Centra Futura 53Ah vs Centra Plus 54Ah: Choosing the Right Battery for Opel Astra II 1.8 115KM
Shant1 62373 51
Which Centra battery is better for an Opel Astra II 1.8 115 KM if I drive mostly short distances: Futura 53Ah or Plus 54Ah?
If you drive mostly short distances, the forum consensus is to choose Centra Plus 54Ah rather than Futura 53Ah, because Plus is the more forgiving option for a car that may not get fully recharged often [#12432224][#12435886] Futura is the stronger battery on paper, with higher starting current, but several users note that it is more sensitive to undercharging and to cars with many electrical consumers when standing still [#13016235][#12897787] The general rule mentioned in the thread is that lower-starting-current batteries tend to tolerate discharge better, while higher-starting-current ones give more "kick" but are less robust if the battery is not kept well charged [#15579650] So for an Astra II used a little, Plus is the safer choice; Futura can work well too, but mainly when the charging system is good and the car is used regularly enough [#12432151][#12904427]
  • #31 17462603
    KodIT
    HDD Recovery specialist
    Help: 90
    Rate: 82
    We used the Astra H 1.7 CDTI Centra Plus 72Ah in our company car for 7 years. This year it is the end of the battery.
    KodIT Odzyskiwanie Danych
    os. Stefana Batorego 49, Poznań, 60-687 | Tel.: 788-XXX-XXX (Show) | Company Website: https://kodit.pl
  • #32 17988193
    autopirat
    And once, from new and without replacement, the battery lasted 14 years in the Opel Astra. The car ran in the same city and in bigger traffic jams than today, because mainly in the city center (now I drive mainly by the beltway).
    Well ... everywhere, business and accounting counts and counts, and assemblies are made with a specified lifetime.
    My battery has just died, and how else, after about 5 years.
    It is a pity that there are no longer-lasting batteries, I will gladly pay extra :(
  • #33 17988310
    cinho90319
    Rate: 48
    I switched to ZAP and I can recommend it
  • #34 17989508
    adse
    Help: 56
    Rate: 255
    Apparently, some Moll models are still produced using the old cast grille technology. The price is several times higher than modern ones. In addition, Ukrainian "Amega 7" produced in cooperation with the Moll company.
  • #35 18323279
    MarcinM2020
    Help: 71
    Rate: 247
    Gentlemen, I have a question. I have a center battery plus a CB 620. What is the actual battery? Serviceable or maintenance-free? I want to recharge it because I left the car at the traffic lights and I don't know if you need to open this cover from the top or not.
  • #36 18335023
    adse
    Help: 56
    Rate: 255
    When he is 2 years old or less, he probably still has enough electrolyte, so you can risk letting go of opening the cells.
    If it is older, it is worth removing the lid and checking the level, especially if it is no longer guaranteed. It will not hurt to check, and if the battery has been overloaded in the previous operation, it may need to be refilled with water. In Plus Centers, it was usually possible to remove the lid integrated with the plugs, but if you do not check if this is also the case.
  • #37 18335037
    MarcinM2020
    Help: 71
    Rate: 247
    Aku is 8 months old :) So far, it works elegantly. I did it only once, leaving the car at the traffic lights, then I loaded it in the garage and so I thought that maybe it can be handled somehow ... :)
  • #38 18354773
    valdipolska
    Hello. Futura 72ah 720A centers have withstood me for over 6 years
  • #39 18355390
    MarcinM2020
    Help: 71
    Rate: 247
    That's nice. I wonder how much mine can take. I hope that I will write about it here in at least 5 years ;)
  • #40 18665475
    grundigfan
    Help: 5
    Rate: 55
    my standard centers lasted less than 6 years
  • #41 18667235
    jerzyf
    Help: 47
    Rate: 198
    I have a fur, I installed it in February 2010, it is still trouble-free, 1.6v16 engine. I drive a little, I stand more, I have never had a load!
  • #42 18667412
    MarcinM2020
    Help: 71
    Rate: 247
    That's cool. May she also "live" with me as long as possible.
  • Centra battery warranty complaint after rapid failure
    #43 19429693
    wklaczynski
    Rate: 18
    Shant1 wrote:
    On some forum I found information:
    "do you drive little or a lot?
    a) little is futura centers - Futura 53Ah battery
    b) there are many plus centers - the Accumulator Centra Plus 54Ah "
    And I wanted to buy a fur, but in the store, the guy looking at my opel astra II 1.8 115KM said that for such a car there will be better centers, plus if I do not drive a lot because fur is rather for newer cars, it needs more charging current or something like that, and what is yours opinion?
