[BHP] Angle Grinder Usage: Directing Sparks Away for Safety and Better Visibility
BANANvanDYK 66927 39
Should an angle grinder be held so the sparks fly away from the operator, and is that a safe way to cut?
You can hold an angle grinder so the sparks go away from you, but the thread says this only makes sense when the guard is positioned correctly and you keep both hands on the tool; the bigger hazard is kickback if the disc jams, which can throw the grinder or shield toward the operator [#14335573][#14347208][#14328188][#14333923][#14334971] Several replies say the photos/manuals are really about proper body position and guard placement, not about reversing the grinder’s rotation, and the workpiece should be secured so you stay out of the disc’s line of travel [#14343427][#14334971] A few users note that the “sparks forward” setup can be awkward on some grinders because of switch and handle placement, but they still report using it that way on larger tools [#14328100][#14340165][#14342161]
  • #1 14328046
    BANANvanDYK
    Help: 1167
    Rate: 2599
    By accident, I came across a newspaper article that instructed the use of an angle grinder in such a way that the direction of rotation of the disc would cause sparks to be thrown forward.
    Somehow I have never met someone from my friends to hold an angle grinder in such a way as if he was left-handed. Sparks always fly towards the person operating the tool. That's why it seems strange to me.
    I found two pages on the internet where this method is described:
    http://www.portalnarzedzi.pl/artykul/prawidlowe-ciecie-szlifierka-katowa
    Depending on how the grinder is held, the sparks will either fly at the operator (photo 2) or in the opposite direction, i.e. away from him (photo 1). The consequence of holding the grinder shown in photo 2 is poor visibility of the cutting line and a high risk of fire and fire, as well as a significant acceleration of wear of the work clothes. As you know, sparks, because they have a high temperature, destroy the fibers of the clothing fabric, and even in extreme cases may cause it to ignite. Therefore, such a position of the grinder during cutting is incorrect and dangerous for the operator.
    Picture 1 shows the correct holding of the grinder. It gives a good view of the cutting line and directs the sparks away from the operator. However, such directing the sparks does not protect us from starting a fire in the workshop. Therefore, it is necessary to separate from their destructive influence both the workshop employees and the objects in it. For this purpose, we should use a special non-flammable barrier, e.g. made of sheet metal.
    http://www.budujemydom.pl/narzedzia-ogrodnicze/11859-szlifierki-katów
    When working with an angle grinder, the direction of rotation should be such that the dust is directed forward and not towards the operator. Apart from damaging clothes or getting eyes, an improperly directed stream of dust is sucked in by the fan of the sander motor, which leads to faster damage.
    What do you say? For and against?
  • #2 14328100
    noel200
    Help: 36
    Rate: 815
    I have tried this several times. With my left hand, holding the grinder, I couldn't actually cut.
    Unless to change the direction of rotation in the grinder.
  • #3 14328188
    jaga134
    Help: 88
    Rate: 192
    Changing the direction of rotation in the grinder is not a problem. But ... I myself witnessed how an employee working with a grinder set up in this way, cutting a 1.5 inch pipe in a fence, received a blow to the head with such a grinder. Just a momentarily locked shield tossed the device upwards and caused an accident. If the disc was spinning in the right direction, the grinder would "jump" forward, but it would be easier to hold. In my opinion, I do not advise you to do such a modification.
  • #4 14328253
    heniek07
    Help: 29
    Rate: 221
    I support col. Jaga134. When sanding with a thick disc, you can direct the sparks slightly to the side, but when cutting to the front? It is asking for an accident , it is impossible to hold the grinder with a slight jam and it will go to the human. Motivation for sparks to enter the rotor? What is more important, health or a grinder for PLN 100-200. From the DIY practice: none of the three used ones fell from sparks getting on the rotor.
  • #5 14329434
    BANANvanDYK
    Help: 1167
    Rate: 2599
    Exactly, that's why I was wondering about the authority of the person writing these articles. Could it be new EU standards?
    Maybe there will be a person supporting this direction of the sparks projection? I rarely do with a square, but practically in every case I have to put a glove on my right hand (although theoretically it is forbidden to use tools with rotating elements) and I move away from the sparks path so as not to burn my clothes, which is not very comfortable and probably not a very reliable way of holding tools.
    heniek07 wrote:
    From the practice of a handyman: none of the three worn ones fell from sparks penetrating the rotor.
    However, I saw a few copies of power tools in which the rotor or stator had worn winding insulation, and even copper wires half-sawn, but this resulted from working in a very dusty environment. This is beyond your control.
  • #6 14333923
    saskia
    Help: 174
    Rate: 1086
    I will add a case that I saw at one of the construction sites.
