Continuous Operation of Home Air Conditioner Compressor: Truth or Myth?
wnoto 21867 9
Can a home air conditioner compressor run continuously for many hours, or does it need to rest?
No—an air conditioner compressor does not have to rest after 10 hours; many units run 24/7 and switch off only when they reach the set temperature [#12393262] Continuous load can still reduce durability because compressors have a finite number of operating hours, so a unit that works all the time may wear out sooner than one that cycles [#12393734][#12401365] If the air conditioner is too small for the room, it may never reach the set temperature and the compressor can run nonstop, and under unfavorable conditions this can even lead to icing of the indoor unit [#12491924] In refrigeration systems, compressor operating time is often selected at about 16–18 hours per day [#12494036]
  • #1 12392892
    wnoto
    Help: 58
    Rate: 745
    While asking the service technician about the "air conditioner" for the house, I heard that you can not give too small because it can not go non-stop (for example, 10 hours) only has to rest.
    Is this true ?
  • #2 12393262
    Sołtys_Elbląga
    Help: 113
    Rate: 565
    At work in offices we have small air conditioners that run 24 hours a day 365 days a year. They rest when they cool or heat the room to a selected temperature, when this temperature changes they switch on again.
    Chris_W
    Help: 386
    Rate: 1053
    There is such a parameter as compressor man-hours - and every compressor has some maximum life calculated in these man-hours. In short, a device loaded all the time will be less durable - of course, there is no rule here - but statistics work.
  • #4 12401187
    wnoto
    Help: 58
    Rate: 745
    Assuming that it has a life of 3000 hours (I'm shooting), it is relevant whether these 3000 hours are done in a row or in a row with an hour of work, an hour of rest?
    In both cases it will be around 3000 hours of total operation? (although in the second case it will be 2 x longer working time).
    Personally, I suspect that the installer slightly stretched the truth.
  • Continuous compressor operation shortens lifespan, especially when undersized
    #5 12401365
    Chris_W
    Help: 386
    Rate: 1053
    Working continuously, she may pass out of this world after, say (I shoot), 4 years - working with "breath" after 8 years. And if you hit a "weaker piece" - these times can be 2x shorter. He stretched the truth by saying that it "must" rest - he should have said that it "should" rest if you want to have trouble-free operation for a long time - but the customer can do what he wants with it - it's his property, after all.
    In practice, if you use the air conditioner ad hoc to cool a room at a time, and then turn it off (for example, so that it does not draw electricity), then the "main thermostat" becomes a person who turns on when he is warm and turns off when he is well enough - then the compressor does not work excessively.
    The installer may have had in mind a case where too male device is trying to reach the set low temperature and is unable to do so - then it keeps running without achieving the effect. At the same time, this device is beyond human control (e.g., server rooms, industrial equipment, etc.) in the apartment rather people prefer to save - they will not allow devices that consume a lot of energy to work unnecessarily.
  • Does continuous operation damage an undersized air conditioner?
    #6 12401452
    wnoto
    Help: 58
    Rate: 745
    Let's take this case. Does such an action affect the durability of the device (understood as rbg) or just the feeling of a person ?
    I would like a device that is able to reduce the temperature by a few degrees and not that it is absolutely always able to get to 20 degrees inside if it is even 36C outside.
  • Compressor lifespan is better measured in operating hours
    #7 12401528
    Chris_W
    Help: 386
    Rate: 1053
    The fact that such a device will work all the time does not significantly affect the fact that fewer hours it will be able to work. But the lifespan of equipment in the popular opinion is counted in absolute time - it does not matter whether it stands or works (unless otherwise indicated) - in some air conditioners may be 15 years old and working - but have worked, for example, 100h, and in others they may work 5 years until they break down, but have worked 20000h (we are talking about the operation of the compressor) - so I prefer to talk about the hours of operation of the device, rather than how long someone has an air conditioner.
  • #8 12401587
    wnoto
    Help: 58
    Rate: 745
    Chris_W wrote:
    ...that's why I'd rather talk about the hours of operation of the unit, rather than how long someone has the air conditioner.
    Thanks for the reply. This is what I was referring to.
  • #9 12491924
    barszcz17
    Rate: 21
    This service technician probably meant something else. An air conditioner with too little power will never reach the set temperature. The compressor will run non-stop, which, if the conditions are not favorable (the lowest discharge speed and clogged filters), can cause the indoor unit to ice up. Even short interruptions in the operation of the compressor will allow the possible seeds of ice to melt.
    As a matter of interest:
    Three new Sanyo inverters air conditioners, server room. They work for 2 days and then flood. Maneuvers like increasing/decreasing the amount of refrigerant did not help. Sanyo asked for help stated that these units are not designed for server rooms. I ended up manually enforcing 5-minute shutdowns every 12 hours.
  • #10 12494036
    p.obelix
    Refrigeration equipment specialist
    Help: 215
    Rate: 564
    I'll add such an interesting fact that in refrigeration systems the compressor operating time is selected at 16/18 h per day.
The discussion centers around the continuous operation of home air conditioner compressors and whether they require rest periods. Responses indicate that while air conditioners can run continuously, their lifespan may be affected by constant operation. Factors such as compressor man-hours and the potential for overheating or icing up in underpowered units are highlighted. It is noted that compressors in refrigeration systems are typically designed for around 16-18 hours of operation per day. Users share experiences with specific brands, such as Sanyo, and emphasize the importance of proper sizing and maintenance to ensure efficient operation and longevity.
