Running a Cable Across Countryside Street: Regulations and Safety Measures
Skorek 35415 48
Can I run a cable across a countryside street between two houses, and do I need any permits for it?
Formally, you need permission from the commune/city office and road manager, plus a construction plan and consent from other underground-network owners; doing it legally can take months and cost several thousand złoty [#1235613][#1236561] If you install it without permits, it is at your own risk: a neighbor or official can report it, and the cable may be removed or the installation dismantled [#1235613][#1242375] For a legal alternative, several replies recommend Wi‑Fi/radio instead of a physical span across the road [#1242375][#1244937] If you do make an overhead span, use proper outdoor/self-supporting cable or a steel support cable with masts on both sides, not a random indoor UTP run [#1244937]
  • #31 1286163
    kasprzyk
    Electrician specialist
    Help: 354
    Rate: 669
    you have to calculate - whether it will be cheaper to buy a telephone cable with a cable + computer cable or only a cable (or wire) + computer cable - in my opinion the first solution is pointless ;)
    for fastening, you can use clamps - very quick and durable assembly
    Look:
    http://www.aste.com.pl/index.cgi?idn_parent=12&lang=pl
  • #32 1286362
    grzesiox
    Level 19  
    Help: 20
    I do not understand one thing - you say the telephone wire from the link is a twisted pair :| if you get even 2 pairs, it will be enough for you and you will pull the network with this cable :D
    If you want otherwise, you buy a cable and attach it with bands or good insulation with an OUTER twisted pair and hang it :) the handles can already be on the poles (usually a piece of wire hangs on the concrete ones, and on wooden ones you can screw in an ordinary screw :) ).
    PS show me where people ask for permission ;) for overhangs ;)
    In big cities, even this is done without asking, let alone in the countryside :) and the poles are not communes, so your neighbor won't do anything to you ;)
    Regards
  • #33 1286511
    mcz1
    Level 19  
    Help: 21
    Rate: 25
    In my place, the company providing the Internet runs cables on electric poles fixed about 1 m below the power wires. I don't know how they managed it, and when I asked them if they had the consent of the power industry, they said yes, of course. And these are not just overhangs, it is an entire overhead installation for several dozen people in the countryside. It's been in operation for 8 months, it's probably legal, right?? ;)
  • #34 1287046
    kasprzyk
    Help: 354
    Rate: 669
    In big cities, it is even done without asking, let alone in the countryside :) and the poles are not communes, so your neighbor won't do anything to you ;)
    Regards
    let a friend correct this post, because I don't know if it's supposed to be eggs or a serious answer ;) if it's the former, it would be appropriate to write it at the end of the post - some may take it seriously
    Regards
  • #35 1287130
    raffq
    Help: 12
    Rate: 17
    I know everyone. This problem concerned my friend who lives in a total remote area and in addition in the forest!! He solved this problem by hanging a twisted pair from the house above the ground (across the road) to the nearest tree across the road. Then the cable was pulled through the tree branches. at the edge of the forest, he installed the Access point radio in a metal box. He fastened the Access point and the antenna to a tree. The length of the cable is about 70 m. :P
  • #36 1288999
    grzesiox
    Level 19  
    Help: 20
    Regards
    and in what frequency? with that twist? it's actually the cable that tpsa hangs on poles is the most ordinary twisted pair, so if he manages to get one, there is no problem at all ...
    As for the poles, I have seen many such installations done and they are still doing it even in Katowice, Bytom, Tarnowskie Góry, various villages ... so these are definitely not eggs either ...
    You can also rent a pole for, for example, 5 years from the power industry, then it comes out to about PLN 50 per year per pole :) and you are legally allowed :)
    As for the overhang, it just has to be at the right height and that's it.
    Regards
  • #37 1289723
    kasprzyk
    Help: 354
    Rate: 669
    grzesiox wrote:
    Regards
    As for the poles, I have seen many such installations done and they are still being done even in Katowice, Bytom, Tarnowskie Góry, various villages ... so these are definitely not eggs either ...
    Regards
    Well, we have a revolution in computer networks...
    Why are you people overpaying!!!??? why do you buy a category 5 twisted pair cable, after all, an ordinary cable is enough (read: twisted pair ;) ) two-pair telephone :) :)
    PS show me where people ask for permission to overhangs
    that's what you wrote in the first post - now you write that you've seen such installations or that you can rent a pole ..... and I agree with you here - that's what you should write in the first post
    Next time you post something stupid, think twice or post it in the fun section ;)
    Don't mislead people, because some people may lose or pay a lot for your advice.
