Miwi 1132 Intercom Wire Connection Guide: 6-Wire Installation with Photos Attached
kilapress 44676 16
How do I connect a Miwi 1132 intercom with 6 wires when the wire colors are unclear?
Connect it by identifying the terminals first: from the left they are handset (1), bell/CA, microphone (2), ground/mass (6), and lock/opening (10-9) [#13008159] If six wires come to the apartment, this is likely not a digital two-wire system but an analog multi-wire installation [#13008159] Do not trust wire colors, because they may not follow any standard [#13014824] The practical way is to find the mass wire first: leave terminal 6 aside, then one by one touch the other wires to terminal 1 while holding the handset to your ear until you hear a hum from the entrance panel [#13014824] For the door release, keep the handset up and touch the remaining wires to terminal 6 until the lock buzzes; if it does not work, swap the blue and black wires and test again [#13030107]
  • #1 13007443
    kilapress
    Rate: 11
    Hello everyone, I need to connect an intercom. I attach 2 photos - the number of wires 6. I need info on how to connect it because something is not going to me. Thanks in advance Miwi 1132 Intercom Wire Connection Guide: 6-Wire Installation with Photos Attached Miwi 1132 Intercom Wire Connection Guide: 6-Wire Installation with Photos Attached
  • #2 13008159
    sikorkam
    Help: 32
    Rate: 90
    Hello. The manufacturer's website, miwi(_at_)miwiurmet.com.pl, will explain a bit, but not completely. Looking at the tile from the left, we have mom
    1-handset
    CA-bell
    2-microphone
    6th mass
    10-9-lock / opening /
    If so many cables come to your home, it is not a digital two-wire installation, but probably a 5-wire one. If you have not dealt with it yet, let me know and I will describe how to proceed.
  • #3 13014705
    kilapress
    Rate: 11
    unfortunately, there is still something wrong. If you can do it, write me specifically, e.g.
    1.red cable - 1
    2.blue cable - 3
    e.t.c.
    thanks in advance
  • Finding ground by sequential wire testing and handset hum
    #4 13014824
    sikorkam
    Help: 32
    Rate: 90
    And I thought you did it. The correct connection is the search and yes. It should be assumed that the colors of the cables do not comply with the adopted rule. The first most important step is to find the mass. In your case, you must
    - tighten all screws except 6.
    -up to 6 consecutively screw the cables, start with blue, black and hold the handset to your ear
    and touch -1- with more cables. At some point you will hear a hum, that's all that is happening in front of the cassette in front of the door.
    Is it clear, I will write further if you find it.
  • #5 13025533
    kilapress
    Rate: 11
    black - 6 + blue - 1 = noise :)
  • #6 13030107
    sikorkam
    Help: 32
    Rate: 90
    Oh, that's some progress. Well, the earpiece and touch up to 6 other wires and you should hear the lock buzzing. If not, swap the blue and black wires and touch the other 6 wires again and you will hear the lock buzzing.
  • #7 17687512
    jackwien
    Hello, please, momoc, I want to replace the current intercom with Miwi 1132, how to connect, please, help, I enclose the old one in the attachment Miwi 1132 Intercom Wire Connection Guide: 6-Wire Installation with Photos Attached
    • Miwi 1132 Intercom Wire Connection Guide: 6-Wire Installation with Photos Attached FDE29CE8-CC86-4E5D-8C0D-F0F56FCD28D5.jpeg (791.36 KB) You must be logged in to download this attachment.
  • #8 17688249
    Ircys
    Intercoms specialist
    Help: 1342
    Rate: 2085
    If you are talking about the Urmet 1132 uniphone, it does not fit here. Fits e.g. 1132/520.
    Regards
  • #9 17689716
    jackwien
    I don't understand too much please more clearly if I can ..... Miwi 1132 Intercom Wire Connection Guide: 6-Wire Installation with Photos Attached
    • Miwi 1132 Intercom Wire Connection Guide: 6-Wire Installation with Photos Attached ED4C0EA8-D640-4A46-A276-82FFDF4D42BF.jpeg (946.72 KB) You must be logged in to download this attachment.
