Panasonic TC-21B3EE: How to Connect a DVB-T Tuner - Recommended Models & Step-by-Step Guide
strusio master 5472 9
Can I connect a DVB-T tuner to a Panasonic TC-21B3EE, and how do I hook it up?
Yes, you can connect any ordinary DVB-T tuner to this TV using the rear AV inputs and a SCART-to-4-RCA (“4 chinch”) cable [#12457483][#12454923] Plug the tuner into the back of the TV, not the front, then switch the tuner and the TV to AV and look for picture and sound [#12457483] The advice was to use a 4-RCA cable because with a 2-RCA cable some needed signals may be missing [#12457483] If you want an easier setup for an older TV, you can also use a tuner with a built-in modulator, but that lowers picture quality because the signal is converted more than once [#12457522][#12461254]
  • #1 12454283
    strusio master
    Question how in the subject whether it is possible to connect Panasonic TC 21BEE to a tuner for digital TV, so please enter the name of the tuner and a brief description of how to do it.
    Thank you in advance for your reply and greetings :)
  • #2 12454923
    mirex
    Help: 1950
    Rate: 1990
    strusio master wrote:
    can I connect to the Panasonic TC 21B3EE to connect the digital TV tuner
    Can be.
    like this, please give me the name of the
    tuner
    Everyone available.
    Suitable cables, from the rear.
  • DVB-T tuner compatibility with Panasonic TV’s available connections
    #3 12456270
    strusio master
    will a regular DVB T tuner fit?
    this is the TV of my grandfather :P (I am still in college and I will come to him in a month) and I do not have a visual access to the TV to estimate what he has in the back, but from what I saw in the pictures on the net there are only exits "aux" without any euro-style cubes.
    I see only such connections in these pictures
    so I'm asking if it's possible to connect?
  • Use a four-RCA Euro-SCART cable for tuner connection
    #4 12457483
    egon42
    Level 37  
    Help: 358
    Rate: 825
    A colleague's problem has been described hundreds of times, you have to read this statutory requirement. you need to buy a euro cable for 4 chinch and connect why for 4 because then you have out of euro 2 input signals and 2 output as you would buy for 2 chinche it would turn out that just come out of these signals you need. At 4 chins, you connect 2 and 2 are free. If you have a cable, you turn on the tuner and tv on AV and you are looking for a vision as you have a vision, you are looking for a voice for that. It's good to have a tuner already programmed because then the voice will work. Of course, the tuner is connected to the back of the TV not from the front !.
  • #5 12457522
    KIEROWCA_VW
    Help: 273
    Rate: 676
    Or a tuner with a built-in modulator, more expensive but makes life easier with old televisions, where often there is no remote control, the replacement remote control will not start the AV mode or the older person does not embrace the entire procedure of starting the equipment.
  • #6 12458371
    strusio master
    thanks for explaining :) and someone could send a name to such a tuner so that it can be plugged in without problems (I'm not talking about a tuner with a modulator just plain cinch)
    I would make a present and allegro bought for my grandfather :P
    and what is going on the topic search option alone, believe it, I've read it a bit.
    I've already got a good article and I know everything :)
    thanks to everyone for the posts.
    Greetings.
  • Built-in modulator simplifies old TV use but degrades image
    #7 12461254
    egon42
    Level 37  
    Help: 358
    Rate: 825
    KIEROWCA_VW wrote:
    Or a tuner with a built-in modulator, more expensive but makes life easier with old televisions, where often there is no remote control, the replacement remote control will not start the AV mode or the older person does not embrace the whole procedure of starting the equipment.
    The problem is that the image from the modulator is worse because the digital signal is converted to analog from the analog is made high frequency signal sent to the TV and again from the high frequency low frequency analog signal is made for what in this tv can be sent directly to tv low frequency signal.
  • Older users can adapt to manual AV source selection
    #8 12461286
    mirex
    Help: 1950
    Rate: 1990
    Egon, this TV does not matter anymore. ;)
    Although in other cases you are right, of course.
    I also do not understand
    Yes, it's difficult. However, whether with a modulator or without it, and so you need two pilots for daily service.
    So whether the TV will stay on the program or whether it should be switched to AV, it's a trifle.
    Also, the option of not working the remote control is slightly stretched in this case, because older people generally use the main switch on the TV. Therefore, press one more key on the panel too, they will get used to it.
    I do not know, unfortunately, I do not remember whether this TV has no option of automatically switching to the last selected source after switching it on. ;)
  • #9 12461435
    KIEROWCA_VW
    Help: 273
    Rate: 676
    This may be somewhat out of the question, since the author has already found a solution: the lack of a remote - I have already encountered several TVs that do not have an option on the panel to switch to AV, it is possible to get this function by pressing several buttons simultaneously, or in the appropriate order but such an operation is difficult to implement for an older person ...
  • #10 12461693
    mirex
    Help: 1950
    Rate: 1990
    But he owns it.
    And we talk about it, not some fancy one.
The Panasonic TC-21B3EE can be connected to a DVB-T tuner using suitable cables. Users recommend a euro cable with four RCA (chinch) connectors to facilitate the connection, allowing for two input and two output signals. It is essential to connect the tuner to the back of the TV and switch to AV mode to access the digital channels. For ease of use, especially for older individuals, a tuner with a built-in modulator is suggested, although it may result in lower image quality due to the conversion from digital to analog signals. The discussion highlights the importance of ensuring the tuner is pre-programmed for optimal functionality.
