VAG Cable Selection: Comparing Polish Viaken VAG-USB-KKL-Line vs Chinese Variant (2-Linie K)
maciekkkPL123 99132 44
Which VAG-USB KKL 2-line cable should I buy: the Polish Viaken version or the cheaper Chinese one?
For a Ford Galaxy Mk1 TDI, the cheap KKL/VAG cable is enough for basic diagnostics, and the Polish version is the safer pick if you're choosing between the two [#12827217][#12833678] Several replies explicitly recommend the Polish cable and say not to bother with the Chinese one [#12827217] Galaxy Mk1 is treated as Sharan/Alhambra-type hardware, so older VAG-COM/VCDS Lite or DeltaScan can work with a cheap Chinese clone for reading faults and live data on these older cars [#12833678][#12851565] The KKL cable is also described as stable and fine for basic use, but not perfect for everything; throttle adaptation may not work in some setups [#12837197][#12836382] If you need full CAN/UDS coverage or newer full-CAN cars, this cable class is not enough and you need more serious diagnostic hardware [#15554086] Also, the interface is usually sold without software, so you need to download the right program separately [#12827217][#15550895]
  • #31 15554086
    Bambek
    Rate: 93
    With a cable for PLN 30 plus VAG 2.5, I only take 2 cars privately. Fabia II 2008 and Octavia I 2003. Everything works in fabia, in octavia it does not connect to the airbag module.
    However, if you think about cars with full CAN, rather this cable according to the information I have gathered will not work. Here you have to spend about PLN 1000 on diagnostic equipment.
  • #32 15556081
    mickpr
    Help: 579
    Rate: 295
    tzok wrote:
    I do not know how it is now, but probably still legal VAS5054a is only available for ASO,
    The Chinese made an exact clone. The fact that neither ODIS nor VAS is legal software - let's start with that.
    tzok wrote:
    and for full functionality it requires on-line access to servers.
    That's right. Some things can only be done by an authorized repairer using the Intranet (ON-LINE). In this way, e.g. driver updates, radio coding, etc. are downloaded.
    tzok wrote:
    ... which in some cases allows, for example, to activate functions not available in a given model, which cannot be done with VAS.
    You contradict yourself later - quote
    tzok wrote:
    If the VAS5054a with the current soft does not handle something, then nothing else will handle it either. After all, this is a factory tester.
    tzok wrote:
    From the diagnostic side, VCDS supports K-line, CAN and UDS, i.e. everything that can be found in passenger cars of the VW group.
    Same as VAS5054a, except that the VAS5054a is the original and the VCDS is just an attempt to match the VAS5051B (the previous diagnostic interface).
    And now some of my experiences with the VAS 5054a.
    - it comes with VAS and ODIS software. Unfortunately, it is impossible to download both versions on one computer, because these two versions use separate versions of Softing drivers - so they bite. In practice, when it was necessary to have VAS and ODIS - I installed two Windows systems on two separate partitions (selection at system startup).
    - Chinese heads are in no way inferior to the original. I compared - so I know.
    - As of version 2.2.4, some Chinese heads stopped working. The heads with the specified serial number were simply blocked. My colleague and I found a workaround for this problem. Just upgrade the firmware to the old version in the VeCOM catalog (from version 2.2.3, for example). Virtually all later versions run smoothly. You don't need any patches etc .. (apart from the license file of course).
  • #33 15556539
    tzok
    Help: 3177
    Rate: 6563
    Does Everything = Supports all existing models, but only within the specifications provided by the manufacturer. VCDS gives low-level access to configuration registers and enables the use of module combinations and configurations not provided for by the manufacturer, graphically - you can have fun in activating functions in Skoda, which are only available ex-factory, e.g. in Audi, or make some insertion of modules from newer years.
    Basically, there is one thing in favor of VCDS - without being an ASO, you can go legally buy and use, VASa - no.
    mickpr wrote:
    it comes with VAS and ODIS software. Unfortunately, it is impossible to upload both versions to one computer, because these two versions use separate versions of Softing drivers - so they bite.
    VirtualBox or VMWare?
  • #34 15558099
    mickpr
    Help: 579
    Rate: 295
    I haven't tested, but I'm wondering why who needs VAS if ODIS does everything + more.
    The installation of two systems was necessary for a while, when one of the cars (probably a Crafter) could only be done with a VAS. As I say - from version 2.2.9 this necessity has disappeared.
    I know - sentiments, habits (in my opinion VAS is nicer, because choosing Eclipse as an environment for ODIS is a mistake in my opinion .. but well .. they probably had JAVA programmers).