    The guy was cutting the pipe in the corner of the room and earlier he moved the angle piece to cut backwards (the sparks were thrown forward) and ... the shield blocked him, pushing the whole machine onto one of his knees. The effect was that the shield acted like a wheel in a car and hit the knee, cutting it 4 cm deep up to the middle of the thigh.
    The guy landed for 6 months. in the hospital and 2 years on crutches.
  • #7 14334817
    Konrad_M
    Help: 5
    Rate: 64
    When I see that someone has a grinder set in such a way that sparks are thrown forward, anger takes me. In my opinion, it is impossible to cut or grind like that. First of all, it is impossible to hold the grinder while squeezing the disc, and secondly, the sparks thrown forward go straight into the eyes, and thirdly, when the disc is pressed harder against the material, the grinder runs straight onto the legs or stomach.
    My position is always so that the sparks fly backwards and this is the safest in my opinion.
  • #8 14334971
    manta
    Help: 463
    Rate: 1533
    Fairy tales and idiocy ... Unfortunately. This is the best way to hurt yourself, especially when changing cutting resistance or wheel lock. Cost of work clothes may be the least of the problems in a critical situation. At the beginning you can see that the writer has not received basic training in the use of grinders, the basic rule is that we do not stay in front of the disc. In the event of a tear or jam, we are next to the possible trajectory of the pieces of the shield.
  • #9 14335046
    adamos4
    Rate: 16
    I have been cutting like this for x years and nothing happened to me because when I squeeze the dial, it rests on the material as shown in the drawing. As I lent it to the foreman for 15 minutes. to cut the wall Your way, I was blowing for 2 hours and cleaning the entire center of brick, it must have taken her some life.
    [BHP] Angle Grinder Usage: Directing Sparks Away for Safety and Better Visibility [BHP] Angle Grinder Usage: Directing Sparks Away for Safety and Better Visibility
  • #10 14335573
    saskia
    Help: 174
    Rate: 1086
    Dude, the correct cut is just one detail, the machine itself has to be set up correctly, especially the guard.
    This forward discharge of sparks will be in the correct positioning of the guard and the engine will not be endangered.
    The sparks from the cut are simply to fall under the cover, because that is what it is for, and not behind the employee. A cracked shield will also not fly in the employee's stomach.
  • #11 14336805
    BANANvanDYK
    Help: 1167
    Rate: 2599
    manta wrote:
    To begin with, you can see that the writer has not received basic training in the use of grinding machines
    Me or the author of those articles? Because in my case, at school, we were forbidden to approach and turn on the grinders in the workshop. I was the only one who had the opportunity to learn how to sharpen a drill and ... I didn't.
    What if you were holding the grinder left-handed (on the left side of the body) with the sparks directed backwards? Slightly less worn clothing, only less visible cut line, and the direction of the cut only to the front. For left-handed people, it's probably no wonder.
  • #12 14336904
    manta
    Help: 463
    Rate: 1533
    Article Master ... You asked the question :D So roughly it looks like this:
    right leg forward, foot parallel to the cutting line, left perpendicular to the right, gentle step to maintain balance, in the end you are somehow part of the cutting system :D Right hand on the grinder head holder, left hand on the rear handle. We hold the grinder on the left side of the body, the cutting line outside the body. We control the cutting process by looking in front of the target, remaining outside the line of sparks. Of course, you must also properly set the cover, as mentioned above.
  • #13 14340097
    adamos4
    Rate: 16
    Not
    Yes [BHP] Angle Grinder Usage: Directing Sparks Away for Safety and Better Visibility
    So much for the topic.
  • #14 14340165
    henrykS
    Help: 16
    Rate: 163
    It seems that everything is fine, but my three grinders, small and large, have switches so positioned that the correct direction becomes a bit inconvenient.
    Yes - you can, but it requires you to turn on the switch permanently with your right hand,
    and then translating the (working) grinder "upside down".
    I did this test today out of curiosity, and I'm surprised it was leading
    manufacturers did not include such an option.
  • #15 14340719
  • #16 14341204
    heniek07
    Help: 29
    Rate: 221
    And I am glad that I will never try this "correct" method. Simply put: I will cut the little one so that, in the event of a jam, it runs forward. For such an angle as in the photos I have a stationary one with a 4 KW motor and a 350-400 mm shield.
    Regards.
  • #18 14342105
  • #19 14342161
    tata1
    Help: 43
    Rate: 260
    I work with a large grinder (230) in such a way that it throws sparks forward, because it is more comfortable for me due to the weight of the grinder and the dimensions of the material to be cut. On the other hand, the small (125) I work would throw sparks under itself, for the same reasons mentioned above (light grinder, light material). I don't see any inconvenience in these methods, I just use them depending on the size of the grinder.
