Fusjitsu Siemen Laptop Keyboard Issue: Only Polish Characters Functioning on Windows 7
seba9414 15012 11
How can I fix a Windows 7 laptop keyboard that types only Polish characters as if the Alt key were stuck down?
Your laptop’s internal keyboard is likely faulty and is sending stuck Alt/Ctrl signals, so Windows thinks Alt is held down and produces Polish characters [#12467405][#12467990][#12469082] Test with an external USB keyboard and disconnect the built-in keyboard to confirm; if the external keyboard works normally, the internal keyboard is the problem [#12446689][#12467990][#12469082] The fact that the same behavior appears in Safe Mode and on a LiveCD shows it is not a Windows 7 setting issue [#12446690][#12446792][#12467405] The Alt+Ctrl reset key combo did not help in this case, so the practical fix is to replace the laptop keyboard [#12467405][#12469082]
  • #1 12446642
    seba9414
    I have a problem with the keyboard of the above mentioned laptop. Namely, only Polish characters work for me, as if the alt key was pressed (this is also the case on the on-screen keyboard). Reinstalling the driver in device manager did nothing. The laptop runs on Windows 7. What should I do in this situation?
    Please help.
  • #2 12446689
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1541
    Disconnect the keyboard and look at the usb keyboard.
  • #3 12446690
    LA72
    Help: 648
    Rate: 1659
    Check if the same thing happens on any LiveCd system.
  • #4 12446696
    waldinhopl
    Level 19  
    Help: 21
    Rate: 21
    Has the problem been present from the beginning?
  • #5 12446737
    seba9414
    Thanks a lot for so many and quick replies!
    Same with the usb keyboard.
    No, for about 3 weeks.
    I'm in the process of firing, I'll let you know the result a little later.
  • #6 12446750
    waldinhopl
    Level 19  
    Help: 21
    Rate: 21
    Try Ctrl+Shift or Left Alt+Shift.
  • #7 12446792
    seba9414
    On xp livecd everything is ok. The key combinations given by waldinhopl did not help.
  • #8 12447148
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1541
    This problem may be in the system settings regarding the keyboard.
  • #9 12447158
    waldinhopl
    Level 19  
    Help: 21
    Rate: 21
    Exactly, I had a similar case, I pressed some key combination and it did. Check your settings, try other left alt combinations, etc.
  • Keyboard tester reports Alt and Ctrl stuck continuously
    #10 12467405
    seba9414
    Sorry for taking so long to reply but I had internet problems. Coming back to my problem, I found that in safe mode this problem also occurs, but it goes away after pressing lalt+lctrl+palt. I tried this combination on Windows 7 but it didn't help. What can this mean, because I'm starting to run out of ideas. Oh, I reinstalled the system and it was fine until the reboot, but after a reboot the problem reappeared.
    Edit: I did a keyboard test and the program shows that the alt and ctrl keys are pressed non-stop (of course I don't press them).
  • #11 12467990
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1541
    This indicates a damaged keyboard.
    Disconnect it from the board and then look at the external keyboard.
    Was the keyboard flooded?
  • #12 12469082
    seba9414
    There is indeed a problem with the keyboard. I did a test of the entire keyboard in the program and it turned out that the alt key on the laptop keyboard does not work at all, while on the usb keyboard everything is ok, so I am already trying to buy a keyboard ;) .
The discussion revolves around a keyboard issue on a Fujitsu Siemens laptop running Windows 7, where only Polish characters are functioning, resembling a stuck Alt key. Initial troubleshooting steps included testing an external USB keyboard, which exhibited the same problem, and checking system settings. The user confirmed that the issue persisted in safe mode and was temporarily resolved by a specific key combination. However, after a system reboot, the problem reoccurred. Further investigation revealed that the laptop's Alt key was non-functional, leading to the conclusion that the keyboard may be damaged. The user is considering purchasing a replacement keyboard.
