Laguna 2 ph1 2002 2.0 IDE: DF017 ABS/ESP Error, Power Supply & Ankle Contacts - Troubleshooting
Grzess93 20685 3
  • #1 17092629
    Grzess93
    Laguna 2 ph1 2002 2.0 IDE: DF017 ABS/ESP Error, Power Supply & Ankle Contacts - Troubleshooting Laguna 2 ph1 2002 2.0 IDE: DF017 ABS/ESP Error, Power Supply & Ankle Contacts - Troubleshooting Hello. I have Lagune 2.0 IDE from 2002
    I bought a lagoon that did not work ABS and ESP connected to the computer showed error DF017. I checked the ankle contacts at the pump, the power supply on both red wires was and - on both black ones. I deleted the error several times with the DDT2000 program and with 4 or 5 together the error disappeared but the indicator light came on after about 40 seconds and another time after firing the error did not jump out immediately and after driving about 1 km. What could it be?
  • #2 17092656
    brani
    Help: 19
    Rate: 113
    clip will respond - probably a pump
  • #3 18186909
    lopat84
    Rate: 98
    What was? Pump or pump electronics alone?
  • #4 18393689
    kubahawaje
    Rate: 19
    Hello. He probably won't answer. He has already paid, repaired and now look for yourself :(
