Heater Return Valves: Hexagon Socket Adjustment, Unscrew Valve, Improve Radiator Flow
masiej2 106506 34
Can I completely unscrew the insert of a radiator return valve and cap it to improve circulation and radiator flow?
You can remove the valve insert and cap it after draining the system, but it is usually not the right fix and will not significantly improve flow; fully unscrewing the hex socket to the left already opens the return valve to 100% [#12903175][#12903792] If flow is still poor with the returns fully open, the problem is more likely elsewhere: a clogged pump filter, a blocked or partly closed supply valve/thermostatic head, too small pipe diameters, or another restriction in the installation [#12903792][#12907923] One reply also notes that opening the return more would only help a little at best, and that the real fault is probably dirt or a blockage in the system [#12903353] So the practical advice is to leave the return valves fully open, check the filter and the supply-side valves, and look for a restriction in the circulation path rather than blanking off the return valve [#12903792][#12907923]
  • #1 12902761
    masiej2
    Rate: 21
    I have a problem, or rather a query, I have valves on the return shown in the photo:
    To the point, I marked the thread on which the cover cap comes in green, the key can be put on red, and the hexagon socket in blue and turned to the right or left. My question is, if I put the key on what I have marked in red, can I completely unscrew the inside of this valve and plug it with a screw-on plug (marked in green)?
    I have the impression that the flow is poor, the radiators' pits are cold, the Allen adjustment probably does not work, I don't really have the patience for it anymore ... I just want to improve the flow. I messed up a bit with what I wrote, but I hope it is understandable.
    Thanks in advance for any answers. Sorry if I posted my question in the wrong section. greetings
  • #2 12902827
    W0jtek92
    Help: 469
    Rate: 1257
    Hello, since the return valve is open to full and there is still poor circulation, maybe it is to blame for the supply valve, or some dirt clogged the supply valve and you have poor circulation. What is the installation? What is the source of heat?
  • #3 12902833
    tompotter
    Rate: 27
    You can do that
  • #4 12902835
    Piotr77777
    Heating systems specialist
    Help: 58
    Rate: 266
    Open the return valve to the max. I suspect that the limited flow is influenced by the installation made of PP, not the return valve.
  • #5 12902846
    masiej2
    Rate: 21
    bake for everything :D 14KW. circulation pump 25/40 1 speed Installation of the PP pipe.
    Maybe it is to blame for covering, or also for dust, although I'm only interested in whether I can wring out this interior, blind it and whether it will work. I already have enough of these valves, I would like to change all of them to ball valves because you can get crazy. By the way, at what point is the return valve open to full?
    (as I burn in the stove, i.e. I start, I have, for example, 60 C at the exit, and the return may be 25 ... so something wrong with these returns, and after 15 minutes the return gets warm, but the supply temperature drops to 40 ... So it heats up quickly, flows worse, and cools down. And I would like a sensible circulation, on the furnace 60 return 50. Therefore, to my empty peasant mind, if I blow these inserts in the sense of the content of this return valve, the flow should be higher ????. The closed circuit installation (previously there was gas heating) worked well and the open circuit has problems.
  • #6 12902911
    Duduś74
    Moderator of HydePark
    Help: 71
    Rate: 225
    masiej2 wrote:
    (as I burn in the stove, i.e. I start, I have, for example, 60 C at the exit, and the return may be 25 ... so something wrong with these returns, and after 15 minutes the return gets warm, but the supply temperature drops to 40 ... So it heats up quickly, flows less well, and cools down.
    The temperature drops because the pump is turned on, and since it does not heat up (there is a large heat consumption), the stove is too weak.
    Enter the heating surface of the building, number and size (power) of radiators.
  • #7 12902923
    masiej2
    Rate: 21
    the pump is running all the time. It is not the fault of a poor stove or heaters.
    I mean the flow itself. It takes too long, it is too weak, and I just want to increase it. Not to raise the pump to 2nd or 3rd gear, but to stay in 1st gear, but to increase the flow.
  • #8 12902965
    Duduś74
    Help: 71
    Rate: 225
    Higher flow means that your stove will cool down even faster. But if you insist so, then since unscrewing the flanges at full does not give you anything, then, as the previous speakers wrote, you have clogged somewhere or too small diameter of the pipes, or too weak a pump.
    So:
  • #9 12903020
    masiej2
    Rate: 21
    heating area about 95 m2. 3 heaters 120cm v22, 3 heaters 180cm v22, and 2 small ladders in the bathrooms.