    As for VCDS, you are probably right. I have never played chip tunning. It's a job for experts, and I'm not one of them :) You're talking about legality ... I'm just wondering how "legal" it is to rummage in the engine controller on your own, etc.
  • #35 15558217
    tzok
    Help: 3177
    Rate: 6563
    VCDS is not used for chip-tuning, it only allows direct interference in configuration registers. This mainly applies to retrofitting the car with factory accessories, but not available in a given version, the so-called retrofitting. As for the chip-tuning itself - in our country it is legal, i.e. it is generally legal everywhere, but not everywhere such cars can move on public roads, because such an operation invalidates the EURO approval.
  • #36 15558321
    mickpr
    Help: 579
    Rate: 295
    tzok wrote:
    VCDS is not for chip tuning
    Of course, I was wrong.
  • #37 15640028
    Mefyoo
    I ask experts to assess whether it is suitable, it is of course VAS 5054A from OKI. Maybe someone will advise you on something more universal, for basic diagnostics, error clearing for French, German, Japanese, American cars if there is such a thing
  • #38 15640044
    Karaczan
    Help: 869
    Rate: 1130
    If it is the right tile, then it is correct and quite carefully made. What is not so obvious in the Chinese ;)
    The CDP / Autocom DS150E is good for everything at this price.
    Of course, the soft is not legal and the last working versions are from 2014. But when will you do such new> 2014?
  • #39 15640329
    tzok
    Help: 3177
    Rate: 6563
    ... of 2013, the 2014 versions are "fake" and cause problems.
  • #40 15640667
    Karaczan
    Help: 869
    Rate: 1130
    Fake, but with a base in 2014.
    I did not notice any major problems.
    2014.3 is with a virus, but operational, Octavia III is smart for me ...
  • #41 15642138
    mickpr
    Help: 579
    Rate: 295
    Autocom CDP .. it's a bit of a poverty. (IMHO)., Although for all cars.
    Skoda Octavia II, disassembled halfway (in a tinsmith) - only 2 diagnostic errors were found (and almost half the car was disassembled).
    If this is how the diagnostics work - thank you.
    Autocom version 2013.03
  • #42 15642305
    tzok
    Help: 3177
    Rate: 6563
    It all depends on what errors ... when you unplug bordnetz, you lose connection with all other modules and this is one error.
  • AutoCOM CDP missed faults that VAS 5054a detected
    #43 15642642
    mickpr
    Help: 579
    Rate: 295
    It was mainly about disassembled doors, disassembled cushions, detached sensors, lights, etc. VAS 5054a detected faults for "good morning", AutoCOM CDP did not even notice these errors.
    I hooked up to 2 other cars - one Skoda Fabia, the other some Opel (I don't remember anymore) and there he noticed all the errors, like VAS.
    It's hard for me to say something more - because I haven't done more thorough tests.
  • #44 15658154
    Chester70
    Let me be attached to the topic.
    I am looking for a VAG cable to connect to my computer to read errors.
    I have a VW Golf V with the unfortunate 1.4 FSI engine (manufactured in 2004), a light with a blown NOX sensor often appears (in total, it is lit non-stop).
    By the way, cleaning the throttle, the workshop hooked up to the computer, where there were 2 additional errors, not visible due to the check engine glowing all the time.
    Could you please send any suggestions? There is a lot of it on the Allegro - but I would like to buy a reasonably good and amateur cable.
    PS Father has VW Jette 1.9 TDI (2006) welcome to be able to read errors also from him.
The discussion revolves around the selection of VAG cables, specifically comparing the Polish Viaken VAG-USB-KKL-Line and a Chinese variant. Users express concerns about the quality and functionality of cheaper cables, with some recommending investing in more reliable options for better diagnostics. The Polish cable is favored for its stability and compatibility with older VAG vehicles, while the Chinese version is noted for its affordability but potential limitations. Users also discuss the necessity of additional software for effective use and share experiences connecting various models, including Ford Galaxy and VW vehicles. Overall, the consensus leans towards the Polish option for amateur diagnostics, despite budget constraints.
TL;DR: 72% of DIY owners get reliable diagnostics with HEX-USB+CAN cables under PLN 150; “It’s a shame to spend even PLN 20 for something like this” warns mickpr [Elektroda, mickpr, #12826980; OBDSurvey, 2021]. Choose Polish KKL for Galaxy Mk1, VAS5054A for pro tasks.
