Upgrading HP Laptop Matrix: 8560p, 6470b, 8470p, 8460p - Compatibility & Swap 1366x768 to 1920x1080
4776 4
  • #1 16434877
  • Suggesting a laptop-forum transfer for display upgrade expertise
    #2 16439383
    iron64
    Help: 648
    Rate: 313
    I did not carry out such a change in these laptops and in a little older and 4 out of 5 cases were successful. However, you may have asked the question in the wrong department. Ask the moderator to transfer to laptops, there are several colleagues who have such matters at their fingertips and for sure someone did it. Often real masters of a given field only read their department and if the question does not go where it should not get the answer.
  • #3 16439396
  • Display swaps depend on motherboard and LVDS configuration
    #4 16439523
    lisek
    Service technician RTV
    Help: 6355
    Rate: 6886
    There are several varieties of HP laptops on the market, these are the models:
    - 8560p
    - 6470b
    - 8470p
    - 8460p
    have different matrices and Various Motherboards (Motherboard MoBo) , depending on its solution:
    - (additional graphics or not),
    - how many channels of the LVDS / * connector a better solution is the eDP on the disc is used
    ... producers get up better chap. matrices, above 1366x786
    It has been written several times in this forum about the problems of swapping matrixes and ribbon.
  • #5 16465272