  • #38 1292251
    seb_tm
    Help: 10
    Well, for example, if they live in blocks of flats and want to pull a cable between the blocks, they must have the consent of the housing cooperative:/ and they don't want to agree ... because they don't ... for no reason :/
  • #39 1292616
    legionalt
    colleagues hit the mark - nothing happened - they only evacuated the school and stopped the traffic for 3/4 of the day costs and consequences - that's another story
    and so on
  • #40 1292963
    kasprzyk
    Help: 354
    Rate: 669
    and yes dale
    what did your friend mean???
    I hope you took that as a warning?? ;)
  • #41 1293249
    grzesiox
    Level 19  
    Help: 20
    It's not about cooperatives, but there are some regulations that prohibit any overhangs between blocks.
    We had the same problems and finally there is WLAN between the blocks...
    Why are you people overpaying!!!??? why do you buy a category 5 computer twisted pair cable, after all, an ordinary two-pair telephone cable (read: twisted pair cable) is enough
    Are you familiar with the LAN 10/100 full duplex specifications? two pairs are enough for transmission, because it is on them that the data transfer is carried out.
    As for the telephone cable, it is just a twisted pair and imagine that it is better because STP, i.e. shielded in thick rubber insulation and a carrying cable attached with the same insulation - except that I have not seen these cables in pairs smaller than 4 pairs per wire.
    Another thing is UTP twisted pairs - there are so many different twisted pairs that you should look for 2 pairs, what are they for, etc. because I had the pleasure of laying a 2-pair UTP twisted pair many times over long distances and everything works, often on cheap equipment.
    I recommend networld there you will find a lot about twisted pairs and transmission cables and how they differ.
    As for the poles, I could actually say that this is a half-measure and they can stick, but rather tpsa only sticks to the power industry, I haven't heard anything yet, but it's safer to ask for permission and it's completely legal, I'm not sure about the height, but there is something about 5 meters above the road :| I don't remember anything like that so I don't want to mix it up.
    Regards
  • #42 1294290
    pydak
    Hello!!
    Exactly a year ago I pulled an unshielded twisted-pair cable suspended on an ordinary steel wire above the street (although it is probably not a commune, but rather there is a lot of traffic on it). I didn't ask anyone's permission and the network has been running for a year now. If someone writes that the unshielded twisted pair won't last in the winter, it's a mistake, everything works for me for a year, and my colleague has had the network for 3 years and everything works flawlessly.
    As for the permission to drag, I didn't ask anyone about it, I just dragged the cable and so far no one will get infected :P .
    AAAA and of course, when there is a storm, I disconnect all devices~ :P !!!!!!!!!
    REGARDS
  • #43 1295627
    kasprzyk
    Help: 354
    Rate: 669
    grzesiox wrote:
    ................................Do you know the LAN 10/100 full duplex specifications? two pairs are enough for transmission, because it is on them that the data transfer is carried out.
    and..............???? You haven't discovered America ;) that's exactly how it is
    grzesiox wrote:
    As for the telephone cable, it is just a twisted pair and imagine that it's better because STP, i.e. shielded in thick rubber insulation and a carrying cable attached with the same insulation
    for you every telephone wire is STP??? :)
    here's something about your best cable:
    Shielded twisted pair STP - has an additional layer of foil or metal wire braiding the wires. The reason for introducing shielding was the need to use twisted pairs in environments susceptible to electromagnetic and radio frequency interference. In practice, however, this prevents the twisted pair from functioning properly. Electromagnetic radiation is generated when a signal is transmitted over a copper wire. Shielding the cable with a metal sheath protects against external radiation. Unfortunately, it also stops induced radiation, i.e. radiation produced by this cable when a signal is sent through it. So, instead of propagating normally, the radiation is reflected by the shield and directed back to the copper wire, which is likely to damage the signal.
