Comparing NICE ROBO500, CAME BX78, FAAC 414 Drives for 4m Sliding Gates with Wiśniowski OPTIMA 600
mangusta28 42243 16
How can I choose a reliable 4 m sliding-gate operator that can use my existing Wiśniowski 2K433 remotes together with the OPTIMA 600 sectional-door operator?
For a 4 m sliding gate, suitable options include FAAC 740/741, CAME BX Strong, or Nice Robus 350 if the gate is not particularly large; the choice should depend on the gate, price, and availability of local service, with correct installation being essential. [#12519456] [#12521317] The Wiśniowski 2K433 system uses an Eldrim receiver, and matching 433.92 MHz alone does not make receivers and remotes interchangeable. [#12522483] Add an external Eldrim receiver compatible with the selected FAAC or CAME control board so the existing remotes can operate both gates; Eldrim produces versions that fit the original connectors. [#12519456] [#12521317] On CAME equipment, the “frequency card” is simply the radio receiver, so it can be omitted when purchasing the controller and replaced by the compatible Eldrim receiver; Beninca models may have the radio soldered onto the board. [#12522866] Buy the operator and receiver as a matched package from one supplier and prioritize a competent installer and nearby authorized service. [#12524430]
  • #1 12516306
    mangusta28
    Rate: 18
    Hello everyone and apologies if I wrote in the wrong section.
    I am looking for a drive and gate that would be suitable for me.
    The gate is supposed to be 4m and be sliding (because it is said that tilting ones get unsettled and do not close properly after winter and there are problems with them).
    Let me know if this is true and what model you recommend, because I was thinking about NICE ROBO500 CAME BX78 AND FAAC 414 for a possible.
    The problem is that I already have a sectional gate Wiśniowski with OPTIMA 600 operator with elDrim eLQ16 controller and 2 2-button remote controls, and I would like one remote to operate both gates.
    Price-wise I would also rather a bit cheaper, but trouble-free.
    How about their warranty because I read that supposedly 2 years.
    Does anyone know what kind of radio is with this eldrim eLQ16 controller ?
    From what I've read, you would need to add a radio to the drive for example. CAME in addition to such a radio, which would operate the 2k433 two-channel remote control from wiśniowski
    Thanks for all the answers.
    kotbury
    Gantry automation specialist
    Help: 2104
    Rate: 3639
    I would add the FAAC 741 (clumsy but armored) to the list of possible drives for the screenings, and if the gate is not a giant I would give the Robus 350 instead of the Robo600 (much more modern than the Robo, which has a less established reputation in drives with 220V motors than the Faac 741).
    Choice a matter of personal preference, price and service available nearby. (the above-mentioned drives actually do not damage themselves mechanically, so the question of warranty repairs or after- it is only in the worst case to send the board with electronics to the service)
    Radio in Eldrim (at Wiśniowski) is also Eldrim production and as you wrote - leave the 2k433 remotes and add an external Eldrim receiver to the gate (to ANY above-mentioned control panel can be done) - he makes such.
  • #3 12519656
    mangusta28
    Rate: 18
    And what do you think about Beninca BULL 8M or 5M .
    Someone wrote somewhere that the gearboxes have all immersed in oil and have not had a case of any failure from the ones installed so far.
    I will honestly say that I am surprised by the price differences for example on allegro, and in online stores (even a few hundred zlotys). What is the point here ?
    And which company has the best service ?
  • #4 12521317
    andrzej lukaszewicz
    Help: 626
    Rate: 2126
    Those without oil( with solid lubricant) last just as long as those with oil - a matter of choice of materials. And oil can also leak and about then?
    The Eldrim company produces receivers adapted to the Came and Faac control boards, so you don't have to clip anything on the cables, just into the original connectors.
    Beninca already has a built-in receiver, which you pay for in the price of the set+ the additional cost of the eldrim radio. I would take faac 740/741 or Came BX Strong. Faac is faster than came and beninca. Faac has of the three the most elegant way to unlock the mechanism.
  • #5 12522253
    mangusta28
    Rate: 18
    And I could not, for example, in Beninka teach the remote control from Wisniowski to operate beninca ?
    Both in Beninca and Wisniowski from eldrim operate the same frequency 433.92MHz ?
    andrzej lukaszewicz wrote:
    The eldrim company manufactures receivers adapted to Came and Faac control boards, so you don't have to clip anything on the cables, just into the original connectors.
    Does that mean from what you write, that Came and Faac do not have built-in receivers :?: and I don't have to pay for them in the price + the additional cost of the radio :?: Because it seemed to me that each of them in the price has a receiver. 9095
    andrzej lukaszewicz
    Help: 626
    Rate: 2126
    Most remote controls work on this frequency and most are not interchangeable.
    These are parts normally bought separately. Any dealer can sell you a control board without a receiver , and this beninca model has this radio soldered into the board and programmed from this board.
    Personally I would also give up the original faaclight and safebeam photocells in favor of other nicer( applies to the lamp) and more durable(photocells) . My proven types I can give you on PW.
