Vectra B '99 2.0 16V LPG: Best Battery for 30km Daily Commute, -10°C Garage, & Monthly 1-Hour Drive
darecki777 2781 9
What battery capacity should I choose for a 1999 Vectra B 2.0 16V LPG used for 30 km daily commutes, stored in a garage below 0°C, and driven for one uninterrupted hour once a month?
Use the battery size recommended by the manufacturer; in the thread, 62Ah is mentioned as a normal choice, and the car can physically take roughly 44Ah to 100Ah depending on what fits [#16263173] [#16263211] [#16263240] If the charging system is healthy, the driving pattern and cold garage temperatures should not require a special driving style, but the battery should see more than 14V at the battery with the lights on [#16263211] One user also reported good long-term results with a 55Ah Banner battery and charging at 14.3V [#16263283]
  • #1 16263156
    darecki777
    Rate: 28
    Is it possible to choose a battery for vectra B 99r 2.0 16V lpg for such parameters?
    -Daily cover 30 km in the morning and return 30 km after 12 hours.
    -garaged, but the temperature below zero, if outside -10, then in the garage -8
    - maybe I do 1 hour once a month driving without interruption
    Does it make a difference to your driving style?
  • #2 16263173
    olekt2002
    Level 32  
    Help: 147
    Rate: 515
    The one recommended by the car manufacturer. Amen.
  • #3 16263208
    marqqv
    Level 32  
    Help: 162
    Rate: 609
    And what happens that you ask about the selection of the battery? Discharges if it's such a whim to change something.
  • #4 16263211
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Not affected, 62Ah.
    Measure the charge, the lights should be on above 14V on the battery.
  • #5 16263240
    ociz
    Help: 1379
    Rate: 3486
    Pack what you want there. From 44Ah to 100Ah, because you can't fit a bigger one.
  • #6 16263283
    darecki777
    Rate: 28
    Banner 55 Ah, the second is charging 14.3V every two years
  • #7 16263298
    marqqv
    Level 32  
    Help: 162
    Rate: 609
    It's normal, I also had it on those I bought exite and I bought a regular one, so cheap and it's been working for 5 :D
  • #8 16263356
    olekt2002
    Level 32  
    Help: 147
    Rate: 515
    marqqv wrote:
    fungi
    Maybe brighter?
  • #9 16263386
    marqqv
    Level 32  
    Help: 162
    Rate: 609
    Works buddy even now in these frosts the engine is disel but still fires :)
  • #10 16604740
    darecki777
    Rate: 28
    I did not mention the gun, so far I think there is a short circuit
The discussion revolves around selecting an appropriate battery for a 1999 Vectra B 2.0 16V LPG, considering specific usage parameters: a daily commute of 30 km with a return after 12 hours, storage in a garage with temperatures around -8°C, and a monthly one-hour drive. Recommendations include using a battery with a capacity ranging from 44Ah to 100Ah, with a preference for a 62Ah model. The importance of maintaining a charge above 14V is emphasized, and the Banner 55Ah battery is mentioned as a viable option. The impact of driving style on battery performance is deemed negligible.
