XBOX 360 to HP Pavilion G7 Laptop: HDMI Connection for Screen Replacement
Dj MaTii 86649 5
  • #1 12949001
    Dj MaTii
    Rate: 9
    Hello. I do not know if the appropriate department is there, so I would ask for your understanding. I would like to connect my console to a laptop with an HDMi cable and I wonder if it is possible. I have already made one try and nothing, I would like the laptop screen to replace the TV set :) And that's why colleagues, I am writing to you whether such a thing is even possible.
    Laptop model: HP Pavilion G7 (has an HDMi input)
  • #2 12949058
    fazinho
    Rate: 25
    No, because the hdmi connector on a laptop is a signal output, not an input.
  • #3 12950131
    klsoft
    Rate: 9
    Unfortunately, you can't do that. You can get the console image on a laptop with a video grabber (eg AverMedia DarkCrystal USB) - but it will be playable because there will be too much latency.
  • #4 12950393
  • #5 12950433
    klsoft
    Rate: 9
    anmedia wrote:
    This grabber has no HDMI input, only a component.
    Yes. But the Xbox has a component output.
    Can use eg AverMedia Live Gamer.
    Unfortunately, this is still not a solution for gaming, but for dumping videos from the game :P
  • #6 12951377
    Dj MaTii
    Rate: 9
    Ok thanks gentlemen for the answers :) that is, a cheaper TV set will be added to the set :)
