Citroen C4: Setting Up Voltage Routing System for Blower Supply via X (30A) Fuse & Y (40A) Fuse
zlotaraczka. 11220 6
  • Relay-controlled blower power from ignition-switched fuse feed
    #1 16461425
    zlotaraczka.
    Rate: 63
    For some, a stupid question may but ...
    How to build a simple voltage routing system from the X (30A) fuse, used to operate several components, to the relay, and from the relay, supply power to the Y (40A) fuse responsible for powering the blower inside the vehicle? What exactly relay to use for this?
    The blower power supply is led through the module in which the 40A fuse power line fell and the blower either works at 1 speed or rarely at 2 or not at all. Apparently, the power line conducts some more current but it is not able to carry a greater load (the power line is printed on the board, and the whole is originally covered with some resin).
    I connected the power supply to the blower fuse directly from the main power point of the entire module, but the disadvantage of this is that when you turn off the ignition, the blower still works and you have to remember to turn it off by turning the blower speed knob to position 0, and I would like to do such a system using the relay and, of course, maintaining the fuses so that the tension "goes on the key".
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Just take the relay control with the key. Secondly, locate and repair the fault, because France takes revenge on the ferns.
  • #3 16461821
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    Replace BSM. The stimulant costs pennies.
  • #4 16462474
    zlotaraczka.
    Rate: 63
    Fraction can take revenge - I know that :)
    Used BSM. Roulette, since you know what's in it and what it can fail ... I will ask, I will look after the auctions more.
  • #5 19203357
    dziadek30
    Rate: 27
    Hello, I have repaired the bsm, I replaced the relay next to the fuel pump relay.
    New relay from Allegro and an hour of work.
  • #6 19631054
    Alek77
    Rate: 25
    How did you desolder the relay in BSM?
    An ordinary soldering iron probably won't work because the relay is still glued to the PCB ...
    I am asking because I have a fight with a damaged relay - in the sense of replacement
The discussion revolves around setting up a voltage routing system for the blower in a Citroen C4, utilizing an X (30A) fuse and a Y (40A) fuse. The user seeks advice on how to connect these components through a relay to ensure proper operation of the blower, which currently only functions intermittently. Responses suggest checking and potentially replacing the BSM (Built-in Services Module) and relay, with some users sharing their experiences in repairing or replacing these components. There are also inquiries about the technical aspects of desoldering relays from the BSM.
