VW Passat B6 1.9 TDI BLS: Resolving Parking Brake Error 02845 - Short to Ground
pisior1987 38274 9
How can I fix the sporadic 02845 parking brake fault / "short to ground" on a VW Passat B6 when the handbrake works normally but the orange P warning appears after restart?
The most likely cause is the parking brake module or switch/button assembly, not necessarily the caliper motors, and the fix may be to check coding/software or replace that module [#16248932][#16249797] One user had the same symptoms and found that the brake button could not be adapted to the computer, so the whole module in the tunnel under the armrest had to be replaced; after that, everything worked normally [#16248417] Another reply notes that if it is the electric parking brake, a faulty motor is possible, but the stronger recommendation in the thread is to suspect the module first [#16193335][#16248932]
  • #1 16193236
    pisior1987
    Help: 12
    Rate: 351
    This error:
    02845 - Indication in the instrument cluster (!)
    007 - short to ground - sporadic
    02845 - Function Display in Instrument Cluster (!): Short to Ground
    The error appears when I pull the handbrake, turn off the car, start it again. The P indicator lights up in orange. The brake works properly. After restarting the car, the light disappears. The instrument cluster is clean.
    Wiki answers it like this:
    "When found in the [53] - Parking Brake control module on the VW Passat or VW Passat CC RoW (Rest of World) vehicles would refer to TPI 2021874 (or 2021008)".
    What is it, has anyone experienced this?
  • #2 16193335
    Stanisław Chwalisz
    Help: 182
    Rate: 803
    Is that the electric brake? If so, one of the motors is faulty.
  • #3 16193498
    pisior1987
    Help: 12
    Rate: 351
    @Stanisław Chwalisz and why do you conclude that? The motor control is normal. The controller can probably diagnose which of the engines is already starting to fail?
  • #4 16193765
    Stanisław Chwalisz
    Help: 182
    Rate: 803
    From experience.
  • #5 16248417
    dolores25
    I had the same thing, the indicator light came on, then it went out by itself and everything worked, but for a while. First, the right caliper fell and blocked the wheel under the house, luckily I managed to unlock it and took it to the mechanic. He replaced the terminal, but the error was still on, so he tried to clear the error, but it did not help. The next thing was the brake button after the replacement, the error was displayed again, so it turned out that the button could not be uploaded to the computer and I had to buy the entire module, which is located in the tunnel under the armrest. After this replacement everything is fine.
  • #6 16248932
    mario 77
    Help: 66
    Rate: 335
    There are several other components in the parking brake system.
    Good question.
    In your case, rather a module.
  • #7 16249797
  • #8 20961050
    krzychu001
    Help: 11
    Rate: 204
    Does anyone have flash to fix this error?
  • #9 20961575
    stanislawchwalisz22
    I have a second module, just in case.
  • #10 20962058
    krzychu001
    Help: 11
    Rate: 204
    3C0 907 801 J. This is my number.
The discussion revolves around a parking brake error (02845 - Short to Ground) experienced in a VW Passat B6 1.9 TDI BLS. The error manifests when the handbrake is engaged, causing an orange P indicator light to appear, which disappears after restarting the vehicle. Users suggest that the issue may stem from a faulty electric brake motor or a malfunctioning parking brake control module. One user shared their experience of having to replace the entire module located under the armrest after multiple unsuccessful attempts to clear the error. Recommendations include checking the driver installation, performing a flash update, or replacing the module with a different one.