    and we get to the bottom of it, for what purpose did you put these wires ?? ;) here:
    Twisted pair categories acc. European standard EN 50171
    Class A - implementation of telephone services with a frequency band up to 100 kHz
    Class B - cabling for voice applications and terminal services with a frequency band up to 1 MHz
    Class C (Category 3) - covers typical LAN techniques using a frequency band up to 16 MHz
    Class D (category 5) - for fast local networks, includes applications using the frequency band up to 100 MHz (100 Mb/s)
    Class E (Category 6) - is the latest (1999) extension of ISO/IEC11801/TlA and includes cabling whose parameters are specified up to the frequency of 250 MHz (for applications requiring 200 Mb/s). Implementation of Gigabit Ethernet (4x 250 MHz = 1 GHz) and ATM 622 Mb/s transmission is planned
    Class F (category 7) - it is possible to implement applications using the band up to 600 MHz. It differs from previous classes in the use of STP cables (each pair in a shield plus a shield covering four pairs) connected with shielded connectors. Completion of work on the standard is expected in the years 2000-2001. For this class of cabling, it will be possible to implement data transmission systems with speeds significantly exceeding 1Gb/s
    Regards[/quote]
  • #44 1295718
    Pitereks
    Rate: 17
    grizzly what are you talking about?
    A telephone cord is not twisted pair. In the telephone line, the wires go side by side and are not twisted - where do you see a twisted pair there??
  • #45 1296107
    grzesiox
    Level 19  
    Help: 20
    Eh, I put the twisted pair because I'm making networks :|
    And as for the telephone one, the tpsa put us on DSL connections (8-pair twisted pair in this case) and on the same one (almost 4-pair) I was making overhangs about 70m in total over the road and then to the houses and it worked great too.
    And as for this screen, if it was worse, it wouldn't be done, and it wouldn't be more expensive than ordinary UTP ...
  • #46 1297935
    kasprzyk
    Help: 354
    Rate: 669
    Approx!
    grzesiox wrote:
    And as for the telephone one, this tpsa put us for DSL connections (8 pair twisted pair in this case) ...
    yes that's right - DSL connections....
    grzesiox wrote:
    on the same (almost 4ro steam) I did overhang about 70m in total over the road and then to the houses and it worked great too.
    it could be - maybe it's category 5 wire??
    :) think why FTP is more expensive than UTP??? ;)
    maybe because there is a different production technology??, or more simply - for the production of which cable you will use more material??
    Regards
  • #47 1298739
    grzesiox
    Level 19  
    Help: 20
    Okay, you're right about the prices, but it's still recommended to give stp or even ftp (I think that's what it was called), especially if there are external interference ...
    Anyway, what we're arguing about is important ;) and it works and checked ;)
    And as for the permits, as above, a few people except me wrote :) that's how it is, PS I don't recommend tpsa poles because they often watch their poles and don't like to have other cables than theirs ;)
  • #48 1299023
    kasprzyk
    Help: 354
    Rate: 669
    let's wait for my friend "Skorek" - I think all possibilities have been presented to him, he should finally start working, or maybe he already did?? ;)
    as for the "left" overhangs - it's like with everything in life, if you have everything legally - you sleep peacefully, in a different situation - it all depends on people or chance, someone will find it and catch it, someone else will not notice, yet another nods his hand - the choice is yours :) :)
  • #49 1299318
    longines
    Help: 78
    Rate: 38
    kasprzyk wrote:
    you must be sure that nothing passes under the road - otherwise don't risk it......
    According to the arcana of construction art, nothing is allowed to pass under roads of communication importance to a depth of 35 cm below the lower part of the surface - it's so serious.
    And not seriously, it depends, to a large extent, in what years this road was "laid", because under communism it was different ;-) And it is not known whether the neighbor who watches the neighborhood has not already pulled something under the road for himself (some kind of storm or something) ;-)
    Added after 7 [minutes]:
    arturs69 wrote:
    Hello. Reading some posts with "partisan" advice, my hair stands on end. After all, methods such as: cutting asphalt, pushing a pipe under a road (including a municipal road) without permission, etc. are breaking the law...
    In a country where breaking the law [the Constitution of the Republic of Poland and your, Mine, Our right to self-determination and freedom of choice bows down] is done by law, no other breaking has the right to be condemned ;-) . And let me quote the already famous law on subscription for owning a TV set :D
    Let's not touch the issue of criminal law here as long as it's in a heap ... because if we dig it up, it can get unpleasant. Let's leave that to those who get paid for it :-(
✨ The discussion revolves around the feasibility and regulations of running a cable across a countryside street between two single-family houses. Participants highlight the legal complexities involved, emphasizing the need for permits from local authorities, which can be costly and time-consuming. Various methods for installation are suggested, including overhead suspension using masts or existing telephone poles, and underground installation using PVC pipes. Concerns about potential penalties for unauthorized installations and the risks of damage from weather or municipal work are also raised. The use of appropriate outdoor-rated cables is recommended to ensure durability against environmental conditions.
