IP DDNS Camera & Connect Box Configuration for Remote Access via Phone Outside Local Network
mat999111 3957 6
  • #1 16743480
    mat999111
    Hello. The problem is to configure the Connect Box with an IP camera in the home network, everything works but the problem appears if I would like to log in to the camera from a phone outside the local network.
    Complete lack of logic, despite the fact that he enters the DDNS server data and when he enters the external IP address in the browser, nothing happens and the Connect Box should turn on.
  • #3 16743597
    mat999111
    IP CAMERA MODEL: ZD-JHI200E-V7
    Modem: HUB3.0
    Vendor: Vrgin media (UPC)
  • #4 16744436
    sosarek
    Help: 9318
    Rate: 15495
    Even Google can't find it ...
    If it supports cloud / Cloud / p2p use it to connect to the camera.
    Z
    Pka, Poznań, 60-850
  • #5 16748851
    mat999111
    Hello, I looked for a bit again and found a camera that looks the same and has the same parameters. Model: QJHI200E-V7
    Is it possible to connect to it from outside the local network ??
    Added after 6 [hours] 33 [minutes]:
    Does anyone know if I have filled in the fields correctly?
    I created an account on NO-IP.COM.
  • #6 16756253
    sosarek
    Help: 9318
    Rate: 15495
    No p2p option somewhere?
    Which internet provider do you use?
    Z
    Pka, Poznań, 60-850
  • #7 16765483
    mat999111
    Unfortunately there are no p2p settings.
    Internet in the UPC house
    Internet in UPC phone
    The connection was established a few times, but unfortunately it broke and it is not a problem with variable IP.
    Unfortunately, I'm still fighting.
    Added after 10 [minutes]:
    And a bit different from the topic, you do not know why when you connect to cameras, there is no full image quality but only as (sub stream)?
✨ The discussion revolves around configuring a Connect Box with an IP camera (ZD-JHI200E-V7) for remote access via a mobile phone outside the local network. The user reports successful local access but encounters issues when attempting to connect externally, despite entering DDNS server data and using the external IP address. Suggestions include checking for cloud or P2P options, which the user confirms are unavailable. The user also mentions using NO-IP.COM for DDNS and expresses frustration over intermittent connectivity issues and suboptimal image quality when accessing the camera remotely.
