Solar Pool Cover Comparison: PLN 30/sqm Foil vs. Bubble Foil - Efficiency, Cost, & Best Uses
andrz6 70431 18
How can I compare a solar pool cover with ordinary bubble foil, and is it meant to absorb sunlight or mainly keep the pool warm at night?
A solar pool cover mainly works as a floating nighttime cover that cuts evaporation and heat loss, so it is less about absorbing sunlight and more about keeping the water warm after dark, and the PLN 30/sqm version is usually not worth much more than ordinary bubble foil [#12183793][#12184126] The water cools by evaporation, infrared radiation, air exchange, and conduction, so the cover should sit close to the water and not leave a large air gap [#12184126] Bubble structure matters: large, continuous bubbles are preferred, while small packaging-style bubbles let too much heat escape [#12182030][#12184126] A metallized/aluminum layer can help reflect infrared back toward the water, but a screen facing the water does not change much and may even worsen night heat loss [#12183793][#12184126] Several replies suggest that many "special" foils are just LDPE-based bubble film with additives or a coating, so the exact construction and bubble arrangement matter more than the marketing name [#12276358][#12277589] In practice, the biggest gain comes from covering the surface; insulating the pool bottom and sides is usually not worth it [#12253690]
  • #1 12180351
    andrz6
    Rate: 134
    The bathing season is about to start so I decided to create a thread about solar foils to cover the pool.
    Do any of you use such foil?
    With what effects?
    I will add that such foil is quite expensive.
    How does solar foil for the price of about PLN 30 / sqm compare to ordinary bubble foil?
    Is the film's job to absorb sunlight or just keep the water warm at night?
    Thanks for all the answers.
  • #2 12182030
    bestboy21
    Level 40  
    Help: 566
    Rate: 782
    Store quote
    "Made of bubble wrap, the sun heats the water in the pool through the cover, and provides thermal insulation on a cold night."
    You will get a similar effect if you stretch an ordinary foil over the water surface, but for it to work, it would have to be tight (around), the construction of the solar foil is such that it works on the water, the sun heats the air in bubbles (as in the inspection on the plot) and the heat is given off is into the water. If you seal the pool with a normal foil around (so that it does not touch the water surface), it will be the same as solar foil only in the macro scale, not micro ;)
    Much less comfortable, but the effect is the same.
    ps Normal bubble wrap has too small bubbles and a lot of heat will escape through it (better this ala inspekt in my opinion).
  • #3 12182248
    andrz6
    Rate: 134
    A'la inspekt is out of the question, the pool is concrete with dimensions 8 x 4. I know from practice that placing anything over the water is almost impossible. There are also bubble foils with thick meshes, about 2 cm in diameter. Basically whether this solar film is made of some special material that absorbs rays (something like an absorber in solar systems) or is it some ordinary fake and it is made like ordinary bubble wrap for packaging.
  • #4 12182305
    bestboy21
    Level 40  
    Help: 566
    Rate: 782
    It works on the principle of "floating inspekcików" there is no space technology there ... and the absorber does not differ much from the inspekciku, mainly by its name ;)
    The NRC foil is already more complicated ...
  • #5 12183739
    andrz6
    Rate: 134
    Let's summarize:
    Solar foil for PLN 30 / sqm is the same as ordinary bubble foil for PLN 30 per roll of 50m?
    I also came across construction insulation foil. it is a bubble wrap with a layer of aluminum foil acting as a screen. What to think about it, if you spread the screen towards the water surface?
  • #6 12183793
    bestboy21
    Level 40  
    Help: 566
    Rate: 782
    There will be some performance difference but definitely not worth the price and that's it.
    The foil with a screen towards the water makes no sense, the sun will heat the air in the bubble, then it has to give the heat back to the water, and this screen will not change anything else, it can even accelerate the heat transfer at night.
  • #7 12183866
    andrz6
    Rate: 134
    This is not about absorbing rays through the foil, because after reading your posts I already managed to determine it. The best ray absorber is probably water itself. It is now only a practical cover for the pool for the night.
    a) specialized solar foil
    b) regular bubble wrap
    c) bubble wrap with a layer of shielding aluminum foil
    d) other (?)
  • #8 12183940
    bestboy21
    Level 40  
    Help: 566
    Rate: 782
    andrz6 wrote:
    It's not about absorbing rays through the foil anymore, because after reading your posts I have already determined that. The best ray absorber is probably water itself. Now it is only a practical cover for the pool for the night.
    d) other (?)
    e) polystyrene cut to measure (or in several pieces)
    f) a bag of pinkpong balls ;)
    Either cut off the water from the air or reduce this contact to a minimum, the second option is easier and more convenient.
