VW Tool - VWTool Installation on Windows 8 Laptop: Resolving This Application Will Not Work Message
malanx 13539 5
  • #1 11848476
    malanx
    Rate: 16
    Hello. Is it possible to install the VWTool diagnostic program on a laptop with Windows 8? In addition, I would like to say that when you try to run the setup.exe file pops up the message: This application will not work on your computer. I will add that the program has been downloaded from the elektroda.pl website. Thank you and best regards.
  • #2 11851919
    DriverMSG
    Help: 3984
    Rate: 4893
    VWTool in what version? Windows 32 or 64 bit?
  • #3 11879179
    bestiarac
    I would also ask you if there is such a possibility of VWTool for 8 x64 wines
  • #4 11993256
    malanx
    Rate: 16
    preferably the 32bit version, because it happened to me that even though I have an x64 system, the x32 version worked more stable
  • #5 13183240
    jakubek2109
    Hello, has anyone already "worked out" how to install VWTOOL on windows 8? The question is whether it can be done or do you have to use older versions of windows?
  • #6 15475119
    msk85
    Rate: 10
    I was looking for another topic about VWTOOL and I came across this one, so I will throw in my solution.
    Using VWtool and today: I installed the Oracle VM virtualbox (free program). I created a vortex computer on which I installed Win XP. The result is that I have a standard Win 10 computer, and "in it" another virtual computer with Win XP. This solves all problems with using old programs. VWtool works without reservations.