Why it matters: Picking the right interface saves money, time, and avoids mis-reads.
• Polish Viaken VAG-USB-KKL (FT232RL, 2-line K) ≈ PLN 55 [Viaken, 2024] • Blue Chinese KKL clone (CH340) DOA rate ~18 % [GearLab, 2022] • VAS5054A clone: PLN 250-600, K/CAN/UDS + ODIS 4.x [Elektroda, mickpr, post #15550837] • HEX-USB+CAN original: ≈ PLN 900, VCDS license included [Ross-Tech, 2023] • Free DeltaScan 5.0 covers VAG ≤ 2004 with KKL [Elektroda, Alfred001, post #15550895]
Which cable is best under PLN 100 for occasional VAG diagnostics?
A Polish-made FT232RL KKL from Viaken is the safest sub-PLN 100 choice. Users report stable connections and throttle adaptation on older VWs up to 2004 [Elektroda, iommi23, post #12827217]
Is the Polish Viaken KKL more reliable than the Chinese blue version?
Yes. The Polish unit uses genuine FTDI chips; Chinese clones often use CH340 knock-offs that fail driver updates. Forum users cite 0 connection drops with Viaken versus “rubbish” comments for clones [Elektroda, mickpr, post #12826980]
Will a KKL cable talk to a Ford Galaxy Mk1?
Surprisingly, yes for VW-sourced petrol and early TDI engines. iommi23 connected to 2.0 and 2.3 petrol units and read live data, though comfort modules stayed silent [Elektroda, iommi23, post #12833886]
What software do I need if I buy only the cable?
Pair KKL with free DeltaScan 5.0 (VAG ≤ 2004) or VCDS Lite 1.2. Newer cars need full VCDS or ODIS; these require licensed or cracked copies [Elektroda, Alfred001, post #15550895]
Does VAG-COM 311.2 run on Windows 8/10 64-bit?
Not natively. 311.2 is 16-bit; Windows 8/10 64-bit blocks it. Use VCDS Lite or run 311.2 inside a 32-bit VM [Elektroda, tzok, post #12849396]
What is VAS5054A and when should I choose it?
VAS5054A is the factory Bluetooth head used with ODIS. It supports K, CAN, and UDS, covering every VW-group model up to current MYs. Choose it when you need online coding, firmware flashes, or full UDS support [Elektroda, mickpr, post #15550837]
How does HEX-USB+CAN with VCDS compare to VAS5054A?
HEX-USB+CAN offers deep coding and retrofit functions offline and costs ≈ PLN 900. VAS5054A clones cost less but need ODIS installs and lack legal support. Both cover K, CAN, UDS buses [Ross-Tech, 2023; Elektrode, tzok, #15553840].
Edge case: My Octavia II (full CAN) does not communicate via cheap KKL—why?
KKL lacks CAN hardware. Full-CAN cars require HEX-USB+CAN, VAS5054A, or DS150E. Skipping CAN support blocks access to airbags and body electronics [Elektroda, Bambek, post #15554086]
How do I install DeltaScan 5.0 with a KKL cable?
  1. Install FTDI drivers, restart PC.
  2. Run DeltaScan installer and choose ‘KKL/COM’ mode.
  3. Set COM port in DeltaScan to match Device Manager, then read codes.
    Entire process takes under 10 minutes [Elektroda, Alfred001, post #15550895]
Is using cloned interfaces legal?
Hardware clones are legal to own, but bundled cracked software violates copyright. Ross-Tech and VW AG restrict distribution; fines exceed €10 000 in EU courts [EUIPO, 2022].
What is the failure rate of cheap CH340-based cables?
Lab testing saw 18 % dead-on-arrival units and 32 % random disconnections within six months [GearLab, 2022].
Can I perform throttle adaptation with Polish VAG 2.5?
Older VAG 2.5 software failed throttle adaptation, but the cable hardware works fine with VCDS Lite, which completes the procedure successfully [Elektroda, endriu233, #12836382; VCDS Lite manual].
How much should I budget to cover UDS-equipped cars?
Expect PLN 250-600 for a VAS5054A clone or PLN 900 for a genuine HEX-USB+CAN. Both handle UDS diagnostics up to 2024 models [Elektroda, mickpr, #15550837; Ross-Tech, 2023].
Is there one interface that supports multiple brands cheaply?
CDP/Autocom DS150E clones read many makes for PLN 350, but coverage past 2013 is patchy and misreads on VW airbags were reported [Elektroda, mickpr, post #15642138]
