Passat B6 '05 - Parking brake, errors suggest a problem with the power suppl
Pati 77358 17
Why do parking brake motor errors 02432 and 02433 appear even though the supply voltage is above 12 V, and why do the motors cut out during output tests?
The most likely cause is not the measured supply voltage itself, but a mechanically stuck or badly connected parking brake caliper/motor that makes the controller cut the circuit off. Check the wiring and terminals first, because poor контакts at the connector can make the module see the wrong current draw and shut down the output [#11373049] [#11374848] If the motors only click and do not move, apply 12 V directly to the motor with reversed polarity to see whether the piston/cable moves; if it does not, the caliper is likely seized, rusty, or mechanically broken and should be repaired or replaced [#11374848] [#11374780] One user freed a stuck unit by manual movement, flushing it, compressing it, lubricating it, and reassembling it with silicone, after which it worked again [#19323844] Another reply notes that broken gears inside the actuator can also cause the overcurrent cut-off, in which case replacing the caliper is the practical solution [#11377729]
  • #1 11371969
    Pati
    Help: 35
    Rate: 409
    02433 - Supply Voltage for Right Parking Brake Motor (V283)012 - Electrical Fault in Circuit - MIL ON
    02432 - Supply Voltage for Left Parking Brake Motor (V282)012 - Electrical Fault in Circuit - MIL ON
    Hello everyone! The problem arose suddenly - from the testimony of the owner. The power supply when reading parameters from address 53 shows that the power supply is above 12V. I tried resetting a bit following the instructions from the net (but without disconnecting the battery) but nothing. After turning off the ignition and trying with OUTPUT TEST, the light suddenly dims, shows the current consumption for a moment, but suddenly disconnects. Again, I have to turn the ignition off for about 10sec to get this short term overload.
    I read something about updating the software from English sites, but I haven't really figured out what's going on.
    Best regards and I hope you can help ;)
  • #2 11373049
    szogun0
    VAG group specialist
    Help: 135
    Rate: 547
    See the wires at the terminals.
  • #3 11374019
    Pati
    Help: 35
    Rate: 409
    I checked everything, I connected it briefly on thick cables, there are only knocks with zero movement, so I suspect that something mechanical took them. Anyone know anything about this topic?
  • #4 11374780
    goldwinger
    Help: 534
    Rate: 2100
    Probably mechanically locked.
    Is the motor housing cracked?
  • #5 11374841
    jurekk55
    Level 36  
    Help: 182
    Rate: 1580
    Check if he has new blocks, maybe he changed them at the blacksmith
    zeimp
    Moderator on vacation ...
    Help: 548
    Rate: 2345
    Since I've been fighting with these clamps, I've set myself an avatar like this :D (principle of operation of the el. clamp).
    There, without power consumption, you won't be able to measure anything. Unplug the plug from the terminal, plug in the 21W bulb and it will light up only once and the controller will cut off the power supply, because the power consumption is too low ... This is what happens when the terminal is cut. I apply voltage directly to the clamp (with two wires) and by changing the polarity, I "drive" a few times back and forth with the piston in the clamp (if possible), if the clamp works, then you fasten the plug back, do tests/settings with VCDS and it's supposed to be. If the "short" clamp does not work, well - bad luck and ... the clamp must be replaced. It must be very, very clean there, on these contacts the terminal socket / wiring plug, otherwise the computer does not see the correct current consumption parameters and cuts off the circuit completely ...
  • #7 11374854
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    Pati wrote:
    I connected it briefly on thick cables, there are only knocks, no movement
    You're right - rusty. Replace and smash the old ones with a hammer - you'll be surprised what crap is inside. (Replace the electronics itself - two screws only)
  • #8 11375515
    Pati
    Help: 35
    Rate: 409
    So I should immediately look for other clamps for the client? Can it be dismantled and repaired? I'm surprised that if they got off, it's two at once, unless one got off earlier but the customer didn't notice it????
