Selecting Radiator for 20m2 Room: Aluminum vs Steel, Prorad V22 600x1000 vs Ragall Zero 50120
Wujas6969 85104 9
How should I choose a radiator type and size for a 20 m² room with central heating: aluminum or steel, and is one of the two models worth buying?
Choose a steel radiator if you want a more universal and generally reliable solution, but the right radiator size and power must be matched to the room’s heat demand, insulation, boiler temperature, and the temperature you want in the room [#11536416][#11547080] Good steel radiator brands mentioned were Brugman, Kermi, and Radson [#11538766] The thread does not give a direct recommendation for the two specific Leroy Merlin models, only that a proper selection depends on the heating calculations rather than on the material alone [#11547080]
  • #1 11535453
    Wujas6969
    Rate: 19
    Hello, I am looking for a heater for a room with an area of 20 m 2, 2.5 m high, i.e. 50 cubic meters. Better to choose aluminum or steel? The room is on the ground floor, insulated from above. Central heating: coal + wood.
    I found 2 heaters
    http://www.leroymerlin.pl/ogarzenia/grzejniki...lowy-v22-600-x-1000-prorad,p178944,l1007.html
    http://www.leroymerlin.pl/ogarzenia/grzejniki...uminiowy-zero-50120-ragall,p139408,l1007.html
    Is it worth buying something like this?
    ] Link [/url]
  • #2 11536416
    kabee84
    Help: 39
    Rate: 164
    I am a supporter of steel radiators, they are more universal and reliable, but not teee ...
    If you want to buy a GOOD steel radiator that will serve you for many years and will not rust or yellow, the paint will not come off, it will heat up well - you have to pay a little more and look in other stores ......
    FEMAX Łazienki. Ogrzewanie. Instalacje.
    Szczęśliwa 25, Gdańsk, 83-110 | Tel.: 664 XXX XXX (Show) | Company Website: femax.pl
  • #3 11536495
    Wujas6969
    Rate: 19
    What companies do you recommend?
    kabee84
    Help: 39
    Rate: 164
    Brugman, Kermi or Radson.
    But I will repeat once again - I personally am a supporter of steel. I can't advise aluminum ones because I don't have much experience with them.
  • #5 11539514
    Wujas6969
    Rate: 19
    Ok, I will look for the companies that you wrote, thanks for the info.
  • #6 11542492
    William Bonawentura
    Help: 190
    Rate: 619
    Just a matter of taste.
  • #7 11542871
    pablowp1
    Help: 46
    Rate: 144
    It is not a matter of taste that comes from physics, aluminum corrodes (oxidizes faster than it seems).
  • #8 11545865
    ogi4
    Help: 8
    Rate: 60
    Drop a photo of the aluminum radiator corroded from the inside.
  • #9 11546261
    Wujas6969
    Rate: 19
    I think that chemical factors are present not only in aluminum but also in cast iron and metal. Somehow, this aluminum radiator that was in the house served for about 20 years and did not corrode but cracked, possibly from a negative temperature. I already know Markie, and what about the size of the radiator, because some are different, e.g. 10 ribs per 12 m2 and others also 10 ribs per 16 m2
  • #10 11547080
    kabee84
    Help: 39
    Rate: 164
    The number of ribs (radiator size and power) depends on the heat demand of a given room. To determine this, you need to know the volume, method of insulation, type of boiler (i.e. the temperature of the heating medium) and what temperature you want in the room.
The discussion revolves around selecting a radiator for a 20 m² room with a height of 2.5 m, totaling 50 cubic meters. The user is considering aluminum versus steel radiators, specifically the Prorad V22 600x1000 (steel) and Ragall Zero 50120 (aluminum). Responses indicate a preference for steel radiators due to their reliability and longevity, with recommendations for brands like Brugman, Kermi, and Radson. Concerns about aluminum radiators include their susceptibility to corrosion and oxidation, although some users report long-lasting aluminum models. The importance of radiator size and heat output, determined by room insulation and heating method, is also emphasized.
