Faac Gate vs Nice Gate: Comparing 414, S418 & Nice Wingo 2024 Full Swing Gate Automation Sets
korzachowski 8739 7
  • #1 16516142
    korzachowski
    Rate: 20
    I want to buy an automation for an opening gate.
    I found 3 sets.
    Which will be the best of the three at the moment and why the better than the others I have mentioned
    thank you
    1) DRIVE FOR NICE WINGO 2024 swing gate (full set) for PLN 1,545.00
    2) Original full FAAC 414 + lamp + 3x remote control (31f) for PLN 1,495.00
    3) Set for FAAC S418 2024 swing gates - full set for PLN 1,685.00
    Moderated By Marek J.:
    3.1.16. Do not post questions that are easily answered on the Internet or in the electrode forum.
    3.1.15. Do not ask immediately on the forum if you have not checked anything yourself or have not attempted a self-diagnosis. Remember that advice is provided remotely in the absence of physical access to the device, the problem must be very well described and understood by users ...
  • #2 16516371
    Marek J.
    Help: 526
    Rate: 951
    Which Holidays are more important? Easter, Christmas, Kurban-Bajram or maybe Hanuka?
    I am asking because I want to define myself about Faith ... :please:
    Sorry for the sarcasm, but what question is the answer ... You did not write what gate, how much it weighs, what filling, what posts, what frequency of work, are there bump stops, what opening angle, what security do you require, what budget do you have, etc. etc ...
    Please take a look at the forum (topic raised many times), use the search option and then, if you do not find an answer, ask smart questions. :D
  • #3 16516379
    korzachowski
    Rate: 20
    Can you judge from the photo ???
    - how much it weighs I do not know .... how can you estimate based on a photo
    - what security also do not know. the difference between these gates is also the price of such a 150 PLN difference in more or less.
    I know that maybe I require a lot, but please understand me - more or less I need to know this before the fitter will install anything
  • #4 16516394
    Marek J.
    Help: 526
    Rate: 951
    I am not a fairy, but ...
    The gate is quite heavy (forged or forged dummy), wide posts (you need to look at the assembly dimensions in the instructions), no bumper at the closed gate (it would be good if it was ...)
  • #5 16516534
    suworow
    Help: 650
    Rate: 1278
    korzachowski wrote:
    before the installer mounts anything
    Why do you think a fitter will mount anything? He should explain to you the differences in the operation of individual drives.
    best regards
  • #6 16521777
    andrzej lukaszewicz
    Help: 626
    Rate: 2126
    Well, unfortunately, sometimes they assemble anything, because they may have such a wingo for this gate + free forging 2 bricks from a post, unfortunately very popular with us ...
    Out of those given, the most sensible would be 414, but with a stroke of at least 400mm, because you won't put on 300. Wingo is out and so is the S418.
    414 is very easy to unlock from the outside, also unfortunately in such an openwork gate.
    Consider e.g. bill 40 actuators with key locks if this is important to you.
  • #7 16522168
    janek ie
    Help: 8
    Rate: 17
    Hello, I would personally choose the Facc company, from my experience, this company is already from the highest level, but as a colleague wrote, you need a lot of factors, where and how to choose a system for the gate, what matters most is the width of one leaf and whether the gate is heavy and whether it is not it is full, because it also counts, you also need to look at how many cycles it will have in the hour because often the gesture happens that the gates open every 2 minutes and after half of the hour they stop working and the motors melted
  • #8 16522812
    Daro1003
    Help: 295
    Rate: 609
    Wingo3524 is designed for brick posts without forging bricks. Additionally, there is no need to install limiters for opening and closing in this model.
The discussion centers around selecting the best automation system for swing gates among three options: Nice Wingo 2024, FAAC 414, and FAAC S418. Key considerations include the weight and dimensions of the gate, the frequency of use, and the specific requirements for security and unlocking mechanisms. Users express a preference for the FAAC brand, citing its reliability and performance, particularly the FAAC 414 model, which is noted for its ease of unlocking and suitability for heavier gates. The Nice Wingo 2024 is mentioned as less favorable due to its design limitations, while the FAAC S418 is also considered but not as optimal as the 414. Overall, the FAAC 414 is recommended for its balance of features and performance.
