Motorized Mower: How to Maintain V-Belt Tension for Rear Wheel Drive Clutch with Small Spring
zgrzezly 156993 15
How do I hook up the small spring so it keeps the rear-wheel-drive V-belt tensioned on my mower clutch?
Hook the spring between the mower housing and the drive/clutch lever or drive gear so it pulls the clutch and stretches the belt; on these drives the housing often has a small or rectangular hole for that spring end [#12367396][#12367402][#12368452] The exact mounting point can vary by mower model, but one similar drive used a strong spring about 3 cm long attached at the top through a rectangular hole in the housing [#17939844] If the spring is missing or no longer fits, replacing it with a new one of similar size may be necessary [#17939920]
  • #1 12366727
    zgrzezly
    Rate: 21
    in the mower I have a loose belt for the rear wheel drive clutch. I have no idea how to keep him stretched. A small, strong spring fell out from under the cover, but nowhere can I see a place where it could be hooked and tightened.
    Enclosed is a view of a small wheel on the axis of the motor and the clutch with the take-up wheel. There are no other "burrs" apart from the aforementioned spring.
    Motorized Mower: How to Maintain V-Belt Tension for Rear Wheel Drive Clutch with Small Spring Motorized Mower: How to Maintain V-Belt Tension for Rear Wheel Drive Clutch with Small Spring
  • #3 12367402
    rou123
    Help: 14
    Rate: 91
    Hello, I marked you in the photo with a red color where you should attach this spring. One half goes into the housing and the other half goes into the red color.
  • #4 12368411
    zgrzezly
    Rate: 21
    Logically, it should be as you wrote, the spring pulling the clutch "up" in the indicated place will stretch the belt - but in the housing there is no attachment point for the other end of the spring, no eyelets etc. Maybe some element should be there ??
  • #5 12368427
    rou123
    Help: 14
    Rate: 91
    And what does the spring that fell out look like?
  • #6 12368452
  • #7 12368635
    zgrzezly
    Rate: 21
    there is no fastening in the housing. I did as in the photo below. I wonder if this was the original mount. The belt is kind of tight.
  • #8 12368646
  • #9 17939653
    xaver_compz
    Rate: 37
    What exactly is a spring? What is its dimension? I lost one, unfortunately. :(
  • #10 17939844
    LENIWIEC_PL
    Help: 119
    Rate: 322
    I have the same drive on a mower with a Tucumesha engine. The spring, from what I remember, is about 3 cm long and as strong as possible (1 cm thick), but do not think that you will find one because it depends on where it is attached. The drives on many mowers are the same, but the spring mounts are different. My friend has the same spring mount as shown in the photo and I already have a longer spring and it is attached at the top through a rectangular hole in the housing.
  • #11 17939874
    xaver_compz
    Rate: 37
    Ok, then I will clarify, it's about the Viking 448TX.
  • #12 17939907
    Boryc2014
    Help: 21
    Rate: 90
    Hello. And try to remove the old one and buy a slightly smaller one, but a new one, so that it is not taken out and then see what will happen. And on this belt, what you have, the drive does not work well, i.e. it slips ????
  • #13 17939920
    xaver_compz
    Rate: 37
    Belt loose, spring in the grass, not to be found. You need a new one.
  • #14 17942229
    Mteusz
    Rate: 8
    and for me everything is in place, only I have a loose rope from the drive, and the drive is working all the time and it cannot be disconnected with the lever while mowing.
    All in all, you can mow and the drive works all the time, but in the long run it is tiring, especially when you have to turn, etc.
    I thought that the line broke or fell, but everything is fine only with this metal box, where the line is all loose ...
    I got into it, and I still don't know
    Thanks in advance for the info,
    kisses
    mteusz
  • #15 17969654
    piter69
    Rate: 20
    Mteusz, if you have a drive as shown in the first photo of the author of the topic, then under the gear drive wheel there is a lever to which the drive engagement rod is connected. On the other side of this lever, a spring is engaged, which is to switch off the drive after the lever is released. This is the drive in the Honda Iza. In my case, the spring broke and the lever did not return and the drive was working all the time. If you have a similar drive design, this could be your fault.
  • #16 18104761
    Norbert Chrobot11
    Rate: 83
    Maybe someone here will help me. I have a problem with the drive in the Makita PLM 4618 mower. The question is how should they be, or how should the spring / springs be installed or installed?
    Thank you.
    Goodbye.
The discussion revolves around maintaining the V-belt tension for a rear wheel drive clutch on a motorized mower. A user reported a loose belt and a small spring that had fallen out, seeking guidance on how to reattach it. Responses indicated that the spring should connect one end to the mower housing and the other to the drive gear to maintain belt tension. However, the user noted a lack of attachment points in the housing. Various users shared insights about the spring's dimensions and attachment methods, with some mentioning specific mower models like the Viking 448TX and a Tucumesha engine. Additional issues related to drive engagement and spring functionality were also discussed.