  • #7 12522519
    mangusta28
    Rate: 18
    That is, it is enough if I take the controller without remotes and without the radio and without the frequency card (or is the radio the card ?), and the radio I will buy from Eldrim, so that I can use the remotes I already have.
    Did I understand correctly ?
    I'm thinking about CAME for now, but I do not exclude FAAC.
    From these 2 I will choose as I find out where the closest to me is a company that services.
  • #8 12522866
    andrzej lukaszewicz
    Help: 626
    Rate: 2126
    The frequency card in came is just a radio receiver. Buy everything from one vendor. I'll give you directions ( PW) to a reliable source where they'll match you up with everything as you want and at one shipment price. I also advise you to install nylon gear strips instead of steel ones.
  • #9 12524430
    PrzyjaznyDom
    Rate: 28
    the basis of product reliability is good installation. Even the best drive can be poorly installed and you will not be satisfied.
    All the drives you have listed are worth considering.
    When it comes to Nice equipment, write to PW and I will recommend a proven company in your area. Buying from one supplier will guarantee peace of mind and possible hassle-free warranty issues in case of problems.
  • #10 12526287
    mangusta28
    Rate: 18
    andrzej lukaszewicz what about these leads ?
    I would be interested in buying only the necessary accessories (I don't need 4 sets of remotes, or emergency safe beam pics as well as radios from Faac or CAME).
    That is, the eldrim eLFAA/eLFAA-H radio for Faac, and the eLR/eLR-C2H for CAME ?
    I'm thinking right ?
    Here's the link:
    http://www.eldrim.pl/index.php/produkty/9-sterowania-radiowe
    NICE I don't take it (they wrote that the service sucks).
  • #11 12527340
    PrzyjaznyDom
    Rate: 28
    Nice service is the largest and fastest of the other companies listed.
    This also shows the number of actuators that are introduced to the market by Nice.
    There are failures, but on a scale similar to, or smaller than, those of competitors.
    Most of them are incorrectly selected actuators (to save money) or incorrect installation.
    Bad things are usually said about the service by installers who do not work directly with Nice.
  • #12 12529140
    mangusta28
    Rate: 18
    The problem is that the issue is that NICE service is ANTI-customer.
    Whatever you didn't do, it's YOUR FAULT and that's the problem.
    For me, this approach = NO WARRANTY - count on yourself.
    As long as this approach to the customer, the customer (read ME) has somewhere to go with the products of these companies.
  • #13 12529237
    PrzyjaznyDom
    Rate: 28
    I never had such a problem with their service. If there is a warranty card (filled out correctly), actuators properly installed then in my case they have always gone along.
    After the warranty there is always access to parts and the possibility of repair in 24 hours.
  • #14 12529483
    mangusta28
    Rate: 18
    You can see, every seller / installer is a different opinion.
    Everyone praises what he sells - and what is to do here someone who does not know ?
    I'll look for an authorized service closest to me and decide which one I choose.
    Greetings and thank you for all the answers.
    Orientally I know that any good, as long as a good installer was.
    How to know a good ?? Someone will say ?
  • #15 12530001
    PrzyjaznyDom
    Rate: 28
    Someone has to be believed. Talk and judge for yourself if someone is worth trusting.
    With this praising of your own is not quite as you say.
    I recommend and sell what I am sure of and have no problem with. I don't want to have unhappy customers and drive to failures.
    If you decide to Nice write on PW I will recommend a good installer in your area.
  • #16 12544256
    andrzej lukaszewicz
    Help: 626
    Rate: 2126
    PrzyjaznyDom wrote:
    I recommend and sell what I am sure of and have no problem with. I don't want to have unhappy customers and drive by failures.
    As there are a lot of companies and models on the market ( also a lot of successful and reliable ones) there will be a lot of equivalent proposals here.
  • #17 21498147
    mangusta28
    Rate: 18
    For those interested, I write that I bought a FAAC 740, installed and programmed the remotes myself. Everything works so far.
The discussion focuses on selecting a reliable drive system for a 4m sliding gate, comparing NICE ROBO500, CAME BX78, FAAC 414, and Wiśniowski OPTIMA 600 with elDrim eLQ16 controller. Sliding gates are preferred over tilting gates due to winter-related operational issues. FAAC 741 and Robus 350 are also recommended alternatives, with FAAC noted for faster operation and elegant unlocking mechanisms. The elDrim eLQ16 controller uses a 433.92 MHz frequency, compatible with Eldrim-made external receivers that can integrate with various drive control boards, allowing use of existing remotes. CAME and FAAC drives typically do not include built-in receivers; these are purchased separately, unlike Beninca models which have integrated receivers. Warranty periods are generally two years, with service quality varying by region and installer competence. NICE service is debated, with some users reporting poor customer support, while others highlight its extensive market presence and fast parts availability. Proper installation is emphasized as critical for drive reliability. Nylon gear strips are recommended over steel for durability. The author ultimately purchased and installed a FAAC 740, reporting satisfactory operation.