  • #10 17689723
    jackwien
    So the black one I bought does not fit, it cannot be mounted .....
    Added after 41 [seconds]:
    • Miwi 1132 Intercom Wire Connection Guide: 6-Wire Installation with Photos Attached D360A5F9-19D5-45BC-9AB4-C56A4FFFFDA6.jpeg (1.99 MB) You must be logged in to download this attachment.
  • #11 17689732
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    Your old Proel PC255 uniphone was connected to the installation with two cables (U- blue, U + white). In addition, it was a digital uniphone, where (as you can see in the photo) you had jumpers in the upper part to program the apartment number. In your case, it's number 52.
    The currently shown uniphone is an analog uniphone for multi-core systems and it is completely unsuitable. This is not the "fairy tale".
  • #12 17690009
    jackwien
    Thank you now, I understand, thank you for the answer. Regards
  • #13 18252250
    przemm87
    I have a Question, I have Miwi 1132, analog version, I would like to use something like this in my installation:
    https://www.aliexpress.com/item/33015922621.html?spm=a2g0s.8937460.0.0.331f2e0eRCqq2E
    I'm just not sure how to connect it, whether I should plug it into the installation somewhere, or connect to the door opening button. Do you have any experience with similar connections? Miwi 1132 Intercom Wire Connection Guide: 6-Wire Installation with Photos Attached
  • #14 18252493
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    Relay contacts (COM and NO outputs) should be connected to terminals 6 and 9 of the uniphone.
    Of course, the module must be powered from a separate power supply.
  • #15 18935624
    mazo13
    Hi, I'm new here. I found this topic, but I am also lost in connecting the intercom. Could I please help with the setup?
    The first two photos are the old connected (and working) intercom, the next photo is MIWI CS1132-001G Uniphone. Between 1 and 10 there is a connecting cable with a capacitor ... The system has a 5-wire analog as shown in the first photo.
    I will be grateful for your help :)
    Miwi 1132 Intercom Wire Connection Guide: 6-Wire Installation with Photos Attached Miwi 1132 Intercom Wire Connection Guide: 6-Wire Installation with Photos Attached Miwi 1132 Intercom Wire Connection Guide: 6-Wire Installation with Photos Attached
  • #16 18935674
    Ircys
    Help: 1342
    Rate: 2085
    We translate the wires from the old to the new.
    old -> new
    1 -> 6
    2 -> 2
    4 -> CA
    5 -> 9
    6 -> 1
    we throw out the capacitor with the cable from the old one
    Regards
  • Miwi 1132 to ELFON A-U1 wiring map
    #17 19776720
    sayeksayek
    Hi
    I found the information in the posts above useful. So I am uploading photos of what it looked like for me.
    I had an old analog earphone, 6 MIWI wires.
    I exchanged it for ELFON A-U1 (cost about PLN 45)
    Dokładnie z tej aukcji https://allegro.pl/oferta/unifon-analogowy-do...mNjFlYzVjZTNlN2FhOGVjNWViNmFiNjQ1YTBkM2Y1MDA=
    I give photos of connecting the old and new headphones, maybe it will be useful to someone.
    Contact number (old-new handset):
    2-> MU
    1-> SU
    6-> T.
    CA-> Journal
    9-> 1
    10-> 2
The discussion revolves around connecting a Miwi 1132 intercom with a 6-wire installation. Users seek guidance on proper wire connections, with various responses detailing the identification of wires and their respective functions. Key steps include finding the mass wire, connecting specific colored wires to terminals, and troubleshooting by swapping wires if necessary. Additional inquiries about compatibility with other intercom models and specific wiring configurations are addressed, emphasizing the importance of understanding the differences between analog and digital systems. Users share experiences and solutions, including connections for other models like ELFON A-U1 and Proel PC255.
