Selecting a Suitable Battery for Polonez Caro 1.6 GLI 1995: Bosch, Exide or ZAP Silver?
sta1415 11427 6
  • #1 16191787
    sta1415
    Rate: 9
    Dear forum members.
    Due to the fact that in my Polonez the battery fell, or actually boiled it off a burned voltage regulator, I need to buy a new battery. Until now, I have used centers plus 62 Ah, but the quality of this brand has probably decreased, because in the last 6 years I have replaced every battery immediately after the end of the warranty, i.e. after 2 years it was unusable.
    I read that the battery should be selected in terms of alternator and starting current. In my polonaise, there is a 55 A alternator. The plus ones were more powerful 70 A alternators and there were 62 Ah batteries there at the factory. However, I had to recharge my batteries to full capacity every month.
    I'm thinking of buying a battery:
    - BOSCH S4 60 Ah 540 A
    - BOSCH S5 63 Ah 610 A
    - Exide 55 Ah 460 A EC551 (also like centers) my number two on the list
    - Exide 62 Ah 540 A EB621 (also like centers)
    - ZAP Silver 555 26 55 Ah 460 A and I am most inclined to do so.
    Best regards and thank you for the answers.
  • #2 16191823
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    sta1415 wrote:
    I read that the battery should be selected in terms of the alternator
    Faithful crap repeated xxx times until it became revealed truth .....
    You have a problem with charging or something consumes too much electricity.
    Normally you give something above 60Ah and you have peace of mind for years as long as normal landing.
    And by the way check the charging with the lights on if it is over 14.2V.
  • #3 16191824
    Ireneo
    Help: 747
    Rate: 2472
    Take the cheapest of those you gave.
  • #4 16191827
    Help: 1405
    Rate: 6430
    Where are you from, buy something aftermarket.
    Bizon_nizinny
    Rate: 17
    According to the Jenox catalog, R056623ZN - 56 Ah, 560 A. comes out. Affordable. There is nothing to push into such a car for such a car, the more that it is not particularly durable.
  • #6 16227112
    andrzej20001
    Help: 1578
    Rate: 6669
    If you plan to use it for a long time, buy S5. If you don't foretell its future, buy the cheapest one.
  • #7 16345085
    sta1415
    Rate: 9
    The topic can be considered resolved. I found in the literature the values that the battery should have for individual engine versions:
    - Polonez 1.4 Rover, 1.5 and 1.6 carburetor (1978 - 1994): 45 Ah,
    - Polonez 1.5 and 1.6 Abimeks injection (1992 - 1997): 55 Ah or 60 Ah,
    - Polonez 1.6 injection Bosh and Delphi (1997 - 2002): 62 Ah,
    - Polonez 1.9 Citroen Diesel (1991-2002): minimum 60Ah, the manufacturer recommends installing larger ones.
    I bought a Kozak battery, 60 Ah L +. After familiarizing myself with the offer and opinions on various brands, I decided that it is not worth paying extra for the brand.
    Greetings.
The discussion revolves around selecting a suitable battery for a 1995 Polonez Caro 1.6 GLI after the previous battery failed due to a burned voltage regulator. The user previously used a Centers Plus 62 Ah battery but experienced frequent replacements. Recommendations include considering the alternator's capacity (55 A) and starting current. Suggested options are Bosch S4 60 Ah, Bosch S5 63 Ah, Exide 55 Ah, Exide 62 Ah, and ZAP Silver 55 Ah. Some participants advise opting for the cheapest option if longevity is not a concern, while others suggest a higher quality battery like the Bosch S5 for better durability. The user ultimately decided on a Kozak 60 Ah battery after reviewing various brands and their reputations.
