Re: Dishwasher Electrolux ESI 5540LOX - burned R67 and LNK362GN resistor
szumbu 7107 2
  • Request for R67 resistor type and replacement parts
    #1 16766578
    szumbu
    My dishwasher broke, I dismantled the front and it turned out that the current was reaching the control panel, I dismantled the panel and it turned out that the R67 resistor was blown. From descriptions in other topics, I read that this is a fairly common failure caused by damage to the LNK362GN.
    I have the following question - what kind of resistor is it and where can I order it?
    I am also looking for the other two elements marked in the photo.
    I know it's not very professional - I visited all the points related to electronics in my area (Starogard Gd.) And no one wanted to help.
    Below photos:
    Re: Dishwasher Electrolux ESI 5540LOX - burned R67 and LNK362GN resistor Re: Dishwasher Electrolux ESI 5540LOX - burned R67 and LNK362GN resistor Re: Dishwasher Electrolux ESI 5540LOX - burned R67 and LNK362GN resistor
  • #2 16766845
    h jaworski
    Home appliances specialist
    Help: 466
    Rate: 717
    The resistance is usually around 22 ohms and 2w is a hard fuse resistance to get, I bought in north pl. The element in the picture is a choke, for the transition it is good, it has a few ohms of resistance.
    If you get a bad resistance, it is possible that the resistance will be damaged frequently.
  • #3 16766967
    szumbu
    Can I use such a resistor - R33 2W?
