Opel Vivaro vs Renault Traffic: Differences, Parts Availability, and Usage Insights
tehaceole 50187 9
What are the differences between an Opel Vivaro and a Renault Trafic, and what should I know about parts availability and ownership costs for a used one?
Opel Vivaro and Renault Trafic are basically the same van, so the differences are mostly in badges and small styling details, and parts availability should not be a problem [#12498399][#12498529] For a used 7–8 year old car, the key is condition and service history: if you do not know when the timing belt was replaced, change it first, because it is the most important item; then do oil and filters [#12498399][#12498677][#12499400] The 1.9 engines are considered sufficient in these vans, with examples of the 1.9 115 HP and 1.9 dCi 100 HP running well even at high mileage [#12498424][#12498529] One drawback mentioned is the rear heating system, which may not work well if the vehicle has separate front and rear controls [#12498424] When buying imported used examples, a car with a current TUV is generally a safer bet than one with only HU/AU or no inspection, and Benelux cars were described as often better maintained and less rusty [#12498677]
  • #1 12498358
    tehaceole
    Help: 102
    Rate: 212
    I am planning to buy an Opel Vivaro in L1H1 sheet metal. Could anyone point out the differences between the Renault Traffic?
    Why Opel? German... Although looking at Traffic, one has doubts. What about the availability of parts for these cars? What is the issue of exploitation?
    ST - SYSTEM
    Maszkowo 24 B, Maszkowo, 75-558 | Company Website: www.stsystem.pl
  • #2 12498399
    Robert 1960
    Level 32  
    Help: 238
    Rate: 408
    Hello !
    Whether it is Opel, Renault or Nissan, you will have the same - the differences are only a little in appearance, but not much - I have been driving Opel Vivaro and Renault Trafic for the last few years - only the name differs, there is no problem with the availability of parts, if it is a new car, warranty inspections every 30,000 km, timing belt every 150,000 km, observe and monitor it, there will be no problems at the service center!
    P.U.T. DOMSAT
    Ignacego Rzeckiego 4/39, Lublin, 20-637 | Tel.: 697XXXXXX (Show)
  • #3 12498408
    tehaceole
    Help: 102
    Rate: 212
    I`m aiming for a 7-8 year old car.
    What kind of bikes did you have under the hood, buddy? There are a lot of cars with an 80 HP engine, but I am biased towards such power for such a car. In the previous company I drove a VW t5 with 175 horses - this route was pure pleasure :)
    ST - SYSTEM
  • #4 12498424
    Robert 1960
    Level 32  
    Help: 238
    Rate: 408
    Hello !
    It works very well with the 1.9 115 HP engine, I drove a passenger car - 9 seats with a driver, the drawback is the rear heating, in mine there were separate controls for the front and rear and when someone in the back turned on the heating when the car was not yet warmed up well, it was neither warm in the front nor in the rear, the heating system in these cars does not work, and apart from that it drives well!
    P.U.T. DOMSAT
  • #5 12498435
    tehaceole
    Help: 102
    Rate: 212
    I am interested in the option of 6 or 9 people, but at the moment the bed will be without the last row of seats and will be enclosed.
    Generally: the size and appearance of the car suits me best as a work car as well as a great vehicle for family escapades.
    ST - SYSTEM
  • #6 12498529
    krocze
    Help: 24
    Rate: 149
    In the 9-seater Trafic, the 1.9 dCi 100 HP engine was completely sufficient. The workers made a mistake twice and poured gasoline, and then diesel was added without removing the gasoline. Since new, the engine has covered almost 200,000 km without any renovation! I wouldn`t believe how much this engine can endure if I didn`t have contact with it. The only issue is that when buying an 8-year-old car, you don`t know whether the engine will require repairs after 300,000 km.
    As for choosing Vivaro/Trafic, it`s like choosing between Evasion/Zeta and Ulysse. Same car.
  • #7 12498551
    tehaceole
    Help: 102
    Rate: 212
    I absolutely count on it. So immediately oil, filters and perhaps timing. Unfortunately, I can`t find anything newer in my budget. Oh - let me just add that the car will be towed from the Netherlands or Germany. So theoretically it should be better than our domestic offers.
    ST - SYSTEM
  • #8 12498677
    krocze
    Help: 24
    Rate: 149
    Theoretically, yes, but it all depends on whether they will send you a car with a current TUV, which was driven until the moment of sale, or one with only HU or no inspection at all. Unless the TUV was purchased from a "Turk", in order to pass the TUV, the car must not have any damage, and all observations are included in the inspection documents - rust on individual chassis elements, etc. Therefore, a car with TUV is in better condition than the one with HU/AU which is granted for one year only. In general, I have noticed that cars from the Benelux countries are more neat/better maintained than those from Germany. The Jeep KJ imported from Belgium had absolutely no play in the chassis and no corrosion. It was expensive, but I wouldn`t buy it in this condition in the country.
    tehaceole wrote:
    oil, filters and perhaps timing belt immediately.
    Start with the timing, because it`s the most important thing. If it hasn`t been replaced for over 100,000 km or you don`t know when, it`s better to be safe. Only after that filters and oil.
  • #9 12499400
    tehaceole
    Help: 102
    Rate: 212
    krocze wrote:
    Theoretically, yes, but it all depends on whether they will send you a car with a current TUV, which was in operation until the moment of sale, or one with only HU or no inspection at all. Unless the TUV was purchased from a "Turk", in order to pass the TUV, the car must not have any damage, and all observations are included in the inspection documents - rust on individual chassis elements, etc. Therefore, a car with TUV is in better condition than the one with HU/AU
    Thanks for your VERY VALUABLE ATTENTION! Too bad I don`t see "helped" here. =/
    And from a service point of view: my wife has a Renault Clio 98. There are no major problems with access to parts. Prices are good too. But damn her car, for the specific month it comes from there are several dozen different variants of the same element. At the beginning of the year, the rods broke (a broken apple on the driver`s side) - it all ended with putting the car on jack stands and coming to the store with old, complete rods.
    That`s why I`m aiming more at the Vivaro than at the Traffic, thinking (perhaps naively) that there will be less trouble and confusion with Opel than with the French. I am basing this on knowledge about the availability of parts for the Opel Astra II owned by my parents.
    ST - SYSTEM
  • #10 12500943
    andrzej lukaszewicz
    Help: 626
    Rate: 2127
    After all, these colleagues have already written thattrafic/vivaro/primastar are the same, only with different badges.
    Consider seriously the version with a petrol engine (and there is one) + LPG. It will be 25% cheaper than diesel, and the failure rate of dci engines is very high.
    Other comparable cars are Ducato/jumper/boxer and certainly with better JTD or HDI engines.
The discussion centers on the comparison between the Opel Vivaro and Renault Trafic, focusing on differences, parts availability, and user experiences. Both vehicles are noted to be similar in design and functionality, with minor differences in appearance. Users report that parts availability is generally good for both models, especially for newer vehicles. The 1.9 dCi engine in the Trafic is highlighted for its durability, having performed well even under adverse conditions. Concerns about engine power and maintenance, particularly regarding timing belts and oil changes, are discussed. The preference for the Vivaro over the Trafic is partly based on perceived ease of obtaining parts and fewer variants of components. Additionally, the option of a petrol engine with LPG is suggested as a cost-effective alternative to diesel engines, which have higher failure rates.
