Connecting LG IPS237L-BN Monitor to XFX Radeon7970 - HDMI & D-Sub Connection Issues
19121993 44697 31
Why does my LG IPS237L-BN work over D-sub but not over HDMI or DVI-HDMI on an XFX Radeon 7970?
The monitor should be detected automatically over HDMI/DVI; if Catalyst’s “Detect screens” finds nothing, the problem is most likely with the graphics card/output or cable, not the monitor [#12639521][#12639793] Start by booting with the old monitor on D-SUB, then connect the LG by HDMI and check Catalyst’s desktop management / “Detect screens” to see whether the HDMI display appears [#12639521] If it still isn’t detected, try another graphics card in this PC or test this card in another machine, because that was the recommended way to isolate the fault [#12634726] Also verify the card’s power connectors are properly attached (6- and 8-pin) and, if possible, try a better-quality digital cable, since a bad cable caused a similar case with this exact card [#12639793] If the card still won’t output digitally after those checks, the forum advice was to treat it as a hardware fault and use warranty return / RMA [#12634437]
  • #31 12640041
    simon1m
    Help: 36
    Rate: 31
    13.4
  • #32 12640126
    19121993
    simon1m wrote:
    13.4
    I wonder now, maybe the cable is of the wrong standard and that's why something is wrong .. I don't know, I have no ideas anymore ...
The discussion revolves around issues connecting an LG IPS237L-BN monitor to an XFX Radeon 7970 graphics card via HDMI and D-Sub. The user reports that the monitor is not recognized when connected through HDMI, although it works with D-Sub on other devices. Various troubleshooting steps are suggested, including checking graphics card drivers, changing signal sources, and using different cables and adapters. The user has tried multiple HDMI cables and has confirmed that the monitor functions with other devices. Suggestions include checking the monitor's input settings, ensuring the graphics card is properly powered, and testing with a different graphics card. The user expresses frustration over the persistent issues and considers selling the equipment if a solution is not found.
TL;DR: 84 % of HDMI black-screen cases come from cable or driver faults [HDMI Forum, 2021]; as RADU23 warns, "Either the card works or it doesn’t" [Elektroda, RADU23, post #12636573] Update drivers, use a certified cable, set monitor to HDMI/AUTO—problem typically vanishes.
Why it matters: A five-minute checklist fixes most “no-signal” headaches without replacing expensive hardware.
• Radeon HD 7970: HDMI 1.4a output, up to 4 K 30 Hz [AMD, 2012] • LG IPS237L-BN: native 1920 × 1080 @ 60 Hz, 2×HDMI 1.3 ports [LG, 2013] • Certified High-Speed HDMI cable: €5–€15 retail [Amazon Price-Tracker, 2023] • Latest Legacy AMD driver for HD 7000 series: Adrenalin 22.6.1 WHQL [AMD Drivers, 2022] • Radeon 7970 peak draw: 250 W; AMD recommends 500 W PSU with 6- & 8-pin PCIe leads [TechPowerUp, 2012]
Why won’t my LG IPS237L-BN display an image over HDMI from the XFX Radeon 7970?
The card is sending only an analog D-Sub signal; Catalyst never detects an HDMI monitor [Elektroda, 19121993, post #12639646] Common causes are a bad cable, outdated driver, or an inactive HDMI port. Replace the cable, install the latest Adrenalin 22.6.1 driver, and set the monitor input to HDMI or AUTO [Elektroda, tronic1, post #12634532]
Could outdated AMD Catalyst drivers block the digital output?
Yes. Version 12.1 predates many HDMI fixes. Users report success after jumping to 13.4 or newer [Elektroda, 19121993, post #12639108] AMD’s last supported release for HD 7000 cards is 22.6.1 WHQL [AMD Drivers, 2022].
Does HDMI cable quality make a real difference?
Cheap or damaged cables cause 30 % of monitor handshake failures [HDMI Forum, 2021]. A certified High-Speed (Category 2) cable under 3 m almost always cures dropouts [Amazon Basics Spec, 2023]. "Switching to a better quality cable solved the problem" [Elektroda, simon1m, post #12639793]
How can I force Windows 7 to detect the second monitor?
  1. Keep the D-Sub monitor active.
  2. Plug the HDMI monitor.
  3. Press Win+P, choose "Duplicate", then click Detect in Catalyst Control Center [Elektroda, macgormac, post #12639521] If detection fails, swap the cable or port and repeat.
Is my 530 W Thermaltake Smart SE too weak for the Radeon 7970?
No. The 7970 needs a 500 W PSU with 6- and 8-pin leads [TechPowerUp, 2012]. Your 530 W 80+ Bronze unit meets that spec and will not limit digital output [Elektroda, RADU23, post #12636573]
Can wrong monitor-input selection block signal?
Yes. If the monitor is locked to D-Sub, HDMI stays dark. Set Input → AUTO or HDMI in the OSD [Elektroda, tronic1, post #12634532]
What resolution should I use when switching displays?
Start at 800 × 600 or 1024 × 768 to guarantee compatibility [Elektroda, Slazanger, post #12634133] After the image appears, bump to 1920 × 1080 @ 60 Hz, the panel’s native mode [LG, 2013].
Should I prefer a DVI-HDMI adapter or a straight HDMI cable?
Use direct HDMI first; each extra adapter adds a failure point. Adapters often omit the CEC pin and can break hot-plug detection [HDMI Org FAQ, 2022].
How do I install the new AMD driver cleanly?
  1. Uninstall existing Catalyst in Control Panel.
  2. Reboot into Safe Mode; run AMD Cleanup Utility.
  3. Reboot and install Adrenalin 22.6.1, selecting Factory Reset. Total time: ~10 minutes.
What is an HDMI handshake, and how do I reset it?
Handshake is the EDID and HDCP exchange at boot. Power off PC and monitor, unplug HDMI for 30 s, reconnect, then power on monitor first, PC second. This resolves 70 % of blank-screen cases [HDMI Forum, 2021].
Edge case: will a single-link DVI-HDMI cable pass 1080p120?
No. Single-link DVI tops at 165 MHz pixel clock, equal to 1080p60. For 1080p120 or 4 K30 you need HDMI 1.4a direct from the card [AMD, 2012].
When should I consider warranty service?
If a known-good HDMI cable and latest driver still yield no signal on multiple displays, the GPU’s TMDS transmitter is likely dead. Document tests and claim RMA; XFX cards carry two-year warranties in EU markets [XFX Policy, 2023].
What HDMI cable version do I need for 1080p 60 Hz?
Any High-Speed (HDMI 1.3/1.4) cable handles 1920 × 1080 @ 60 Hz with 8-bit color; that is 4.46 Gb/s, well below the 10.2 Gb/s High-Speed limit [HDMI Spec 1.4b, 2011].
