Seeking Resistor Values for Damaged Silvercrest S16-UB13 Electric Blanket Power Supply
dudi777 54966 20
What are the values of the burned resistor(s) and thermal fuse in a Silvercrest S16-UB13 electric blanket power supply?
The burned resistor next to the thermal fuse is about 1 Ω: one poster read its color bands as brown-black-black-silver-gold, and later replacements/suggestions were 1R 0411 2W 5% or 1R00 1.5W 500V TK300 [#15420621][#15429654][#15437271] The thermal fuse in this unit was identified as a Tamura Japan part rated 102°C and 2A [#15404055] Another helpful check is the blanket load itself: it should be about 200 Ω with a diode inside, and if it measures much lower than that, the blanket may be shorted and keep damaging the controller [#16389537]
  • #1 12020060
    dudi777
    Rate: 21
    After unscrewing the power supply turned out to be damaged, the resistors are burned, I cannot read the correct values. I hope that someone has this blanket and will give me the values of these elements or post a photo of a working power supply. The blanket bought in LIDL, the symbols S16-UB13 on the housing of the power supply / driver, the integrated circuit of the board is HT66F30. The damaged resistor is R12 and the one next to it at the edge of the board, the burned place does not allow you to read the marking.
  • #2 12023295
    dzimi
    Help: 822
    Rate: 1285
    Post a photo of the power supply. The HT66F30 is a + 5V powered microcontroller.
  • #3 12380593
    Polaris
    Help: 5
    Rate: 69
    When measuring with the R12 meter, R3 are 960 k?, while the burned out is F1 - a fuse, I will not give you the value, because the element is in a thermo shirt and it is impossible to read it. Generally, this power supply is a crap, my third one has already died, just like that, it worked yesterday, today it does not want to turn on.
  • #4 12380594
    Polaris
    Help: 5
    Rate: 69
    For me, this time F2 burned out, but after replacing it, the resistors next to it heat up, so probably T1 and or T2 are also damaged. If you have F1, it is possible that there is a problem with the blanket itself, not with the control and after the replacement it will all burn anyway.
  • #5 12498485
    123cvbnm
    Rate: 10
    Hello!
    Do you can tell me the value of thermal fuse F2?
    Do you can tell me the value of a resistor in addition thermal fuse F2?
    My Silvercrest S16-UB13 bought in Lidl Cro these parts are burned out and do not see the marks.
    Thanks in advance!
    P.S. Burned parts are indicated in the picture attached
  • #6 12552389
    dudi777
    Rate: 21
    Thank you for your help. Blanket dumped garbage. The posts I figured it was junk and I wish the west. ;-)
  • #7 15380741
    JirkaDeLucina
    Rate: 33
    Hi, I have the same problem. Please can you tell me, what resistor F2 should I buy? Thank you very much.
  • #8 15404055
    pracktiger
    Rate: 30
    Look here. It is a new one.
    I find nowhere to buy the fuse. It is from Tamura Japan. 102°C 2A.
  • #9 15404344
    JirkaDeLucina
    Rate: 33
    Ohhh...super :) Thank you very very much :) Czech e-shops have these fuses, but only 1A (http://www.gme.cz/radialni-tepelna-pojistka-nec-tsm102r-p530-050), are you sure it is 2A? There are only 115°C/2A which can I buy (http://www.gme.cz/radialni-tepelna-pojistka-tsm115r-p530-052)? Thank you very much.
  • #10 15405439
    pracktiger
    Rate: 30
    I have found this flyer in www.
    And I have unsoldered and photographed my fuse.
    If you find a shop of this temperature fuse sold, please post it here.
    Flyer found on google: eska-fuses.de/fileadmin/produkte/Temperature_2012.pdf
    Seeking Resistor Values for Damaged Silvercrest S16-UB13 Electric Blanket Power Supply Seeking Resistor Values for Damaged Silvercrest S16-UB13 Electric Blanket Power Supply
    • Temperature_2012.pdf (4.17 MB) You must be logged in to download this attachment.
  • #12 15405744
    pracktiger
    Rate: 30
    This type I have found. But how do you want the heating resistors position? And where is the difference between T 2F and A 2-F? I am not a specialist and I do not want to burn. :not:
  • #13 15406015
    JirkaDeLucina
    Rate: 33
    Can you please add links to T2F and A2-F? The position is a question. I think there is a lot of space inside, it should pass there.
  • #14 15416054
    pracktiger
    Rate: 30
    T2F is the original and A2-F have you found. Where is the different between T and A ?
  • #15 15417693
    JirkaDeLucina
    Rate: 33
    I was looking for the same parameters as you wrote there (102°C, 2A). I have found only radial type. Original is axial type. But both are thermal fuse. I think it should work same way. But I am thinking about use the NEC TSM102R (http://www.gme.cz/radialni-tepelna-pojistka-nec-tsm102r-p530-050) - but paremeters are: 102°C, 1A
    Please can I ask you for a favour? Can you please lock at F1, if both fuses are the same (F1 and F2)?
    Whole time we are talking about F2, but my problem is F1 (as shown on the picture).
  • #16 15420621
    pracktiger
    Rate: 30
    brown, black, black, silver, gold
  • #17 15429654
    JirkaDeLucina
    Rate: 33
    The resistor should be: 1R 0411 2W 5% (http://www.gme.cz/rmo-1r-0411-2w-5-p114-108). Thank you very much ;)
  • #18 15433132
    pracktiger
    Rate: 30
    Is the resistance is not too small for 2W?
  • #19 15437271
    JirkaDeLucina
    Rate: 33
    I sent picture of the resistor to another shop and they recommended the almost same type: 1R00; 1,5W; 500V; TK300(http://www.ges.cz/cz/2w-metall-1r00-GES05301645.html).
  • #20 15482681
    JirkaDeLucina
    Rate: 33
    The resistor did not solve my problem. Still not working.
    Do anyone know what is output power (what is voltage input into the electric blanket)? Please can you measure Volts, Watts and mA for each level for me?
  • #21 16389537
    t782
    Rate: 12
    Check the load of the blanket - it should be 200 ohms + a diode is built in inside, if it's less than 50 ohms like mine, then it's hot-short in the garbage. 4.7 k? resistors
    Check the load of the blanket - it should be 200 Ohm + inside the diode is built-in, if less like I have 50 Ohms, then the garbage blanket is short. Resistors of 4.7 k?
The discussion revolves around the repair of a damaged power supply for the Silvercrest S16-UB13 electric blanket, purchased from Lidl. The user seeks assistance in identifying the resistor values for burned components, specifically R12 and a nearby resistor, as well as the thermal fuse F2. Various users share their experiences with similar issues, discussing the potential for other components like T1, T2, and F1 to be damaged. Recommendations for resistor specifications include 1R 0411 2W 5% and 1R00; 1.5W; 500V; TK300. Users also inquire about the output power and resistance of the blanket, noting that a load of 200 ohms is expected. The conversation highlights the challenges in sourcing specific thermal fuses and resistors, with links to potential suppliers provided.