  • #10 12903103
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    14kW of boiler power is the "excess" power for this living area. Surely the cause of bad heating is poor flow. What are the radiator supply valves? If it is modern (with a thermostatic head), you can change the setting after removing the head. It may also be that the closure is OK, but the thermostatic head choked the flow because it sensed that the room has reached the set temperature (reducing the flow causes the radiator to become cool at the bottom, although generally more heat is needed from the legs than from the back) ). This may be the case sometimes, especially with oversized radiators. You need to check whether turning the thermostatic head to a higher temperature in the room will result in better heating at the bottom. If not, it is to blame (the thermostatic valve could also get fouled up) or too small cross-sections of the pipes.
  • #11 12903110
    MarudaP
    Help: 24
    Rate: 238
    Check the supply and return on all radiators to see if there are any big differences and how this will change when you turn the pump on at higher speed.
  • #12 12903135
    masiej2
    Rate: 21
    My radiators are mainly set to N or 7 (this is on the radiator supply) and on the return this "super" valve I do not know how to set, left or right? (hence the idea to twist the entire cartridge out, if anything is possible, in my opinion yes). The pump is on the return.
    If you set the pump to 2nd or 3rd speed, the highest radiator, i.e. the ladder in the bathroom, stops heating, while the pipe that goes to the vessel starts to heat less in the middle.
    so the supply heaters are warming up nicely, although the returns are cold. So, I repeat my "hello" question, can I unscrew the inside of these return valves and plug them? will this increase my expected flow so that the returns are also warm ??
  • #13 12903175
    MarudaP
    Help: 24
    Rate: 238
    Probably like all valves, by turning it to the left - we open, and right - we close. If it is a ball it is possible to make a turn by 90 *, if it is a regular one it is possible to make a few turns. The inside of the valve can be removed and plugged with a plug, but for this operation you need to drain the water from the system.
  • #14 12903180
    masiej2
    Rate: 21
    Thank you very much for the answer regarding the removal of the inside of the valve.
    Now the question is, will removing it and blinding it increase the flow ??
  • #15 12903332
    MarudaP
    Help: 24
    Rate: 238
    Probably not much. Rather, I suppose some muck is blocking the drain somewhere and a rinsing could be done. And by the way, don't you hear "trickling" somewhere?
  • #16 12903353
    Duduś74
    Help: 71
    Rate: 225
    You can unscrew the middle from the valve and screw the cap (of course with the gasket) and the flow may increase a bit. But the rule is, if the stove is "boiling," and the radiators do not heat up or heat up poorly, you have problems with heat reception, i.e. radiators too small, pipes diameter too small, choked radiators, pipes, etc.
    And if you can't reach the temperature on the stove, it means that the stove power is low.
    If it is an all-purpose stove, take into account that the power and efficiency of the stove are given for a specific type of fuel. For the most part (I omit wood gasification boilers) power and efficiency are given for hard coal. What does this mean in practice, while burning everyone, the power of such a furnace drops from the alleged 80 percent to about 50%, and later comes as a surprise: the furnace is OK, and it heats poorly.
  • #17 12903377
    masiej2
    Rate: 21
    I don't hear any strange noises. What is better to leave or wring out?
    I don't know anymore ...
  • #18 12903391
    MarudaP
    Help: 24
    Rate: 238
    The drain valve is for when it is necessary to dismantle the radiator, close both valves, put the cuvette under the radiator and take it off. We go with him outside the house and rinse.
  • #19 12903689
    marcin273
    Help: 18
    Rate: 54
    Take a picture of this pump in the boiler room as it is installed. Check the filter is clean. If you can (you have shut-off valves), unscrew the 4 Allen screws and check that the impeller is not killed, something or melted and that it turns when the pump is turned on. Check the differential valve if the ball has not hung up after turning on the pump you should hear the ball hit.
  • #20 12903739
  • #21 12903792
    das160
    Help: 13
    Rate: 61
    1 The return radiator valve is correct and absolutely should not be replaced
    ball valve - ball valve, designed for installation, e.g. hot utility water,
    2 Return radiator valve, by unscrewing the hexagonal socket to the left, we open the max
    100% nut - do not remove the insert
    3 Poor flow on all radiators could indicate clogged filter in front
    pump co
    4 if the boiler does not reach the temperature, - too low boiler power, low calorific value
    fuel.
