HP dv1080 Laptop and GF 9600 GT: Connecting Digital Decoder via HDMI, Graphic Drivers Query
kwas6110 106239 10
Can I connect a digital decoder to my HP dv1080 laptop via HDMI, and do I need special graphics drivers or playback software for it to be detected?
No — the HDMI socket in a laptop is only an output, so a decoder will not be detected there, and no graphics driver or playback software will change that [#9955341][#9955414] If you want the decoder’s signal on the laptop, you need a TV card or capture device with a video input such as S-video and an audio input [#9955423] If the decoder has SCART output, a video grabber is suggested as the cheapest solution [#9955372] The laptop’s HDMI can be used to send video to a TV or monitor, not to receive video from the decoder [#9955414]
  • #1 9955187
    kwas6110
    Rate: 8
    Hello, I have an Hp dv1080 laptop with a gf 9600 gt and I would like to connect a digital decoder to it. Do I need to download any playback software?
    I changed the system and maybe I do not have all the graphics drivers because when I connect the decoder, the laptop does not show that it detects the new device.
    Advice if you have any ideas
  • #2 9955282
    sebol*
    Help: 5
    Rate: 28
    And you want to watch movies on the display of this decoder? :D
  • #3 9955297
    michcior
    Level 30  
    Help: 159
    Rate: 462
    I think you combine the exit with the exit.
  • #4 9955341
    matzg
    Help: 308
    Rate: 358
    Nonsense.
    The HDMI socket on a laptop is only used to output a signal to eg a TV
  • #5 9955357
    michcior
    Level 30  
    Help: 159
    Rate: 462
    matzg wrote:
    Nonsense.
    What did I write? Output with output. Is it not?
  • #6 9955372
    matzg
    Help: 308
    Rate: 358
    We connect the exit with the entrance.
    Going out and out ... pointless.
    Returning to the topic, as the decoder has scart output, it should be used Grabber
    More Link
  • #7 9955388
    michcior
    Level 30  
    Help: 159
    Rate: 462
    More Link
    What is a digital set-top box in this case, Cyfra +, Polsat? It only has a way out. Well, our colleague linked the exit with the exit. I know that it makes no sense, quite obviously, from my post.
  • #8 9955405
    kwas6110
    Rate: 8
    So if there is only an Output in the HDMI tab, then I must have a TV card to connect the decoder?
    This HdMI socket will not be of any use to me in this case?
    Thanks for the quick reply
  • #9 9955414
    sebol*
    Help: 5
    Rate: 28
    You can connect a TV or monitor to this socket, just like to this decoder ...
  • #10 9955423
    matzg
    Help: 308
    Rate: 358
    This question has already been answered
    The laptop (TV card) must have an input for a Video signal (S-video) as well as an input for an Audio signal.
    Video Grabber is the cheapest solution
  • #11 9956816
    kwas6110
    Rate: 8
    Thanks for the answer.
The discussion revolves around connecting a digital decoder to an HP dv1080 laptop equipped with a GF 9600 GT graphics card via HDMI. Users clarify that the HDMI port on the laptop is an output-only interface, meaning it cannot receive signals from the decoder. To connect the decoder, a TV card with video and audio input capabilities is necessary, or alternatively, a video grabber can be used as a cost-effective solution. The original poster seeks advice on whether playback software is needed, but the main focus is on the hardware compatibility and connection methods.
