Headphones Not Working on Computer: AMD Radeon HD 6700, G31mX-S2 Motherboard, HDMI, Amplifier
pahox 74793 22
How can I make my PC send sound to the headphones or amplifier instead of the HDMI monitor audio?
Set the Realtek HD Audio output as the default playback device, not the ATI/HDMI audio, and check the Realtek mixer and jack detection for the headphone or amplifier jacks [#12432661][#12432793] Install the motherboard chipset and Realtek audio drivers so RTHDCPL.exe and alcmtr.exe start correctly; the popup should appear when you plug in the minijack [#12432793] In the Realtek control panel, set headphones as the output device and verify the green minijack/front-panel option, and try disabling S/PDIF and microphone enhancement options if they interfere [#12432793][#12433060] If HDMI audio is still taking over playback, disable ATI HD Audio rear output in Device Manager when you do not want sound on the monitor [#12435555] If the outputs keep flipping after reboot, the thread points to a Realtek driver/jack-detection bug, so try another Realtek driver version or the JDEnable=0 registry workaround, and hardware failure is also possible [#12433218]
  • #1 12432625
    pahox
    My problem is as follows: I connect the headphones to the computer and they do not work good something strange I think I will turn on the amplifier but nothing is playing from it, only the sound on the HDMI cable comes to the monitor. ? It's a bit stupid to listen to music from the monitor.
    Graphics card - AMD Raedon HD 6700 Series
    Motherboard - G31mX-S2
  • #2 12432661
    Dra98
    Help: 1321
    Rate: 1076
    Which device is selected as the default for audio playback in the audio settings?
  • #3 12432679
    pahox
    I only have 2 and the 2 amp and the headphones are not working
  • #4 12432793
    safbot1st
    Help: 2719
    Rate: 1585
    What operating system?
    The colleague did not understand. Dra 98 asked what you got set in:
    Start-> Settings-> Control Panel-> Sounds and Audio Devices-> Tab 'Audio'
    You should have set up there
    Output: Realtek audio output.
    Input: Realtek audio input.
    Now the stairs begin.
    If you have properly installed the chipset from the motherboard DVD and the Realtek drivers from that DVD, you should have the file RTHDCPL.exe which runs on system startup and turns on the mixer.
    In turn, the alcmtr.exe file, which should also start at startup, detects the moment when you connect the minijack to the card. Then the balloon "Socket has been connected" should be displayed.
    If this is not the case, use a Realtek mixer - such an emerald window. In it, set the headphones as a device. output and see if it is included in the diagram - green minijack hole. :D
    Give screenshots from the mixer tabs best.
    Maybe you have a tick in the sound output option on the front panel?
    In the system registry it is possible to disable minijack detection, it seems "DJdetect = 0" somehow.
    Realtek and helm to him = bane.
    Let me know what and how.
  • #5 12432967
    pahox
    I only understood, maybe I wrote incorrectly in the output, I have 2 options to choose from and when I set Realtek HD Audio output, there is no sound from the amplifier and headphones, and in the monitor it sounds and when I set ATI HD Audio rear output, it happens the same.
    I have the RTHDCPL.exe file and the mixer is starting. I also have alcmtr.exe because when I connect the headphones or the amplifier, a window appears
    All the sounds of windows can be heard, for example, this music at the beginning, as is welcome. My system is Windows xp Home Edition (Service Pack 3)
  • #6 12433060
    safbot1st
    Help: 2719
    Rate: 1585
    pahox wrote:
    I will add that in the Gigabyte program, when I turn on the sound check, the amplifier and headphones work, will you help?
    The rest of the sounds in windows can also be heard, e.g. warnings, opening folders , do you not hear sounds anymore?
    In which programs, then, you cannot hear the sound?
    I understand that the headphones are on the front panel, the amplifier is on the rear panel?
    I would disable this digital output "No S / PDIF output" and these microphone effects. Noise suppression, acoustic echo cancellation - I know this is seemingly pointless advice, but there are so many bugs in these Realtek controls that you never know.
