Renault Laguna II 1.8i ABS Error C1131 & C10C0: Brake Pressure Sensor & Low Voltage Issue
kredens007 21840 12
Why do the ABS and handbrake lights stay on in a Renault Laguna II with fault codes C1131 and C10C0, and is the ABS pump/module or brake pressure sensor at fault?
The fault is most likely in the ABS pump/module rather than just the electronics, and one reply says the complete pump has to be replaced [#12643230] Another reply adds that the pump module usually has three power supplies plus ground, so those feeds should be checked, and the brake pressure sensor code does not always mean the sensor itself is faulty; read the live values in the ABS unit [#16564714] A later case with a similar ABS/ESP issue was fixed by removing the pump, finding the motor pistons blocked, cleaning the assembly, and then bleeding the brake system [#21328583]
  • #1 12414828
    kredens007
    Rate: 20
    Hello!
    Well, I have a problem with ABS in Laguna II 1.8i, after starting the engine does not go off ABS and handbrake control.
    Errors: C1131 and C10C0: brake pressure sensor, no controller power supply, voltage too low.
    All relays, fuses, contacts have been checked, the power supply on the ABS block is coming.
    What do you think? An ABS pump in? Or maybe the system itself at the pump?
  • #2 12643230
    77kris77
    Rate: 61
    The ABS pump is released. Replacing the electronics itself will not do anything. You must replace the entire pump.
  • #3 16563951
    Slawek570
    Rate: 11
    I will dig out the topic I have Lagune II 1.8 16v from 2001 and I have exactly the same problem and error C1131 which I can not remove of course, the ABS indicator light and the hand brake light what was the cause of the fault whether it is actually ABS pump pozdr
  • #5 16564364
    coperfild
    Help: 291
    Rate: 1697
    The driver itself can be replaced.
  • #6 16564692
    adam7009
    Help: 656
    Rate: 1635
    what will it change?, how damage is not in the driver?
    AUTO-ELELEKTRONIK AB
    Linowiec, Lisewo, 86-230 | Tel.: 697XXXXXX (Show)
  • #7 16564714
    ptr92
    Level 19  
    Help: 27
    Rate: 248
    The ABS pump module usually has three pluses. And the power to the minus, which are also to check.
    And the fact that the brake pressure sensor error comes out does not always mean its failures. You need to analyze the actual values in the Abs steering wheel
  • #8 16564868
    adam7009
    Help: 656
    Rate: 1635
    ptr92 wrote:
    And the fact that the brake pressure sensor error comes out does not always mean that it fails.
    always
  • #9 16564875
    ptr92
    Level 19  
    Help: 27
    Rate: 248
    Once in the skins superb I had a brake pressure sensor error. The error was canceled, but after pressing the brake pedal appeared. In real terms the pressure was good and the stop switch turned out to be guilty. I tested KTS, but I doubt that he misinterpreted the error
  • #10 16564964
    adam7009
    Help: 656
    Rate: 1635
    the small difference here is not canceled, you were canceling, and because it was good, only the system did not see that you pressed the pedal and the pressure increased.
  • #11 16564978
    ptr92
    Level 19  
    Help: 27
    Rate: 248
    adam7009 wrote:
    , you canceled, and because it was good, only the system did not see that you pressed the pedal and the pressure increased.
    Well, that's ;)
  • #12 16566513
    Slawek570
    Rate: 11
    So the replacement pump can be regenerated or is it not better to replace it better?
  • Blocked ABS pump pistons caused relay fault
    #13 21328583
    epiotrek
    Rate: 8
    The topic is supposedly over, but I had a similar case. Laguna II FL. Error slightly different C1113 - ABS Power Relay Coil Short Circuit To Battery.
    Clearing the error did not help, after a while the error was active again. I took the ABS/ESP pump apart and there the pistons that drive the motor were blocked. I started it up, cleaned it, etc.
    After bleeding the brake system, the error disappeared. Everything is working properly.
    Jamming of these pistons in long-standing pumps is apparently a fairly common occurrence.
The Renault Laguna II 1.8i exhibits persistent ABS and handbrake warning lights after engine start, with diagnostic trouble codes C1131 and C10C0 indicating brake pressure sensor faults and low voltage/no controller power supply issues. Despite verified power supply and intact relays, fuses, and contacts, the ABS pump is often identified as the root cause. Replacement of the entire ABS pump assembly is generally recommended, as replacing only the electronics or driver module may not resolve the issue. The brake pressure sensor error does not always indicate sensor failure; it may result from system misinterpretation or related components such as the brake light switch. In some cases, mechanical jamming of the ABS/ESP pump pistons can cause similar errors, which can be resolved by disassembling, cleaning, and bleeding the brake system. This piston seizure is a common failure mode in long-used pumps. Regeneration of the pump is possible but replacement is often preferred for reliability.