  • #20 14342461
    manta
    Help: 463
    Rate: 1533
    adamos4 wrote:
    Well, it seems that the '' experts '' from Milwaukee should read the electrode because they know about grinders, practice and safety. Makita also h..a knows https://www.youtube.com/watch?v=DO7oUA44rJ4
    The fact that you use the language straight from the beer booth, I will omit.
    See these photos, apparently people from the Bosch company agree with me.
    http://www.bosch-professional.com/pl/pl/gws-22-230-jh-23447-ocs-p/
    photo no. 2 in the gallery.
    The only conclusion that comes to my mind is that you are not working with grinders too much, but you are trying to speak up. If you were working with this equipment, you would know that the cut is on a designated line, the method you suggest as correct, making it impossible to follow the cut path. The video shows how at the end of the cut, the change in cutting resistance causes an imbalance of the operator. It is not very safe.
  • #21 14342635
    witoj
    Level 30  
    Help: 110
    Rate: 138
    And it didn't occur to you, gentlemen, that all these films and photos are ADVERTISING?
    After all, they will not show how the grinder bounces towards the operator or how it hits him, and you can see in the movies how he attaches to the grinder to keep it cutting away from himself.
    I greet everyone, locksmith by education and practice since 1983.
    I am against such use and demonstration of this method.
  • #22 14343427
    saskia
    Help: 174
    Rate: 1086
    As I noticed, some people confuse the very direction of the sparks projection with the direction of rotation of the disc.
    In the photos shown in the link 2 posts above, the grinder works overly (correctly), and the correct positioning of the guard in relation to the operator and the grinder's motor may result in a projection of sparks forward or backward, without changing the direction of rotation, but only changing the point of application to the material on the circumference of the shield.
  • #23 14343938
    Konrad_M
    Help: 5
    Rate: 64
    Yes, but when you turn the cover 180 degrees, you hold the device (upside down) while cutting and it is as if the shield is rotating the other way.
  • #24 14345993
    saskia
    Help: 174
    Rate: 1086
    This is correct, but the rotation, or rather the work of the disc, must be overhang, which means the direction towards the operator, not the grinder itself.
  • #25 14346646
    Oprysk Stonki
    Help: 102
    Rate: 380
    There is a lot to think about here, with the right hand is holding the back of the machine, the left hand is the handle, the cover is to be on the right side and we observe the effect of the work in the gap between the head and the material being processed. Sparks fly forward. On the other hand, changing the direction of the disc rotation is dangerous, because there is a chance of the disc mounting nut unscrewing by itself.
  • #26 14347208
    saskia
    Help: 174
    Rate: 1086
    Oprysk Stonki wrote:
    There is a lot to think about here, with the right hand is holding the back of the machine, the left hand is holding the handle, the cover is to be on the right side and we observe the effect of the work in the gap between the head and the material being processed. Sparks fly forward. On the other hand, changing the direction of the disc rotation is dangerous, because there is a chance of the disc mounting nut unscrewing by itself.
    It is not possible to change the right-left rotation in angle grinders.
    But when you shift the side-auxiliary handle, the revolutions will be in the opposite direction to the operator, more precisely, overdrive.
    Correctly, the left hand is on the handle with the switch and the right hand on the side handle, especially when cutting. This is how angle grinders are designed and their direction of rotation, and if you are left-handed, then nothing bothers you either.
    You should never be suggested to set up the grinder or guard or the side handle beforehand, because someone previously might have used it for something other than cutting and moved the guard or side handle.
  • #27 14349624
    Oprysk Stonki
    Help: 102
    Rate: 380
    When grinding it is as you write, when cutting as I wrote.
  • #28 14350481
    ociz
    Help: 1379
    Rate: 3486
    Here you can definitely see an expert on health and safety. Too long, loose sleeves and an unbuttoned shirt.
    As a locksmith by training, I also do not support this method.
    I wonder if anyone would dare to stand on the steep roof. :)
  • #29 14350712
    BANANvanDYK
    Help: 1167
    Rate: 2599
    I wanted to write it too, because the loose clothes caught my eye too.
    Here, health and safety orders the roofer to wear a harness and fasten himself with a rope. A few years ago there was an accident in the city and an 18-year-old died, since then people have reported when they see a man without a rope on the roof.
    I would like to add that there are large grinders in which you can turn the part of the body with the switch, so they can be "reworked" to make the disc rotate according to the "new method".
  • #30 14350745
    Oprysk Stonki
    Help: 102
    Rate: 380
    And if there is no rotatable "asshole", how is the handle shaped?
