How to trim protruding wall boxes – what tool to cut them flush?
nottin 31656 12
How can I trim a protruding wall electrical box flush without damaging the painted wall?
If the box plastic is soft enough, a sharp assembly knife, used with a hammer or pliers, is the simplest way to cut it flush without marking the wall [#12373298][#12376106][#12375804] If you want a powered tool, people suggested a mini grinder or a small sanding disc/mini shield on a screwdriver, and one reply mentioned cone-arranged sandpaper as the shaped attachment you were looking for [#12375804][#12373321] To avoid scratching already painted walls, one suggestion was to make a sheet mask with a hole matching the box diameter and place it over the wall before grinding [#12374552] Several replies also said the better fix is to set the box deeper or re-embed it instead of trimming it, using a template or a shallower box with longer screws if needed [#12373706][#12376154][#12378305]
  • #1 12373244
    nottin
    Welcome gentlemen,
    I deal with electrical installation mainly in single-family houses and for some time I have been struggling with a certain problem. Namely, for more or less a year I started to put boxes under sockets/switches on plaster (after the plasterers placed the boxes crookedly and it was impossible to assemble multiple sockets horizontally), which eliminated the problem described in parentheses, but sometimes it happens that the plaster goes extremely little and the can sticks out.
    So far, I cut such cans with an angle grinder (flat surface of the disc), but it happens that I "overshoot" and there is a trace of the disc on the wall around the can. If I do it before painting, it can still be plastered, but after painting it is already a problem:-/ .
    I was thinking about something in the shape of a cone, preferably with a drill attachment, but unfortunately I can't find anything.
    Maybe you guys have some proven patent for trimming protruding cans??
    Regards.
  • #2 12373298
    Reprint
    Help: 9
    Rate: 66
    If the plastic is not hard, you can try with an assembly knife:
  • #3 12373306
    technikabasenowa
    Help: 138
    Rate: 445
    Aku and a good milling cutter - although there is a bit of fun with it :cry:
  • #4 12373321
    vodiczka
    Help: 1185
    Rate: 4311
    A wallpaper knife or a lancet, more laborious than a grinder, but you won't damage anything.
    There is sandpaper - leaves arranged in a cone.
  • #5 12373706
    mar_cik
    Electrician specialist
    Help: 101
    Rate: 156
    nottin wrote:
    Maybe you guys have some proven patent for trimming protruding cans??.
    g embed deeper, and those that come out too shallow, chisel out and embed again. Patent checked. :spoko:
    P.S WITH I forgot the letters. :D
  • #7 12374552
    leszek-56
    Help: 22
    Rate: 127
    The oscillating jigsaw probably won't be able to handle it, I'm afraid that it can tear the can out of the wall. I, however, propose to make such a sheet mask with a hole with the diameter of the can and apply it to the wall before grinding.
  • #8 12375738
    remik_l
    Help: 144
    Rate: 325
    Wkuj the boxes almost flush with the wall, as they give more plaster, then you mount longer screws to the accessories.
  • #9 12375804
    Joker.
    Help: 140
    Rate: 130
    This knife as above and hitting it with a hammer or pliers. Otherwise you can get sweaty :)
    Maybe a mini grinder will also be good, because you can trim from the inside of the can.
    Or just such a "mini shield" put on a screwdriver. They come in sanding kits.
  • #10 12376106
    fighter
    Help: 20
    Rate: 56
    Buddy nottin and where you learned the profession, they didn't teach you that???.
    A good assembly knife, a hammer and the case, but not a knife for wallpapers and plasterboard hehe
  • #11 12376154
  • #12 12376160
    vodiczka
    Help: 1185
    Rate: 4311
    fighter wrote:
    just not a wallpaper knife
    I placed two cans in March and the wallpaper knife did the job perfectly (hehe) professionally, maybe it doesn't pay off, but I had nothing else at hand.
  • #13 12378305
    INTOUCH
    Level 30  
    Help: 99
    Rate: 199
    I'm wondering why cut the protruding cans, since there will be profanity during the installation of sockets and lighting connectors.
    Mount the box as it should be without shortening, or buy a shallower one if possible and it will not prevent the installation of the above-mentioned equipment.
    Boxes on an unplastered wall are always exposed 0.5-1 cm shallower due to the plaster.
    If the wall is plastered, it is necessary to forge or drill a hole deeper so that the box fits.
The discussion revolves around the challenge of trimming protruding electrical boxes (cans) installed on plastered walls. Various methods and tools are suggested for cutting these cans without damaging the surrounding wall. Recommendations include using an assembly knife, wallpaper knife, or a milling cutter for precision. Some participants suggest using sandpaper arranged in a cone shape or a mini grinder for internal trimming. Others propose embedding the boxes deeper or using templates for proper installation to avoid protrusion. Concerns are raised about using oscillating jigsaws, as they may damage the cans. Overall, the focus is on finding effective and less damaging techniques for managing protruding electrical boxes.