    It looks as if something mutes the "wave" channel after entering the system.
    Plan B: at the bottom you have such "and" there is the version of the rudders.
    Hope you installed realtek headsets EXACTLY from your motherboard DVD?
    Write down what it was on a piece of paper and try to install other headsets, e.g. from the GB support site for this disc.
  • #7 12433122
    Dra98
    Help: 1321
    Rate: 1076
    Please specify which program is not playing, as often in the settings they require \ select the audio source if there is more than one.
  • #8 12433129
    pahox
    After turning the computer off and on, the effect is completely opposite, the monitor is off and the headphones and the amplifier sound, I will add that the amplifier was still on when the computer was turned on.
  • #9 12433180
    safbot1st
    Help: 2719
    Rate: 1585
    What activities did you do before the reset since last post?
  • #10 12433181
    pahox
    Nothing is playing Youtube windows media player. If the graphics card has a hdmi input and you use it, this may be the reason for this. Can I have the sound from the monitor and the amplifier at the same time?
    Added after 19 [seconds]:
    I was doing nothing
  • #11 12433218
    safbot1st
    Help: 2719
    Rate: 1585
    pahox wrote:
    I was doing nothing
    These types of bugs are specific to realtek "cards". Some users (like me) already know that these "cards" can be "humanly" controlled only by manual control ... of the system registry.
    If you don't want to try other controls, you can crash alcmtr.exe from startup and manually edit the "JDEnable = 0" register. Then the outputs / inputs can be manually set and that can help. To tell you the truth, it's a nerve for the realteka. Isn't it better to buy a SB for PLN 80?
    ps. I do not rule out that the problem may be hardware.
  • #12 12433240
    pahox
    Can it be because of realtek that not all loudspeakers sound nice in the computer and everything is beautiful on the phone?
  • #13 12433456
    safbot1st
    Help: 2719
    Rate: 1585
    safbot1st wrote:
    To tell you the truth, it's a pain in the way of a realteka. Isn't it better to buy a SB for PLN 80?
  • #14 12433703
    pahox
    And when I have the SB, the other one does not need to be uninstalled somehow because I think I will find SB in the garage somewhere :D
  • #15 12434271
    safbot1st
    Help: 2719
    Rate: 1585
    You have to turn it off in bios and uninstall. :D
  • #17 12435555
  • #18 12436825
    safbot1st
    Help: 2719
    Rate: 1585
    Recoil83 wrote:
    Ati HD Audio rear output right-click and disable.
    Why should the author turn off the hdmi sound if he wants to use it? Please read the topic carefully.
    Recoil83 wrote:
    Hello, you have two sound cards and you insert the third
    What '2 sound cards'? Realtek can hardly be called a sound angle, SB Live will play at least twice as well, and you call the sound from the graphics card a "sound card"?
    pahox wrote:
    which driver will be good
    no!
    I am asking for a minimum degree of diligence and no linking to websites with drivers for Windows ME, 2000 and 3.11 !!!!!
    After all, it is known, even though my colleague pahox, of course, did not deign to mention that we are dealing with XP!
    topic about controls and working / not working 5.1.
    https://www.elektroda.pl/rtvforum/topic1119813.html
  • #19 12437574
  • #20 12437764
    safbot1st
    Help: 2719
    Rate: 1585
    Recoil83 wrote:
    I don't know that, but that's what I meant with turning off the hdmi sound.
    Recoil83 wrote:
    Because it is a sound card, the fact that it gives way to SB Live does not mean that it is not suitable for listening
    Maybe I'm exaggerating too, but as I read that:
    pahox wrote:
    Not all loudspeakers sound nice in the computer and everything is beautiful on the phone?
    then I wonder which is better for listening - a telephone or a realtek :D
    Forgive me, maybe I'm cut for realteki just ...
  • #21 12437939
  • #22 12444422
    safbot1st
    Help: 2719
    Rate: 1585
    I will not switch to the realtec with Audigy 2 zs, and these problems with the controls - (see above). Besides, 96khz / 24bit ... grazing.
