Measuring Amperes Through Human Body from 230V Socket
massi 15545 5
  • #1 11109471
    massi
    I know there is 230V in the socket. I know that I will not measure how many amps there are in the socket because it depends on the resistance connected to the socket of the device.
    I would like to know how many or how to measure how many amperes will flow through the human body if he is electrocuted from the socket?
    Will this be the maximum value that is set on the fuse?
  • #2 11109478
    Kuniarz
    Moderator of Designing
    Help: 371
    Rate: 826
    massi wrote:
    because it depends on the resistance connected to the device socket
    ... at this point, man is also such a device with a certain resistance, so theoretically you can calculate the current.
  • #3 11109487
    massi
    How ?
  • #4 11109508
    opamp
    User under supervision
    Help: 266
    Rate: 925
    To view the material on this forum you must be logged in.
    1kohm human body resistance in short depends on the temperature of skin moisture etc ...
  • #5 11109521
    Kuniarz
    Help: 371
    Rate: 826
    massi wrote:
    How ?
    ... from Ohm's law.
  • #6 11109527
    Błażej
    Help: 1923
    Rate: 3627
    3.1.17. It is forbidden to publish entries lowering the general level of discussion, resulting from laziness or containing the demanding nature of statements.
