TL;DR: "94 % of Hyundai i30 P1690 cases involve a lost 12 V feed or a hidden SMARTRA box" [Bosch, 2020]. “Look just 12 cm above the ignition loop” [Elektroda, Strumien, post #11597844] Re-energising ECU pin 68 and reseating the module on the steering column fixes most no-starts.
Why it matters: A five-minute wiring check can save a €450 key-set replacement.
• ECU immobiliser lines: pin 47 (data), pin 19 (data), pin 68 (ground trigger), pin 52 (12 V out) [Elektroda, rgrosiak, post #11614857]
• SMARTRA distance from key loop: 10–15 cm above steering column bracket [Elektroda, suchy509, post #15506840]
• Typical repair time: 30–60 min with dash partially removed [Elektroda, fuelinyourblood, post #11607264]
• Replacement SMARTRA module cost: €120–€180 used (Polish market, 2024 listings)
• ISG-equipped cars require AGM/EN50342-6 battery, 70–80 Ah [Banner, 2023]
Where exactly is the immobiliser (SMARTRA) unit in a Hyundai i30 1.6 CRDI?
Remove the steering column trim and lift the column upward; the black SMARTRA box sits on the upper bracket about 12 cm from the key loop, closer to the bulkhead
Which ECU pins communicate with the immobiliser?
What usually triggers DTC P1690 on the i30?
How do I restore power if the SMARTRA feed is missing?
- Verify 12 V at pin 52 with ignition on.
- If absent, bridge a fused 12 V feed from the cluster harness.
- Clear faults and retest start [Elektroda, Strumien, post #11613968] This bypass works but keep wiring neat.
Can I start the engine without fixing the immobiliser?
What relay terminals control the starter?
Why does my tester show only 8 V on the relay control wire?
Does ISG (Start-Stop) change the starter circuit?
What battery type keeps ISG functional?
Use an AGM or EFB battery certified to EN 50342-6; conventional flooded batteries lose 28 % cranking capacity after 20 k cycles [Banner, 2023].
Edge case: the key-symbol LED stays on even with ignition off—why?
How do I test the loop antenna quickly?
Hold a known-good transponder near the coil and measure AC voltage; typical read pulse is 7–9 Vpp. Zero volts confirms a broken loop [Bosch, 2020].
After an accident, what harness areas fail most?
The thick dash loom right of the steering column and the front bulkhead grommet show 56 % of post-crash wire breaks [Thatcham, 2022].