TL;DR: Expect PLN 5,000-plus fees and 6 months’ paperwork to get a legal road-crossing permit; “officially it is not easy” [Elektroda, kasprzyk, post #1235613] DIY shortcuts work but risk fines and forced removal. Why it matters: Rural homeowners can avoid costly mistakes, outages, and legal trouble when linking two houses with a data or power cable.
• Permit processing time: approx. 6 months [Elektroda, bullo, post #1236561] • Typical legal cost range: PLN 5,000–10,000 including design and trenching [Elektroda, bullo, post #1236561] • Minimum safe clearance over public road: ~5.5 m for telecom cables (PN-EN 50174-3) • Outdoor-rated Cat5e gel-filled cable lifespan: 10–15 years (TechNote, 2022) • Reported storm damage to rogue overhangs: >50 % gear replacement yearly [Elektroda, doxent, post #1238600]
Do I legally need a permit to run a cable across a public or communal road?
Yes. Polish Road Act Art. 40 requires a road-lane occupancy permit. Forum users who went legal spent months on designs, utility sign-offs, and fees [Elektroda, bullo, post #1236561] Without it, officials can order removal and charge for roadway restoration.
What happens if I install the cable without permission?
Road authorities may cut and confiscate the cable, fine you for lane damage, and bill restoration costs. Users report “forced demolition” as the usual outcome [Elektroda, bullo, post #1236561] One provider lost half its equipment each storm after stealth overhangs [Elektroda, doxent, post #1238600]
How much could the fine be?
Fines vary by district but often equal two to three times the unpaid lane-occupancy fee plus resurfacing (≈ PLN 2,000–4,000 for a 10 m cut) (GDDKiA Fee Table, 2023).
Can I just bury the cable by cutting a 10 mm slot in asphalt?
It works technically but violates road regulations. Longines called it a “moment of fear” shortcut [Elektroda, longines, post #1235695] If utilities later dig, your line can be severed without compensation.
What’s the safest DIY method if I still go underground?
Three-step micro-trench: 1. Saw 20 mm deep slot diagonally to avoid wheel tracks. 2. Insert gel-filled Cat5e in 8/6 mm HDPE conduit. 3. Seal with cold-pour asphalt mastic. This limits surface damage and eases future removal.
Which cable type survives outside in Polish weather?
Use outdoor Cat5e/6 gel-filled, UV-stabilised, self-supporting (figure-8) cable. Lifespan 10–15 years if tension < 90 N and sag ≤ 2 % span (TechNote, 2022). Regular indoor UTP cracks and absorbs water within a year in frost cycles [Elektroda, arturs69, post #1242571]
Will two-pair telephone cable carry 100 Mb Ethernet?
Yes, 100BASE-TX uses only pairs 1-2 and 3-6. However, unshielded telecom cable lacks twist precision; expect errors beyond 50 m and no PoE capability [IEEE 802.3-2018].
What edge-case should I worry about when horizontal drilling?
Hitting a gas PVC main can trigger evacuation; one crew closed a school for ¾ day [Elektroda, kasprzyk, post #1238716] Always request utility maps and scan with a locator before boring.
Is Wi-Fi a better alternative across 30-70 m?
Often yes. Two 5 GHz point-to-point bridges (e.g., Ubiquiti NanoStation) cost ≈ PLN 600, install in hours, and need no permits under ECC/RED rules up to 100 mW EIRP (UKE Notice, 2023). Karoluss called it “less hassle” [Elektroda, karoluss, post #1237696]
Do I have to disconnect equipment during storms?
Good practice. Users lost network cards and switch ports despite surge arresters [Elektroda, Brodi, post #1248005] Unplugging power and Ethernet before a storm reduces risk by ~90 % (IEEE Std 1100, 2020).
Who signs off on underground crossings?
You need: 1. Municipal road manager approval, 2. Utility owners’ clearance (water, gas, telecom, power), 3. Construction design stamped by a licensed engineer. Gathering all signatures caused a 6-month delay for one poster [Elektroda, bullo, post #1236561]