    Syf the battery. I bought it earlier because I had a bosh that worked for 7 years. But we support Polish. Unfortunately, the battery does not run a bit colder anymore, sometimes it did not need any special cooling down. After some time, it cannot even be recharged. Going with the complaint of this shit, it turns out that the warranty states that the battery has no voltage, the complaint will not be accepted. The only reason for the complaint is that the battery cannot be charged and it is obvious that there is no electricity. So the guarantee is a fake, knowing that muck so they wrote it down in order not to recognize the guarantee for their crap. Charging in the car works perfectly, with the rest I dumped the scrap metal and bought a Bosch, it works fine for a long time in the same as the muck from the center, it did not last half a year. So another man can do it, and they always have some but, because the car can be unloaded when stationary, maybe the computer in the car is downloading something. But since someone getting out of the car has to remove the battery, it's a mockery. Worse, when there is frost, take the battery to bed. Producers from Centa should know what the weather conditions are in the winter, and know what cars they are, now have computers, etc. ... which also take a small amount of electricity when stationary and produce such a battery that they can do, especially since other manufacturers from outside the country are coping. I stated, because of a great outburst of patriotism, that I do not want to deal with this muck, I dumped the muck, I did not think about a guarantee. I bought it abroad, and I advise against it, if they do not know how to produce, let them fall to a German for asparagus, and he will earn by selling me the battery.
  • Warning against Centra batteries and warranty traps
    #44 19430885
    wklaczynski
    Rate: 18
    What color acu century battery is worth nothing to sell. When buying, look at the provisions in the warranty, they speak for themselves. There is a warranty, but what can only go wrong is a thin print, the complaint is not accepted. So the guarantee is a mockery, they know it's a shit, it won't stand up in our climate. If the car is not in the garage and there is frost, you can forget about driving in the morning. Running, charging, combinations, after a few such accidents, the current does not hold, the voltage drops, it cannot be charged, the problem is not subject to complaint, the warranty record, the voltage of the damaged battery is too low. Under no circumstances should you test this something, because it's just a nerve damage. Running through the courts is also a waste of time. No money saving, because the price compared to brand-name batteries of the same class is even higher. But those are at least 5 years, not half a year, and if they fall within the warranty period, there is no problem with claiming your rights. It is a pity that the Centers have customers somewhere, and similarly their vendors smile when advertising this junk, but then scoff in the eyes, because you should read the contract when buying. When buying, we are guided by the better earning of our people in the country, then we can rather spit in the beard for it, as they will treat us like suckers when we make a complaint. They also say that they give us grace, that they talk to us at all. Better to buy a foreign Bosch, etc ... let Germany earn, or someone else who respects his customers, even if he hits a defective art, which sometimes happens. And those gentlemen who trick us into such things will have to use their cunning with a German on asparagus. What I wish them very much, because by selling this crap they are as responsible for it as the producer of what encourages them to cheat their customers, because rather scammers from centers that commission such sales, always a few stupid will find at least once in their life and will give them the last one to earn.
  • #45 19431580
    pasikowski1
    Help: 5
    The service battery or no water should be poured into it from time to time, as there were plugs outside, it was natural to look at it sometimes and then add some flapjacks and no one looks inside.
  • #46 20167719
    jaken
    Centra plus 74A in Citroën, 10 years. He died a few days ago.
  • #47 20167849
    Kantylena
    Help: 18
    Rate: 222
    In the family - golf vi 2.0 tdi for 5 years Futura 64 Ah, which is kind of a bit too small and I can do it, so in my opinion it also depends on the copy, it is worth taking a look at the production date.
    I wonder if he can do it in winter.
  • #48 20168720
    jerzyf
    Help: 47
    Rate: 198
    jerzyf wrote:
    I have a fur, I installed it in February 2010, it has been trouble-free until today, the 1.6v16 engine. I drive a little, I stand more, I have never had a charge!
    This year, a few months ago, after 12 years, she gave up, which I regret to report!
  • #49 20241398
    Błękitny
    Rate: 17
    For me the Exide Excell EB500 is dying after 7 years of use. The car has never been parked in a garage.
  • Battery criticized as failing after first frost
    #50 20241559
    wklaczynski
    Rate: 18
    It is a pity that only sellers this battery only works. Unfortunately, the battery is rubbish. Doesn't last a year. Complaints about mockery will always get out of hand. The battery was dead after winter. Seller's recommendation to remove even when going to the store, wear in a warm, sleep, keep under a duvet, otherwise 0V will die, Auto user fault is ok, replaced with another brand 0 problems it has survived for 10 years despite the fact that the centers died at the first frost, and only a problem with complaints until it was time to let go and buy a real third-party battery. Unfortunately, also not recommended by repair shops. The car and the climatic conditions on earth where this muck could work has not been created yet. So saying it has survived for 10 years rather paid advertising, nothing more.
  • #51 20841539
    stywen
    I've had Centra plus for 7 years and it's still ok. I top it up twice a year, in November and March. So I recommend it.
  • #52 20845997
    MarcinM2020
    Help: 71
    Rate: 247
    My centa plus is currently 4 years and 8 months old and today it turned slower. I will have to recharge it because the last time I saw the charger was in March. And generally I keep the rule that I top it up twice a year.
