How to drill a 60 mm box hole in a 1970s load-bearing wall?
dzajdol 48330 14
How can I drill a 60 mm hole for an electrical box in a reinforced load-bearing concrete wall?
Use a diamond crown/hole saw for reinforced concrete, drill it without impact, and start with a small pilot hole (for example 8 mm) to guide the crown [#8155658] If you want to use an impact crown instead, the drill needs a strong hammer action — about 2 J and 700 W, preferably an SDS-plus machine [#8155723][#8155797] A 65–68 mm crown was suggested for this kind of box hole, and one reply noted that a Bosch 65 mm impact crown cost about 270 PLN [#8155723][#8155797] If the wall has a hollow block or void, drilling there is much easier; otherwise, drill a ring of small holes around the outline and then chisel/forge out the middle [#8155701][#8155723]
  • #1 8155535
    dzajdol
    I have a problem because I bought a drill bit for cans. wrote to concrete, size 60 cm, so it suited me.
    In one bearing wall I drilled maybe 5mm for 30 minutes, and in the other it went smooth (there was a hollow block inserted, when I knocked with a hammer it fell out on the other side; P) - it went smooth but the blade (teeth) went down to 0. The drill was bosch -and.
    You have some effective way to drill a hole in something like this.
    I have an idea to drill a few or a dozen holes around and forge it, but it will be time-consuming
  • #2 8155613
    pavulon
    Help: 34
    Rate: 73
    No wonder it didn't go when it is 60 cm.
    Seriously, what material do you want to drill? The load-bearing wall is not a material, apart from the fact that you should not disturb the load-bearing wall structure.
    Did you buy a drill or a lace? for dry / wet drilling, with / without impact ??
  • #3 8155654
    marian_em
    Help: 60
    Rate: 182
    Did you accidentally buy a lace that looks like a "coiled saw"? If so, it is not surprising that he does not want to go into concrete, there are special bits for concrete, besides, for drilling in a large slab, you also need a piece of a good drill ;)
  • Diamond core bit cuts reinforced concrete without impact
    #4 8155658
    Miwhoo
    Electric installations specialist
    Help: 128
    Rate: 316
    Lace with a diamond blade is the best for reinforced concrete, it will even cut the reinforcement, but you have to drill it without impact so as not to damage it. For easier guidance, you can first drill the "pilot" with the fi8 drill, then the guide drill into the hole and a little patience :)
    Diamond crown:
    Widia is good for drilling with an impact, but you need a drill with a good impact [electropneumatic or other, but not based on gears flying in a row, as in cheap drills from a market]. For example, the makita HR2470 is suitable.
    Vidia lace:
    Did you drive a Widia or a diamond one? Or maybe one for wood? :)
    Other than those from the photo, they are not suitable for concrete.
  • Finding slab voids with pilot holes before enlarging
    #5 8155701
    cepilek
    Help: 62
    Rate: 194
    I will just add that a large plate, every 17 cm, has empty spaces depending on the construction, of course, and drilling in this place is more effective, because any hole, once you get it, you can enlarge it with any pneumatic hammer, you just have to think a little, sometimes you have to break a little plaster and soak it properly, light a cigarette and when you finish it, in a place where it dries faster or where the concrete is lighter, there are voids in the large slab ... It requires experience, and if it is not enough, drill holes every 5 cm with a diameter of 10 mm until you come across a void and in this place only with the above-mentioned lace .... You will save yourself a lot of time and nerves ...
  • #6 8155706
    dzajdol
    more like a widiowa, it had more teeth, it looked like a ball in a circle.
    What brand of lace - how much do they cost and can you buy them in castorama, leroy or practical, because I just bought in a practical, I wrote to concrete and Bosch, I thought that I would be fine: p I was obviously wrong
  • #7 8155719
    Arturo2005
    Help: 149
    Rate: 485
    So?
  • #8 8155723
    zdzisiek1979
    Help: 563
    Rate: 1256
    Diamond crown fi. 65mm 68mm either, but it's a dirty job an angle grinder and diamond blade and cutter.
    As an impact crown, the drill should have at least 2J and 700W of power to prevent the machine from falling.
    Or you draw the outline of the can and drill holes and chisel and forge until you make it. :D
  • #9 8155741
    dzajdol
    Arturo2005 wrote:
    Such?
    Yes - yes :)
  • #10 8155742
    Miwhoo
    Help: 128
    Rate: 316
    Well, buddy, you massacred a wood ball on a concrete wall ... it is suitable for plasterboard, but not for reinforced concrete :)
    Buy a lace for a specific purpose and don't let the wood drill bit stick in a second time :)
  • #11 8155757
    zdzisiek1979
    Help: 563
    Rate: 1256
    In 30 minutes, instead of 5mm, you would do it, definitely 2-3 holes for the cans by drilling holes and forging by hand.
  • #12 8155759
    Arturo2005
    Help: 149
    Rate: 485
    And it said concrete? Probably fresh ;)
  • #13 8155778
    Miwhoo
    Help: 128
    Rate: 316
    To be precise, let me just say that the one from the Arturo2005 photo is for metal :)
  • #14 8155797
    zdzisiek1979
    Help: 563
    Rate: 1256
    The Bosch impact crown 65mm cost me PLN 270, but it's for SDS plus. And such a bimetallic one can be used for aerated concrete, although it is a pity to waste money.
    There are certainly diamond deders in supermarkets, but you need to buy a drill handle and a lace, it will be around PLN 150, they are impact-free with probably four diamond plates.
  • #15 8155813
    dzajdol
    Well, I will have to drill a few holes around with a small drill and a hammer and chisel :) then some plaster and it will be.
    Thanks for the help.
    I especially need advice with water to see where it will be easier :)
The discussion revolves around the challenges of drilling a hole for a can in a load-bearing wall made of concrete. The user initially attempted to use a 60 cm drill bit designed for concrete but faced difficulties, achieving only 5mm of progress in 30 minutes. Responses suggest that the user may have used an inappropriate drill bit, possibly a wood bit, instead of a specialized concrete bit. Recommendations include using a diamond crown drill bit for reinforced concrete, which can cut through rebar, and drilling pilot holes to guide the larger bit. It is advised to drill holes around the desired area and then chisel out the material, as this method can be more effective. The importance of using the right tools, such as a high-quality impact drill, is emphasized, with specific brands and models mentioned for optimal results.
