WIFI IP camera - does not connect to the "external" operator outside t
EMER12 48735 12
How do I configure my Wi‑Fi IP camera so I can view it from outside my home network, not only from the same Wi‑Fi?
Set up port forwarding (virtual server) in the router so incoming traffic on the camera’s port(s) is redirected to the camera’s local IP address [#12785515][#12786359] Check the camera manual for the exact ports to forward; the example in the thread uses port 70–70 for camera IP 192.168.1.105 and enables the rule in the router [#12786506][#12786545] After that, access the camera from outside using your public static IP address, and if the IP were dynamic you would also need a DYNDNS service [#12785515] The thread’s final fix was exactly to provide the Wi‑Fi IP camera’s ports in the router settings [#12786636]
  • #1 12785369
    EMER12
    Rate: 28
    I bought a wifi IP PTZ camera, which I installed on the wifi router according to the instructions. After turning on the computer connected to the same wifi network, I have a preview from this camera, the same on the phone, after connecting the phone (samsung galaxy S II on android) to the home wifi network to which the camera is connected, I also have a preview of the camera image on it . But the problem starts when I turn off the wifi on my phone and turn on the packet data offered by my network (play in this case), (I don't have exhausted limit in this packet!). I can't connect to the camera, I can't preview the image from the camera. The same happens when a friend at home on his wifi tried to connect to my camera - no access.
    Therefore, I am asking for urgent help.
    I would like to mention that when it comes to computer science, I have little idea, so I am asking for simple vocabulary and the simplest possible hints.
    Regards.
  • #2 12785515
    Marek31415
    Help: 148
    Rate: 97
    You need to redirect the ports used by the camera to the camera's IP in the router.
    You didn't specify the model of the camera or router, so it's impossible to tell more.
    If you have a fixed public IP on the router, then you can connect from the outside by typing this IP and possibly the port number after the colon. If the external IP is dynamic, you still need to register some DYNDNS service. You didn't specify who your ISP is, so I can't tell you more.
  • #3 12786331
    EMER12
    Rate: 28
    My router is Pentagram Cerberus P6360
    Camera ... on the box it says IP Camera ... and that's it.
    My internet provider is the "Komster" company operating near Poznań.
    I called them and they told me that I have a permanent IP address that they gave me, and in a conversation with a friend I got information that I have a permanent public IP and I have a static external IP...
    Ps. It's black magic to me...
    Moderated By Mirek Z.:
    I removed the link to the allegro. https://www.elektroda.pl/rtvforum/faq.php - p.3.1.18.
  • #4 12786359
    sosarek
    Help: 9320
    Rate: 15532
    In that case, you need to forward the incoming ports on the router to the specific IP address of the camera and everything should work.
    Z
    Pka, Poznań, 60-850
  • #5 12786465
    EMER12
    Rate: 28
    I go to the router settings: 192.168.1.100 and it does not accept the password, I can't get further .... I fart ... :(
  • #7 12786494
    EMER12
    Rate: 28
    I'm already in, what's next?
    And it is not possible to share the camera by entering its IP in the virtual server in the router settings?
  • #8 12786506
    sosarek
    Help: 9320
    Rate: 15532
    1. Instructions from the router in hand, learn how to enable port forwarding.
    2. Then, from the camera manual, find out what ports you need and configure the router.
    3. If it's still black magic, I suggest starting with point 1
    You can try, but you still need to define ports for a given IP address in the network (camera).
    Z
    Pka, Poznań, 60-850
  • #9 12786530
    EMER12
    Rate: 28
    Now it's about entering the camera data?
    because I entered the initial and final port: 70-70 the one on which the camera is running,
    IP address in the LAN such as the camera has, e.g. 192.168.1.105
    In the protocol, I marked common and marked enable
    I don't know if I'm doing it right
    sosarek
    Help: 9320
    Rate: 15532
    How do you know that the camera is running on port 70? Do you have any way to configure it (besides entering the IP)? So far it should match.
    Z
    Pka, Poznań, 60-850
  • #11 12786609
    EMER12
    Rate: 28
    I have configured everything as it should be :) The camera is walking :D
    Thanks for the help saucers :D
    sosarek
    Help: 9320
    Rate: 15532
    It's okay, the most important thing is the effect :)
    Z
    Pka, Poznań, 60-850
  • #13 12786636
    EMER12
    Rate: 28
    The solution to the problem is to provide ports for the WIFI IP camera in the router settings.
A user experienced difficulties connecting a WiFi IP PTZ camera to external networks after successfully accessing it on a local WiFi network. The issue was identified as a need for port forwarding on the router to allow external access. The user confirmed having a static public IP address from their ISP, Komster. After guidance on accessing router settings and configuring port forwarding, the user successfully connected to the camera externally. The solution involved entering the camera's IP address and the correct port settings in the router's virtual server configuration.