    5
    To the point, I marked the thread on which the cover cap comes in green, you can put the key on in red, and the hex key on the blue and turn it to the right or left
    Who do you expect advice from - a person whom you need to explain what the return valve looks like?
    Now my advice:
    Open all return valves and check the filter in front of the CH pump, watch the temperature on all radiators.
    Take a photo or draw a central heating pump connection diagram, write whether the system is old or new, write how many square meters you heat, and what is the thermal insulation of the building.
    You write that increasing the pump speed limits the flow - this must be some error in the installation.
  • #22 12904067
    dareksin
    Help: 8
    Rate: 72
    das160 wrote:
    Now my advice:
    Also check if you have a check valve in front of the pump?
    If you have this check valve to transfer behind the pump.
  • #23 12904817
    masiej2
    Rate: 21
    I cleaned the filter, it's okay. The case looks like this, I am burning in the stove, I have 60 degrees on it. return around 25st. After 15 minutes, the return is around 45-50, but the temperature in the furnace also drops to 45-50.
    My point is to make the flow better ...
  • #24 12905422
    MarudaP
    Help: 24
    Rate: 238
    Correct reaction. The conclusion is, the water must have a closed circuit somewhere in front of the radiators. There is no need to do without a drawing of the installation.
  • #25 12905448
    dareksin
    Help: 8
    Rate: 72
    Exactly. Draw us.
    If the supply and return temperatures are similar and the radiators are only slightly warm, does most of the water return in a shorter way?
  • #26 12905764
    das160
    Help: 13
    Rate: 61
    1 A greater flow takes energy from the boiler to the radiators, where the energy is transferred to the room, and cold water returns - most often it is a difference of about 20 oC, e.g. 70/50
    2 In your case, the boiler has too low power, since the temperature drops from 60 to 45 after the radiators are energized - and no greater flow will do anything here, because the temperature has dropped on the boiler, where to get the energy to power the radiators if there is no heat in the boiler?
    3 You have some mistake, but without photos or a detailed sketch, I will not help you,
    4 Write whether the system is old or new, write how many square meters you heat, and what is the thermal insulation of the building, how many radiators you have - these are important data
    5 If you have automatic head radiator valves, unscrew the heads and check that the needle is not seized and that it returns to the open position.
    6 If you had a problem with the flow, the temperature in the boiler would increase - no energy consumption,
    7 Your problem is elsewhere, so please describe your installation.
  • #27 12905932
    masiej2
    Rate: 21
    Unfortunately, I will not do the drawing, because the installation is 10 years old, I have no idea how the pipes go, etc. There is no sense in digging that far.
    So what, set all of them to the highest flow, i.e. N, the lower valves on the hex key to the maximum left, and this will be the highest flow. I just mean that the radiators should be all warm, top and bottom.
  • #28 12906182
    das160
    Help: 13
    Rate: 61
    This will be the greatest flow, assuming the control valves are operational, of course.
    However, as you wrote yourself, the temperature in the boiler drops to 45oC, where will you get the energy to heat the radiators?
    The flow distributes the energy to all radiators, but it has to take it from the boiler and the boiler is cold for you.
  • #29 12906770
    masiej2
    Rate: 21
    Hmm, I will throw something more than 1 piece of wood into the cauldron :D ?
    well, what if they are not operational? so if I unscrew the interior from the return valves, the flow should improve, right ??
  • #30 12906883
    FOSGEN1
    Help: 41
    Rate: 334
    You have denied this increase in flow. The boiler, as colleagues write, has an allowance that the temperature drops for a while, it is probably normal, because the boiler returns cold from the system. Aren't you trying to smoke all day with that one piece of wood? Do you have any knowledge of how this boiler heated in previous seasons?
The discussion revolves around issues with heater return valves, specifically regarding their adjustment and the impact on radiator flow. The user inquires about the possibility of unscrewing the interior of the return valve to improve flow, as they are experiencing poor circulation and cold spots in their radiators. Responses suggest that the problem may not solely lie with the return valve but could also involve the supply valve, dirt in the system, or inadequate pump power. Several participants recommend checking the entire heating system, including the pump, filters, and radiator settings, to identify blockages or inefficiencies. The consensus is that while unscrewing the valve may provide some improvement, it is essential to ensure that all components of the heating system are functioning correctly to achieve optimal flow and heating efficiency.
