Gerda Door ZW6000 Lock Removal: Fixing 20-Year-Old Door's Handle Spring & Detaching Pull Rod
Szymon Tarnowski 15492 6
  • #1 16647409
    Szymon Tarnowski
    Help: 61
    Rate: 181
    I have a 20-year-old Gerda door with a built-in ZW 6000 lock or some kind of progenitor of this type. I would like to fix the spring of the door handle bolt (or what is the name of the handle operated handle). I need to remove the door lock. I can unscrew the lock and loosen it, but I can not unfasten the pull rod from the rear bolt (the pin which slides out on the opposite side from the lock and handle). The question is how to do it?
  • #3 17470770
    andysb
    Rate: 30
    Hello, under the link there are no details for disassembly / assembly of the central locking with strings. In my ZW6000 I have to replace the spring of the latch wavelength, so first I have to buy it somewhere and then deal with three strands (top, bottom and back of the lock). Until now, I was able to do everything, but I did not want to risk disconnecting the lock from the strings. Where could I buy these springs and how to cleverly deal with stretches?
    The service charges PLN 200, including PLN 150 for the service.
    Thanks in advance for your help.
  • Two handle springs, not the bolt lock
    #4 17516989
    Nix
    Help: 17
    Rate: 189
    I also have the same problem with the "latch" of the door handle - the door cannot be slammed.
    Is this one or more springs to replace? Because professionals write "replacement of a spring set" - but maybe they write in such a way that it sounds better :)
    Yes, there are 2 springs in the handle's bottom plate, but they retract the handle itself, not its
    bolt-lock.
    I think to choose a spring from a different, ordinary lock.
    Kisses Nix
  • #5 18872837
    marioking
    Rate: 16
    I have a similar problem with making the spring, but I can't even dismantle the signboards or remove the handles in this old model Gerda star s old type and take out the inserts because from the inside the screw heads are with some unique pattern, as if with a flat screwdriver made 30% X turn and I don't know how to undo it at all ... was that something you did too? because as I can see a set of these signs, they are sold with normal screws ...
  • #6 18872856
    Szymon Tarnowski
    Help: 61
    Rate: 181
    marioking wrote:
    on the inside, the heads of the screws are with some unique pattern, as if a flat screwdriver made 30% X turn and I don't know how to unscrew it at all ...
    I had these too, the profile of the cut is made so that it can be tightened, but when unscrewing the tip of the screwdriver slips. I guess it was to serve as a protection against illegal startup. I don't know how to unscrew it, my screws were loose, I could unscrew it with my fingers. The bolts seem to have undergone some heat treatment, maybe they are hardened, there may be a problem with drilling. I would try gently with a punch and a hammer.
  • #7 18872874
    andysb
    Rate: 30
    Try to tighten the wide flat screwdriver as you would, but twist to the left. For me, the service technician did so when replacing the insert. Later I did it myself, as I replaced the spring of the latch wavelet. This is a good option if the screws are not tightened too much. Even the service technician does not tighten too much because the screws are on the inside, so there is no fear that someone from the outside will unscrew it. The screws should therefore only be slightly tightened. Best regards.
The discussion revolves around the challenges of removing and repairing a 20-year-old Gerda door equipped with a ZW6000 lock. Users share their experiences with fixing the door handle's spring and detaching the pull rod from the rear bolt. Several participants express difficulties in disassembling the lock due to unique screw patterns and suggest alternative methods for unscrewing. Some users recommend sourcing replacement springs and discuss the possibility of using springs from other locks. The conversation highlights the need for careful handling to avoid damaging the components during the repair process.
