Hello, I have this question. I would like to install a webasto parking heater in my car. I was thinking about wet webasto, because from what I heard it consumes similar amounts of fuel and there is no need to install air supply pipes, and I have a small car (Corsa B 1.5 TD). This is where my question arises: can I use webasto for a few hours or overnight? Will it drain my battery? What battery would be needed to pull this for example for 8 hours (how many Ah). I thought about moving the battery to the trunk, because you know, it's always warmer, that is, it lasts longer ... And can the webasto be regulated, for example, so that the temperature in the car is 18 degrees? How much oil will such a webasto consume? What model do you recommend?
zbyszek_k007
zbyszek_k007
Rate: 24
