How to calculate the voltage with series and parallel connection on panels?
huligan0 30264 5
  • #1 12304630
    huligan0
    Hello, I have a question about DC voltage. Here I have a specific example, namely I have 2 photovoltaic panels that are positioned differently to the sun, one panel gives 80 volts and the other 90 volts. If I connect these panels in series and parallel, what voltage will I get?
  • #3 12304744
    huligan0
    nice, but these are old posts, there are answers that are false or different from the topic and no particulars.
  • #4 12305483
    prociomen007
    Rate: 30
    The matter is basically simpler than the wire ;-P. Basic physical laws provide answers to this. The series connection comes down to adding the voltage. So e.g.
    20V + 50V + 15V = 85V at the output
    in parallel, this connection is essential for CURRENT! The voltage will be as high as the highest applied, while the current efficiency will increase.
  • #5 12305508
    wieswas
    Help: 240
    Rate: 400
    Assuming that they are two identical panels, they will deliver their maximum power when both are directed exactly towards the sun.
    SERIAL CONNECTION:
    If they have different orientation directions, when connecting in series, the voltage will be 90V + 80V = 170V instead of 180V in the same direction.
    Also, the short-circuit current (maximum) will be smaller than if they were equally directed at the sun. The internal resistance of this underexposed panel will also limit the current of that "better" panel.
    The power you can consume when loading with optimal resistance will be less due to the lower voltage and lower current.
    The only advantage of the unequal orientation of both panels (when they are stationary) is the power delivered more evenly. For example, in the morning, more power is given by the eastern panel, at noon they give the same power (though not the maximum) and in the afternoon more power is given by the west panel.
    PARALLEL CONNECTION:
    Panels with different voltages should not be connected in parallel. (like rechargeable batteries). If it really depends on it, it is only through diodes preventing equalizing currents between the panels. The power possible in such a system will never reach the power of two panels equally directed at the sun. The only positive thing is that the power is more evenly distributed throughout the day.
    The optimal design is to set both panels to the same direction and rotate to follow the sun, or to set using a programmer that remembers the current month, day and time and regardless of whether it is a sunny or cloudy day, positioning both panels towards the predicted position of the sun.
  • #6 12470698
    huligan0
    thanks for the answer, everything explained.
