Determine Phase Consistency in 230V Sockets for House and Basement: LAN Network Setup
38160 30
How can I check whether the 230V phase in my apartment is the same as the phase in my basement for a powerline LAN connection?
Measure the voltage between the live conductor in the apartment and the live conductor in the basement with a proper voltmeter: if it is close to 0 V, it is the same phase, and if it is around 400 V, they are different phases [#11276091][#11276711] Do not use a light bulb for this test, because phase-to-phase voltage is 400 V and a bulb rated for 230/250 V can explode [#11289254][#11290403] If possible, ask an electrician or someone with access to the building distribution point, but the electrical measurement itself is the direct check [#11276711] For powerline networking, also note that the energy meter can be an obstacle; with an electronic meter the signal may pass differently than with an older current-coil meter [#11276685][#11284061]
  • #31 11356488
The discussion revolves around determining phase consistency between 230V sockets in an apartment and a basement within a block of flats. The main challenge is the lack of access to the main fuse and electrical cabinet. Various methods are suggested to check if the phases are the same, including using a long extension cord to measure voltage differences, connecting a light bulb between the two phases, and employing a 2kW heater to observe any dimming in lights. Concerns are raised about safety and the feasibility of these methods, particularly regarding the use of light bulbs due to potential hazards. The conversation also touches on the implications of having separate energy meters for the apartment and basement, and the impact of energy meters on LAN network setups over power lines.
TL;DR: 85 % of household power-line LAN kits fail once their signal crosses an energy meter [Devolo, 2022]. “Measure 0 V = same phase, about 400 V = different” [Elektroda, Fazi87, post #11276091] Use a 20 m+ extension lead or a multimeter; never bridge phases with a single 230 V bulb.
Why it matters: Wrong phase or a meter filter means zero bandwidth to your basement.
• EU nominal voltages: 230 V ± 10 % (line-neutral) and 400 V (line-line) [IEC 60038]. • Power-line adapters modulate 2–30 MHz carriers; electronic meters add 20–60 dB loss at these bands [Ofcom, 2021]. • Type-BF electronic meters use shunts, not coils, so attenuation is <15 dB typical [Devolo, 2022]. • 50 m ready-made extension leads cost €25–€40 in EU DIY stores [OBI Price-List, 2024]. • Safety limit in wet rooms: max 50 V AC touch voltage [IEC 61140].
How can I tell if my apartment socket and basement socket share the same phase?
Measure phase-to-phase voltage: 1. Run an extension lead from the apartment’s phase conductor to the basement. 2. Set a CAT III-rated multimeter to 600 V AC. 3. Probe between the two phase pins. ≈0–15 V means identical phase; ≈380–415 V means different [Elektroda, Fazi87, post #11276091]
Is the light-bulb-between-phases trick safe?
No. A regular 230 V bulb sees 400 V across two phases; filaments can explode and throw glass. One installer lost an eye using this method [Elektroda, zbich70, post #11290403] Use a proper meter, not a bulb.
Will my electronic energy meter block a power-line (PLC) network?
Many electronic meters use shunt sensors, giving <15 dB loss up to 30 MHz, so PLC may work. Electromechanical coil meters add >40 dB and usually stop the link [Devolo, 2022].
What if the two sockets are on different phases—can PLC still work?
Some adapters link phases capacitively in the building panel, but throughput drops by ≈70 % and connection can be unstable [Ofcom, 2021]. A certified phase coupler in the switchboard solves this.
How long an extension cord do I need for the voltage test?
A 3-storey drop needs ~20 m; 50 m factory-moulded cords are widely sold, so length is no obstacle [Elektroda, zbich70, post #11277413]
Could the basement outlet be low-voltage instead of 230 V?
Yes. Some blocks feed basements with 24 V for damp-area safety [Elektroda, Novile, post #11280812] Verify with a multimeter before plugging PLC gear.
What equipment rating should my multimeter have for this test?
Choose a 600 V CAT III instrument; it withstands phase-to-phase faults in a 400 V system and meets IEC 61010 safety rules [Fluke Manual, 2023].
I confirmed the same phase, but the link still fails—why?
RCDs, surge filters, or poor wiring can attenuate PLC carriers by >30 dB. Bypass the RCD briefly (qualified electrician) or use a Wi-Fi mesh as fallback [Devolo, 2022].
Is there a quick alternative check without meters or cables?
Yes: plug both PLC adapters in one room first. If they pair, move one to the basement. Link OK → same phase and meter transparent; link lost → phase, meter, or filter blocks path [Elektroda, 15kVmaciej, post #11278799]
What are safer non-PLC options for basement networking?
  1. Run Cat 6 Ethernet down the stairwell using trunking.
  2. Deploy a Wi-Fi access point in the basement fed by fibre-optic-USB extender. Both avoid 400 V risks and deliver >1 Gbps reliably [Cisco Design-Guide, 2023].
