Hyundai I30: Central Key Lock Not Working - Door & Luggage Compartment Issues, Troubleshooting
jasieniek88 14829 1
  • #1 16851523
    jasieniek88
    Hello, I dug a lot of pages, videos and posts and found no solution to my problem.
    I open the car with the key. When the key is turned, all the doors and the luggage compartment open, similarly when I close the driver / front passenger door, all the doors and the luggage compartment close. The central locking has not been working since yesterday. When I turn the key in the lock to open, only the driver's door opens. When I open the other door from the inside and wants to close the car - I put the key in the driver's door lock, only the driver's door closes.
    - Closing the door from the inside with the "lock" button does not work.
    - I checked the fuses are ok.
    Where to look for a problem, or is the problem a central locking controller? - How to get to it - where is it located.
    I would like a hint on how to remove the problem.
  • #2 16952610
    tiger81mem
    Rate: 51
    in my case the same, if I close the door handles manually, it opens from the central driver's door panel and from the remote control, but does not close either from the remote control or from the lock button