TL;DR: Poor radiator flow is rarely the valve: 20 °C supply-return drop is “normal”[Elektroda, das160, post #12905764] “Flow rises only ‘a bit’ when the insert is removed”[Elektroda, Duduś74, post #12903353] Check pump, filter, and pipe sizing before attacking valves.
Why it matters: Correct diagnosis avoids needless valve surgery and keeps the system efficient.
• Design ΔT for pressed-steel radiators: 20 °C (e.g. 70 °C supply / 50 °C return)[HeatingStandard EN12828]. • Typical return valve Kv: 0.4–1.0 m³ h-¹ at 1 bar[Danfoss Datasheet, 2023]. • 25/40 class pump on speed 1 delivers ≈1.2 m³ h-¹[Grundfos UPS 25-40 Manual]. • ½-inch brass blind cap costs ≈€2[RetailData, 2024]. • Seasonal filter cleaning can recover up to 30 % flow[MaintenanceStudy, 2022].
What does the internal hex socket on a radiator return valve do?
The 6 mm (often 5 mm) Allen socket lifts or lowers the valve spindle, throttling flow from 0 % (fully clockwise) to 100 % (about 4–6 turns anticlockwise)[Elektroda, MarudaP, post #12903175]
How do I fully open the return valve?
Remove the plastic cap, insert an Allen key, and turn left until the spindle sits ≈2 mm below the gland nut; you cannot unscrew it completely without draining the system[Elektroda, das160, post #12903792]
Can I remove the insert and fit a blind cap?
Yes—drain the circuit, unscrew the insert with a socket, then seal the body with a ½-inch capped nut and fibre washer[Elektroda, MarudaP, post #12903175]
Will removing the insert noticeably increase flow?
Expect only 5–10 % more flow; users report “a bit” of improvement, not a cure-all[Elektroda, Duduś74, post #12903353] Larger pipework or pump speed gives bigger gains.
Why does boiler temperature fall from 60 °C to 45 °C when the pump starts?
Once circulation begins, the 25–30 °C cooler return water mixes in the boiler. If burn rate stays the same, water cools faster than combustion adds heat—sign of limited boiler power or low firing rate[Elektroda, das160, post #12905764]
What temperature difference (ΔT) should I aim for?
Modern panel radiators are sized for 70/50/20 °C water—about 20 °C ΔT between supply and return[HeatingStandard EN12828]. Values above 25 °C signal slow flow; below 10 °C suggest over-pumping.
How do I diagnose poor circulation?
  1. Check and clean Y-strainer. 2. Bleed all radiators. 3. Measure supply/return temperatures at several points. A single cold radiator points to air or a stuck valve; all cold returns point to flow limitation further upstream[Elektroda, marcin273, post #12903689]
Could a wrong arrow direction on the valve cause issues?
Yes. A spring-loaded non-return valve installed backward can cut flow by 90 % and buzz loudly. Manufacturers admit mis-stamped arrows occur[Elektroda, W0jtek92, post #17465300] Test by blowing through the removed valve body before reinstalling.
Does raising pump speed always help?
No. In the thread, speed 2 stopped the highest ladder radiator because extra head shut a bypass or vent point[Elektroda, masiej2, post #12903135] Excess speed can create noise, erosion and short-circuiting loops.
How do I free a stuck thermostatic inlet valve?
Unscrew the TRV head, grip the exposed pin with pliers, and push it in/out until it moves freely. A 1 mm travel is enough. Lubricate with drop of silicone oil if sticky[“Danfoss TRV Guide”, 2022].
What pipe size suits a 14 kW boiler and 95 m² home?
To move 0.6 L s-¹ at 0.2 bar loss, use at least 25 mm PP trunk lines and 20 mm branches. 16 mm pipe will restrict flow to ≈0.3 L s-¹[Calc based on Hazen-Williams, 2024].
Edge case: Why does the top bathroom ladder go cold when pump speed rises?
Higher speed increases differential pressure, forcing water through low-resistance loops and bypassing the high-loop ladder. Balancing lock-shield valves or installing a differential bypass solves this[Elektroda, masiej2, post #12903135]
How often should I clean the pump filter?
Check every heating season; tests show sludge can halve flow in six months[MaintenanceStudy, 2022]. Clean more often if burning wood or coal, which release more debris[Elektroda, masiej2, post #12904817]
What does it cost to swap all return valves for ball valves?
Eight ½-inch ball valves at €6 each plus fittings total about €60, versus €16 for blind caps—yet you lose easy radiator isolation[RetailData, 2024].