    If you bought these black pinkpongs and poured them (as much as you can), you will have an almost solar pool :P
  • #9 12184015
    andrz6
    Rate: 134
    Let's not be serious ... A practical way to isolate the water table.
  • #10 12184022
    bestboy21
    Level 40  
    Help: 566
    Rate: 782
    You can insulate about 85-90% of the mirror surface with pinkpongs, and when they are black, they will absorb much more energy than water. There is nothing funny here.
    You also don't have to roll up and unfold every now and then.
  • #11 12184126
    _jta_
    Electronics specialist
    Help: 3212
    Rate: 4260
    The pool water cools down as a result of: (1) evaporation, (2) thermal radiation,
    (3) air heat transfer and (4) heat conduction through the housing.
    * To effectively reduce (1) the pool should be covered with foil - it does not have to touch each other
    with water, but there should not be a large space between the water and the foil.
    * To effectively reduce (2) an infrared reflective film is needed
    - it is possible for metallized foil. On top of that, the water is a bit malicious:
    It absorbs little visible light, but emits infrared very well;
    the absorption of visible light can improve the dark bottom of the pool.
    * To effectively reduce (3) airflow and contact must be restricted
    thermal air above the water with the surroundings - maybe bubble wrap, but not like that,
    which has bubbles on part of its surface, and one which has bubbles everywhere; they do not have to
    be very small, e.g. several cm in size; if a significant part
    the surface of the foil will be without bubbles, the air will be released on this part
    heat through the foil to the outside and fall to collect another portion from the water.
    * A (4) does not depend on the foil covering the pool, but on the insulation made when it was
    under construction - it is rather difficult to improve anything in this matter.
  • #12 12184158
    saskia
    Help: 174
    Rate: 1087
    jta, correct yourself. :-)
    Add a little hush to your statements. you should add that the foil should reflect the thermal radiation of the water, i.e. the foil from the water side.
    The beams also work both ways, so the direction of heat transfer would be useful. :-)
  • #14 12253690
    technikabasenowa
    Help: 138
    Rate: 445
    Insulating the bottom and sides is not necessary and not profitable (in practice)
    The greatest losses are through the surface - covering at night and with an unused pool reduces the heat loss of water and water treatment chemicals.
    I have already seen many inventions from various types of foil, usually I end up with the purchase of a normal solar foil - they can last up to 10 years
  • #15 12275213
    andrz6
    Rate: 134
    Are you suggesting that solar foil, which costs about PLN 30 / sqm, keeps heat better than insulation bubble foil? If so, how does it work? Not that I am clinging, but I want to know what this foil is better in and how it works.
  • #16 12275831
    technikabasenowa
    Help: 138
    Rate: 445
    One piece of advice for you has cost me a warning :D (as you saw, they went to the trash with a comment so that I would not water down - a substantive argument)
    Tomorrow, when I am at work, I will send you the data :D
  • Questions about solar foil absorption and nighttime insulation
    #17 12275922
    andrz6
    Rate: 134
    After all, it is about a discussion and not about launching a topic that you did not set up yourself, which also irritates me. I just want to know if something costs a lot of money that's what I need before I spend it. That is why there was a question about transformers and now it is about foil. What is solar foil in it that ordinary bubble foil does not? Is it made of some special ray-absorbing foil? What is the fact that it insulates the water table better at night?
  • #18 12276358
    telecaster1951
    Help: 829
    Rate: 818
    It is blue, so it absorbs the complementary color. It is not made of some kind of cosmic material. Ordinary LDPE with additives.
  • #19 12277589
    _jta_
    Help: 3212
    Rate: 4260
    It may be that one such foil is plain LDPE, and the other is coated to keep the heat - you need to ask the seller (and check if it is credible). Besides, the arrangement of the bubbles is important.
The discussion centers around the comparison of solar pool covers, specifically a solar foil priced at PLN 30/sqm versus ordinary bubble foil. Participants share insights on the effectiveness of these covers in heating pool water and retaining warmth overnight. It is noted that while both types of foil can provide thermal insulation, the solar foil is designed to enhance heat retention through its construction, which allows for better air heating within the bubbles. The conversation also touches on alternative materials, such as aluminum-coated bubble wrap, and the importance of minimizing air contact with the water to reduce heat loss. Ultimately, the consensus suggests that while there may be some performance differences, the cost of specialized solar foil may not justify the benefits over standard bubble foil.
