Wiring Guide for Installing Dual Horns with 12V 40A Relay and 30A Fuse
kedly 70185 6
  • #1 11278336
    kedly
    Hello, I would like to install a separate horn in my car - I don`t want to resuscitate the old installation, something died - that`s why I want to install a new one.
    For this purpose, I purchased a normally open button, a 12V40A relay and 2 horns.
    There are a lot of diagrams for such relays on the Internet, but I can`t identify them with my situation - so I`m asking for help in solving my problem, which I would like to see illustrated or described in detail - regarding the picture I attached.
    Oh, and what fuse should I use? 30A is enough?
  • #3 11284769
    kedly
    Dziarski Hank - unfortunately your description does not work, I connected everything correctly, I only had doubts whether the relay itself was functional, so I got another one, but without a positive result.
    I am attaching a photo of the relays I have.
  • #4 11284781
    Grzegorz_madera
    Help: 268
    Rate: 1736
    The diagram is definitely correct. You`re doing something wrong.
  • #5 11284794
    kedly
    Well, that`s what I thought at first, but after checking it again, I got another relay and checked the whole thing again (from the efficiency of the horn itself to the normally open button). The problem is not in my design - maybe both relays are on the left side?
  • #6 11284887
    Błażej
    Help: 1923
    Rate: 3627
    Only you know that.
    Connect the horns as shown in the drawing, and independently supply power to the coil and check if they start. If so, you have a problem in the control circuit. Pull out the relay and supply power directly to the horns with some wire. If they don`t move, you have a problem in the electrical circuit. It`s a trivial diagnosis!
  • #7 11284922
    kedly
    It just dawned on me, I went to the car and it turned out that I`m a hammer, I forgot to put the fuse in the housing. Now everything is running smoothly. Thank you for your help!
The discussion revolves around installing dual horns in a car using a 12V 40A relay and a 30A fuse. The user seeks guidance on wiring the new setup, as previous installations have failed. Initial responses provide diagrams and troubleshooting steps, emphasizing the importance of checking the relay and horn functionality. After several attempts and verifying connections, the user discovers that the absence of a fuse was the issue, and once resolved, the installation works correctly.