  • #9 11375944
    szogun0
    Help: 135
    Rate: 547
    He would have noticed, because the failure of one disables the system. The auxiliary brake indicator light also flashes or is displayed in yellow.
  • #10 11376282
    Pati
    Help: 35
    Rate: 409
    Well, that's how it is now, I'm only surprised that both stand frozen when I connect them for a short time, and I hit the battery with thick cables until lightning strikes. Weird that they both locked up at the same time. Maybe he's been doing it for a while, but I'll have to ask him.
    Someone regenerated it?
  • #11 11377729
    zeimp
    Help: 548
    Rate: 2345
    Probably yes, but in a specialized workshop. I disassembled it several times and I will tell you that not only is rust a problem, but also this (photo) gear is broken and you can't fix it, and you won't even get parts. Later in turn (after folding) it will most likely be too hard to walk and what follows? Well, the controller will read too much current consumption and ... cut off the circuit ...
    Photo of the gear itself (the teeth are falling apart, plus the toothed belt):
    For me, it's buying a new caliper = the best solution.
  • #12 11377897
    Pati
    Help: 35
    Rate: 409
    That's exactly how it was, except that here it would be 100% fine and the transmission as well. It's rusted off. I threw it in the brake fluid, started it manually, then under the pressure from the compressor I accelerated this contraption and blew the fluid a few times, lubricated it, put everything on silicone and it works, let's see how long ;) . But this translation is a massacre, some low idea, but did you have to make it up so much???
  • #13 11377976
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    Pati wrote:
    we'll see how long.
    If the customer does not give up 1000 km from home abroad, he will be satisfied :D :D :D
  • #14 11378654
    Pati
    Help: 35
    Rate: 409
    According to me, it should last for two years because it looked quite nice after raincarnation ;) , in my opinion, it was little used, maybe I'll offer him an autohold as something to start the mechanism ;)
  • #15 11378793
    Pawel wawa
    Help: 1262
    Rate: 4432
    You risked a lot, I would exchange, you will not be satisfied as for complaints you will have to clog up several hundred km.
  • #16 11378803
    Pati
    Help: 35
    Rate: 409
    I can see that if you say so, it may not be colorful, so I'll warn him, but as far as I'm concerned, it looks really good. We'll see, I'm not closing the topic for now, I'll get back to you at most. Regards!
  • #17 11380576
    Pati
    Help: 35
    Rate: 409
    The guy has this car for 3 years and he tells me that he has never used a manual car. Will try to do it now.
  • Disconnecting the module plug fixed parking brake errors
    #18 19323844
    MechBar
    I write even though wontek is probably out of date, but for those browsing the internet in search of help, it will definitely come in handy, basically it started with a routine replacement of the clamp on the right side, I ordered a new one from skv without electronics, the cables were a little cloudy but not rotten, I put the motor in and forgot to put on the test activation and error 02433 and it will not translate on the other hand, it is definitely functional and does not delete anything after connecting to the other side it works so after longer fights I found that the module must have failed I left it until the morning the next day with the clamp dropped and the test and immediately after the ignition it suddenly started after the activation and the errors cleared, which was impossible before, the application when replacing the clamp and works where it is required to disconnect the plug is the safest way to cut off the electricity, put it back together, start and everything will be ok.
The discussion revolves around a 2005 Volkswagen Passat B6 experiencing parking brake issues, indicated by error codes 02433 and 02432, which suggest electrical faults in the supply voltage to the right and left parking brake motors. The owner reports that the power supply is above 12V, but the system fails to operate correctly. Various responses suggest checking the wiring, potential mechanical locking of the motors, and the condition of the electronic clamps. Users recommend inspecting for rust, replacing faulty components, and ensuring clean connections to avoid circuit interruptions. Some participants share experiences of successfully repairing or replacing the clamps, while others advise against temporary fixes due to reliability concerns.