    If anything works, maybe we will survive this winter. In March, Aku will be 5 years old....
The discussion revolves around the comparison between Centra Futura 53Ah and Centra Plus 54Ah batteries for the Opel Astra II 1.8 115KM. Users express varying opinions on the suitability of each battery based on driving habits. The Centra Plus is generally recommended for frequent driving due to its higher durability and better performance under load, while the Futura is suggested for less frequent use, although some users report issues with its longevity and warranty claims. Concerns about the quality and reliability of Centra batteries are prevalent, with several users sharing negative experiences regarding warranty service and battery lifespan. The consensus leans towards the Centra Plus for its robustness, especially in colder climates, while the Futura is criticized for its performance and warranty issues.
TL;DR: Forum data show 53-54 Ah Centra batteries last 1.5-12 years (median ≈ 6 years)[Elektroda, tomek1m, #13014650; jerzyf, #20168720]. “Everything is now made to last only the warranty period”[Elektroda, Kekacz, post #13016235] Futura delivers ~25 % more cranking amps than Plus, but Plus handles low-charge use better.
Why it matters: Picking the right model cuts cold-start risk and avoids denied warranty claims.
• Centra Futura 53 Ah: 540 A EN cold-cranking, heat-sealed lid, 3-yr warranty [Centra Catalogue, 2023]. • Centra Plus 54 Ah: 480 A EN, removable service lid, 3-yr warranty [Centra Catalogue, 2023; Elektrola, Aksag, #12897787]. • Typical price Poland: Futura 350-450 PLN; Plus 300-380 PLN [SklepAkumulatory, 2024]. • Lead-acid weight for 54 Ah class: approx. 13-14 kg [BatterySpec, 2024]. • Lead prices rose 110 % since 2004, driving lighter plates [Infomine Lead Price, 2024].
Which battery fits Opel Astra II 1.8 115 KM best?
Centra Plus 54 Ah meets Opel Astra II size (207×175×190 mm) and delivers sufficient 480 A start current. Forum users note Plus copes with short urban trips better than Futura because it tolerates partial charge states [Elektroda, Shant1, #12432142; benny1, #12432224].
What is the core difference between Centra Futura and Plus?
Futura uses thinner, calcium–silver plates and sealed cover, giving higher cranking current (~+25 %) and lower self-discharge. Plus keeps thicker plates and a vented, openable cover, so it accepts over-charging and water top-ups [Centra Catalogue, 2023; Elektroda, Aksag, #12897787].
Why do some Futura units die after only two winters?
Futura’s thin plates sulphate quickly when left under-charged. Users driving short distances with many electrical loads report voltage staying near 13 V, leading to sulfation and plate mass shedding [Elektroda, pawel8080, post #12912672] Manufacturer rejects such claims as “user under-charging” [Elektroda, Kekacz, post #13015759]
Does higher starting current really help the Astra?
The Z18XE petrol engine needs roughly 300 A at –18 °C. Futura 53 Ah offers 540 A, giving large reserve; Plus 54 Ah offers 480 A, still 60 % over the requirement. Extra current mainly shortens crank time in deep frost but does not extend battery life [Bosch Starter Data, 2022].
Can I open and top up distilled water?
Yes in Plus: pry the combined lid and add water to cover plates. No in Futura: case is heat-sealed; forcing it voids warranty [Elektroda, Aksag, post #12897787]
How often should I recharge if I do mainly city trips?
Forum veterans recommend bench-charging every 3 months. Three-step routine: 1. Remove negative lead; 2. Charge at 14.4 V until current < 0.5 A; 3. Rest 2 h, then reinstall. This stops chronic under-charge that caused 1.5-year failures [Elektroda, Aksag, post #12897787]
My warranty was refused—why are claims hard to win?
Service accepts faults only for short-circuited cell, zero volts, or factory leak. Sulfation or capacity loss from under-charge is classed as ‘user misuse’ and rejected [Elektroda, Kekacz, post #13015759]
Are lighter batteries worse?
Generally yes: less lead means thinner grids and lower cycle life. Centra omits weight from spec sheets; community members cite this as red flag [Elektroda, adroit, post #15579108] Lead content trimmed because raw-lead price rose 110 % since 2004 [Infomine Lead Price, 2024].
How do I maximise battery life?
  1. Keep state of charge above 80 %—bench-charge quarterly.
  2. Clean and torque terminals to 10 Nm, reducing self-discharge.
  3. Maintain 14.2–14.8 V alternator output; adjust regulator if low. Following these three steps doubled service life from 3 to 6 years for multiple posters [Elektroda, rafcio363, post #13070200]
Will frequent short trips harm even the Plus model?
Yes. At idle with lights, fan, and defogger, alternator cannot restore start energy. One user drained Plus in three days of 2 km trips [Elektroda, Shant1, post #12432142] Add monthly charger sessions or occasional 30 min highway run.
