Extending UPC Router Cable: Guide on Cable Types, Connectors, and DIY Extension Solutions
mtaton 16584 7
  • #1 12087442
    mtaton
    Help: 8
    Rate: 42
    I would like to extend the cable from Router from UPC, the computer has been moved to the 2nd room and I would also like to move the router but the cable is too short. It is exactly the one connecting the Router with the plug in the wall. I asked about the cost of the service where the fitter does not have to do anything, it was enough to leave me a cable because you do not need to drill or anything. I was told PLN 70. And now a question for you, if I would like to buy a cable, what is it supposed to be? And if I get the plugs in a store, I mean female and male to connect them into 1.
    Regards
  • #2 12087471
    wojtek2803
    Level 37  
    Help: 337
    Rate: 144
    It would not be easier to connect this modem to the computer using a "twisted pair". Modem at this point, what is it and connect to the computer with a cable?
  • #3 12087499
    mtaton
    Help: 8
    Rate: 42
    I want the Router to be next to the PC due to the connection of 2 laptops and the console to it, and after WiFi, the console has problems with online games, so it also wants it to be close to the PC because the console is connected to the monitor.
    andrefff
    Level 36  
    Help: 321
    Rate: 807
    Link
    Link
    Link
    That's all you need.
    And the best thing to do is to buy a new cable for the whole thing, in this case you only need two Fs, because with UPC they are probably crimped.
  • #5 12087599
    mtaton
    Help: 8
    Rate: 42
    This is what I ment :) Thank you very much for your answer.
  • #6 12093091
  • #7 12094751
    mbo
    Help: 2333
    Rate: 845
    With a few meters, the parameters will not change.
    In fact, the crimped F's are better, but when put on correctly, they will also do their job.
    50 or 70 PLN for a piece of cable is quite a rip-off - a meter of good cable in detail costs ~ PLN 2, plugs less than PLN 1. It is easy to count how much the operator earns on such a service.
  • #8 12094759
The discussion revolves around extending a UPC router cable to accommodate a computer and gaming console relocation. Users suggest using a twisted pair cable for direct connections, while others recommend purchasing a new cable with crimped connectors for better performance. The cost of professional installation is debated, with some users highlighting the high markup on cables and connectors. It is emphasized that using quality connectors and ensuring proper installation is crucial to avoid signal loss and installation issues. The consensus leans towards DIY solutions with careful consideration of cable quality and installation techniques.