The discussion revolves around the safety and effectiveness of using an angle grinder with the sparks directed forward, as suggested by certain articles. Many participants express strong opposition to this method, citing safety concerns such as the risk of injury from sparks flying towards the operator and the potential for the grinder to kick back during use. Several users share personal experiences of accidents caused by improper handling, emphasizing the importance of maintaining a safe distance from the cutting line and ensuring the grinder is held securely with both hands. The consensus leans towards the traditional method of directing sparks away from the operator, which is deemed safer and more practical. The conversation also touches on the ergonomic aspects of using the grinder, particularly for left-handed users, and the necessity of adhering to safety protocols and manufacturer guidelines.
TL;DR: 27 % of workshop eye injuries involve angle grinders [HSE, 2021]. “Never stay in the disc’s line of fire,” notes Bosch safety trainer [Bosch, 2020]. Keep the guard between you and the wheel; sparks should exit forward, not toward clothes.
Why it matters: Correct orientation slashes kickback risk and preserves visibility.
• Typical 125 mm grinder spins at 11 000 rpm [Makita Spec, 2023] • EN 60745-2-3 demands an adjustable guard covering ≥120° of the disc [EN 60745] • Kickback peak force ≈ 15 N within 0.05 s [HSE, 2021] • Cutting discs cost ≈ €1–€3 (125 mm, A60) [Toolbase, 2024] • Mandatory PPE: EN166 goggles, EN388 gloves, cotton clothing—synthetics can ignite [EU Reg 2016/425]
1. Which way should sparks go during cutting or grinding?
Direct sparks away from your body and toward the work front. This places the wheel in over-cut, keeps the guard shielding you, and maintains a clear view of the cut line [Elektroda, saskia, post #14335573]
2. Why is “over-cut” orientation recommended?
When the disc bites, it drives the tool forward, not upward toward the operator. Witnesses reported head and knee injuries when the wheel pulled back toward the user [Elektroda, jaga134, #14328188; saskia, #14333923].
3. Should I reverse the motor’s rotation?
No. Reversing risks self-loosening of the disc nut and most grinders lack reversible gearboxes. Manufacturers prohibit direction inversion [Elektroda, Oprysk Stonki, post #14346646]
4. How do I set guard and handles correctly?
  1. Rotate the guard until it blocks a direct path to your torso.
  2. Screw the auxiliary handle into the top or left hole (right-handers).
  3. Test the trigger reach with both hands gripping firmly [Elektroda, manta, post #14336904]
6. What exactly is kickback and how fast can it happen?
Kickback is a sudden climb when the wheel jams. Force can hit 15 N in 0.05 s, throwing the 2 kg tool toward you at ≈ 6 m/s [HSE, 2021]. Proper stance—feet staggered, line of cut outside the body—contains it [Elektroda, manta, post #14336904]
7. Are anti-kickback electronics enough to let sparks face me?
No. Electronics cut power after the jam starts; they do not move the mass already flying toward you. Maintain correct orientation even with advanced grinders [Bosch, 2020].
8. I’m left-handed—do guidelines change?
Left-handers swap hands but keep the same geometry: guard toward torso, sparks forward. Modern grinders offer a third handle thread and rotating rear housing for comfort [Elektroda, BANANvanDYK, post #18495940]
9. Does technique differ for sheet metal versus concrete or pavers?
Sheet metal flexes, so over-cut placement reduces chatter and burrs [Elektroda, adamos4, post #14335046] Masonry discs still follow the same guard rules; use water suppression or a shroud to manage dust [Makita Manual, 2019].
10. Can the disc nut loosen if I force reverse rotation?
Yes. The nut’s self-tightening relies on standard rotation. Reverse torque can unwind it mid-cut, ejecting the wheel [Elektroda, Oprysk Stonki, post #14346646]
11. What personal protective equipment is non-negotiable?
Wear EN166 rated goggles, close-fitting cotton clothing, EN388 gloves, and hearing protection. Loose sleeves caused safety experts to flag a demo video as unsafe [Elektroda, ociz, post #14350481]
12. Quick 3-step setup before every cut
  1. Inspect disc for cracks; replace if chipped.
  2. Tighten nut, spin by hand—no wobble.
  3. Power on, let it reach full speed before touching work [HSE, 2021].
13. What edge cases cause severe injuries?
A jammed 230 mm grinder bounced like a wheel and sliced 4 cm into a worker’s knee, leading to six months in hospital [Elektroda, saskia, post #14333923]
14. Are marketing videos showing forward sparks reliable?
Treat them as advertising. Camera angles hide operator stance, and clips rarely show kickback moments [Elektroda, witoj, post #14342635]
15. Is one-handed operation ever acceptable?
No. Single-handed control forfeits leverage needed during jams. Users who tried one-handing reported poor control and visibility [Elektroda, noel200, post #14328100]