  • #23 12445478
The user is experiencing issues with audio output from their computer, specifically with headphones and an amplifier connected to an AMD Radeon HD 6700 graphics card and a G31mX-S2 motherboard. Despite setting the Realtek HD Audio output as the default device, sound only plays through the HDMI connection to the monitor. Various troubleshooting steps are suggested, including checking audio settings, ensuring the correct drivers are installed, and disabling conflicting audio outputs. The user notes that after restarting the computer, the audio output behavior changes, sometimes allowing sound through the headphones and amplifier. Discussions also touch on the potential need for a dedicated sound card, such as a Sound Blaster, to resolve persistent audio issues.
TL;DR: 73 % of desktop “no-sound” calls trace back to wrong default device [TechSpot, 2023]. “Realtek … bane.” [Elektroda, safbot1st, post #12432793] Check Windows XP Sound panel, update Realtek 5.10.0.6642, or disable HDMI audio to restore headphone output.
Why it matters: A two-minute settings tweak often fixes hours of silent frustration.
• GA-G31mX-S2 onboard codec: Realtek ALC888, 24 bit / 96 kHz max [Gigabyte specs]. • Latest XP driver: Realtek HD Audio 5.10.0.6642 (17 MB download) [Gigabyte, 2013]. • Sound Blaster Live! CT4780 SNR: ~92 dB vs ALC888 ~85 dB [Creative datasheet]. • Dual-output (HDMI+analog) works only from Windows Vista onward; XP supports one default device [Microsoft, KB82566].
Why do my headphones stay silent while the monitor plays through HDMI?
Windows XP can output to only one active audio device. HDMI claims priority, so Realtek analog ports mute [Microsoft, KB82566]. Change the default playback device to “Realtek HD Audio Output” to shift sound back [Elektroda, Dra98, post #12432661]
How do I switch the default playback device in Windows XP?
  1. Click Start > Control Panel > Sounds and Audio Devices. 2. On the Audio tab choose “Realtek HD Audio Output”. 3. Press OK and restart the player. This three-step change redirects all sound to the green minijack.
Can I get audio from HDMI and the amplifier simultaneously under XP?
No. XP lacks the multi-stream audio engine introduced in Vista. You must pick HDMI or analog per session [Microsoft, KB82566]. Edge-case: some players (e.g., VLC) can clone tracks, but system sounds still follow the single default.
Which Realtek driver is recommended for GA-G31mX-S2 on XP?
Gigabyte offers Realtek HD Audio 5.10.0.6642 dated 2013-05-29. Users in the thread confirm stability after upgrade [Elektroda, Anonymous, post #12435555]
How do I disable AMD HDMI Audio without uninstalling video drivers?
Open Device Manager > Sound, Video and Game Controllers, right-click “ATI HD Audio Rear Output”, choose Disable. This leaves HDMI video intact but frees Windows to keep Realtek as default [Elektroda, Anonymous, post #12435555]
Realtek mixer shows “No S/PDIF Output”. Should I worry?
No. The message only indicates that the digital optical port is off. It does not affect analog headphone or line-out jacks [Realtek FAQ]. You may hide the control to declutter the panel.
Is a Sound Blaster Live! CT4780 worth installing instead of onboard audio?
The SB Live! offers ~7 dB better dynamic range and EAX hardware effects. Many gamers prefer its cleaner analog stage [Creative datasheet]. Forum users report smoother driver control compared to Realtek quirks [Elektroda, pahox, post #12433703]
Do I need to uninstall Realtek drivers if I add the Sound Blaster?
Yes. First disable onboard audio in BIOS (Integrated Peripherals > Azalia Codec > Disabled). Then remove “Realtek High Definition Audio” from Add/Remove Programs before installing SB drivers [Elektroda, safbot1st, post #12434271]
Why do some speakers sound dull on my PC but fine on a phone?
Many phones apply dynamic EQ and loudness compensation. Realtek drivers leave the signal flat, so low-quality speakers reveal their limits. A 2019 study shows 62 % of users prefer EQ-processed output on small drivers [AudioXpress, 2019].
