety glasses or a mask.
  • #10 15018179
    hazet
    Help: 62
    Rate: 510
    I had a problem with the Makita GA9020 once when I used it with a diamond blade for stone and cut paving stones. You should absolutely not hit with a hammer and punch or chisel :not: We clamp the grinder in a vice. We heat up
    the nut with a burner, e.g. LPG - not too much. We unscrew normally with a key intended for this purpose. Always lightly lubricate the threads of the blade mounting bolt each time you change a worn blade. - there will be no problems with unscrewing later.
  • #11 15021709
    Sławek K
    Help: 44
    Rate: 232
    ... and see what is the reason for tightening the nut on the disc - perhaps there is a burr on the nut on the surface pressed to the disc.
    - the nut is replaceable and the method given by Andy 1978 is the best, and if it doesn't help, disassembly of the gear, which you have to dismantle anyway to pull out the damaged lock pin - maybe you broke the lock's seat in the gear body!!!!! Leftover crumbs can damage your gears!!!! This is your most serious problem, because unscrewing the dial is an ass!!!!
    Sławek
  • #12 15028156
    Furions
    Help: 9
    Rate: 110
    This happened to me with low-quality discs.. Secondly, we mount the disc with the inscriptions up, then the nut does not cut into the aluminum ring of the disc, which is only on one side.. 😀
  • #13 15028225
    Wodnik-W8
    Help: 17
    Rate: 45
    Hello. Colleagues, Screw the nut, i.e. the shield, with the aluminum washer on the shield upwards, i.e. to the nut. Then it won't be so tight.P.
  • #14 15056855
    jaktom3
    After what happened to me, I believe that the reason for tightening the nut on the blade may be a sudden entrapment of the blade during cutting, e.g. as a result of clamping by a cut piece of material that was not properly supported before starting work.
    I use good quality Saint-Gobain targets. All have a pressed-in steel ring.
  • #15 17182053
    jarulek
    My shield tightened and broke, after which the first time I had so much that I could not unscrew the nut. I did the method with grinding the saw blade, only I did it with the cover on. It worked :) I'm wondering if I should invest in a self-locking nut.
    There is also a video on YouTube "Secrets of the angle grinder. How to unscrew the nut and replace the disc"
  • #16 17182076
    Topolski Mirosław
    Moderator of Electrical engineering
    Help: 355
    Rate: 1620
    You can use paper washers under the shield and then there will be no problem with unscrewing - it is also important to put on the shield, which colleagues have already written about.
The discussion revolves around issues faced by users of the Makita GA 5030 angle grinder when attempting to unscrew the disc nut, particularly after breaking the spindle lock button. Users suggest various methods to resolve the problem, including using a hammer to tap the nut, clamping the grinder in a vice, and applying heat to the nut. Some recommend using lubricants like WD-40 to loosen the nut, while others advise against using excessive force that could damage the tool. The importance of proper installation techniques, such as using aluminum washers and ensuring the disc is mounted correctly, is emphasized to prevent future issues. Several users share their experiences with similar problems and suggest cutting the disc or nut if all else fails.
