VCDS 15.7.0 on Windows 8.1 - No Response After Installation
yamaha777 5754 11
  • #1 15219878
    yamaha777
    Hello all;]
    problem with vcds of course Chinese 15.7.0 after installing no response to program opening. The cable detects the comp ut nothing after that, I use windows 8.1.
    Can anyone help?
  • #2 15219894
    grala1
    VAG group specialist
    Help: 1496
    Rate: 5054
    Check on another operating system.
  • #3 15219896
    yamaha777
    I had windows 10 and the same. I do not have another one, as it is.
  • #4 15219900
    grala1
    Help: 1496
    Rate: 5054
    This is a Chinese program and the devil knows if he works on these systems.
    From what I know it works on XP and 7.
  • #5 15219907
    yamaha777
    I had 12.12.0 and even worked on windows 10. You say that only on xp and 7 will work?
    Added after 6 [minutes]:
    once I managed to run as admin and as I wanted to save the settings after clicking "save" a window appeared with this "Unable to write to the VCDS.CFG file. "
  • #6 15219933
    grala1
    Help: 1496
    Rate: 5054
    I do not know, you have to check.
    The program may be damaged.
    If you do not check it you will be lost.
  • #7 15219980
    tzok
    Help: 3177
    Rate: 6563
    The cable has nothing to run or program. But with the clone only the program attached to it will work.
  • #8 15220041
    yamaha777
    I have two such cables two plates and two the same.
  • #9 15220092
    grala1
    Help: 1496
    Rate: 5054
    The cable is not needed to run the program - at least it is in the original.
  • #10 15220312
    yamaha777
    Maybe I can succeed on another.
  • #11 15220330
    sebap
    Help: 538
    Rate: 1083
    grala1 wrote:
    cable is not needed to start the program - at least this is the case in the original.
    In the clone interface is also unnecessary to run the program.
  • #12 15220355
    yamaha777
    how to do it? maybe someone is 15.7.0 that I would take from someone else.
The discussion revolves around issues with the VCDS 15.7.0 software, particularly a lack of response upon opening the program after installation on Windows 8.1. Users suggest checking compatibility with different operating systems, noting that the software may work on Windows XP and 7, while one user mentions it previously functioned on Windows 10 with an older version (12.12.0). Concerns are raised about the reliability of the Chinese version of the software, and the possibility of file corruption is mentioned. The role of the cable in running the program is debated, with some asserting that the cable is not necessary for the software to operate, especially in original versions. The author expresses interest in obtaining a working version of 15.7.0 from another user.
