As in the topic of Golf V 2007, the estate car does not work, the window lifter, the central locking and the illumination of the window lifting button on the rear left side. There are wires to the bundle: thick brown mass - there, thick red power - there, red - white - loudspeaker, brown and black - loudspeaker, two white wires, and the colors are given from the pillar to the door. The most important are the white ones, one of them in front of the pillar is purple and white and goes to the driver's door (I suspect it is a control from the driver's door panel), the other one in front of the ankle is red and black and here the trail breaks off when it enters a thick beam at left pit. No communication after connecting the computer. The module was purchased, another functional, although the controls were good (both work in the right door and there is communication), the switch is also located in the right door and works correctly. I am asking for a hint regarding the red / black and purple / white wires because I do not know which ones are communicated and where they are connected or where to get the signal for communication. Regards and I am asking for your suggestions.
sadek1979
sadek1979
Cars specialist
Help: 237
Rate: 1423
