Dividing UPC TV/Modem Signal in Apartment: 3-room Setup, Teletechnical Box, Variant 1 vs Variant 2
grzegorz1982 5124 8
  • #1 16638661
    grzegorz1982
    Rate: 9
    I have a question for you, how to divide the signal into 3 rooms (TV / MODEM) + modem (teletechnical box), the current installation is such that the signal from the teletechnical box goes only to one room where a decoder and modem are connected. Which variant will be better?
    variant 1 Dividing UPC TV/Modem Signal in Apartment: 3-room Setup, Teletechnical Box, Variant 1 vs Variant 2
    variant 2 Dividing UPC TV/Modem Signal in Apartment: 3-room Setup, Teletechnical Box, Variant 1 vs Variant 2
  • #2 16640224
    Pablo1964
    Moderator
    Help: 507
    Rate: 641
    I suggest consulting UPC. They can suggest interesting solutions.
  • #3 16640295
  • #4 16640359
    grzegorz1982
    Rate: 9
    What I proposed, I am able to do myself and if you have a more interesting solution, ask for suggestions. At this stage, he does not want to contact UPC unless the signal is too weak.
  • #5 16640994
    Pablo1964
    Moderator
    Help: 507
    Rate: 641
    According to the contract, the entire installation is owned by UPC, so it is not worth going to the orchestra ...
  • #6 16641298
    grzegorz1982
    Rate: 9
    From what I read, the UPC (or other operator's) installation ends at the teletechnical box.
    Secondly, when contacting UPC, I have to pay PLN 50 for making an additional socket. If it turns out that one of the variants drawn by me is good and the technician from UPC will do the same, why should I pay? Contact with UPC is a last resort (so far I have put all the cables myself, the technician who came only connected the signal in the UPC box). If it is only a matter of other distributors, please specify which ones.
    I am still not sure which option will be better?
  • #7 16648111
  • #8 16648295
    grzegorz1982
    Rate: 9
    Before trying to modernize the modem and the signal, I have + 10db DS and 42db US maximum values. The next element is a 2xF data socket and there it drops by about 3-4dB. So I can still use an additional splitter so that the signal is within the acceptable range (from what I read and what I know is -8 to + 10dB).
  • #9 16661995
    grzegorz1982
    Rate: 9
    Due to the change in furniture, I have another problem because the socket in the room is not on the wall I would need, but from the other room I can pass the signal through the wall (partition wall) but I do not know how through sockets behave (attenuation at the IN-OUT output, attenuation on output to the receiver) from what I saw, this socket has an attenuation of about 10dB as with the signal that may be too weak?
    Can UPC do such modernization or is it better to do it by yourself? How to buy it yourself? Does UPC use pass-through sockets at all?
    Or maybe you have another idea?
    In the photo below, I marked in red where the new socket should be.
✨ The discussion revolves around the challenge of dividing a UPC signal for TV and modem use across three rooms in an apartment, utilizing a teletechnical box. The user is considering two installation variants but seeks advice on which would be more effective. Responses suggest consulting UPC for solutions, but the user prefers to avoid this unless necessary due to potential costs. The conversation highlights the importance of understanding signal strength and attenuation, with discussions on the implications of modifying the installation and the potential need for additional splitters. Concerns about signal quality and the feasibility of DIY solutions versus professional assistance from UPC are also raised.
