Clutch Function & Role in Drills: Basic Overview, Purpose, and Location Explained
...Paweł... 23514 3
  • #1 13109277
    ...Paweł...
    Hello, I would like to know about the clutch in the drill, what it is for, what function it is for, where it is located and basic information about it.
  • #2 13109301
    Błażej
    Help: 1923
    Rate: 3620
    It is most likely an element breaking the connection between the motor / gear and the drill spindle when it becomes blocked or overloaded. You have adjustable clutches in each cordless screwdriver, in which you regulate the force at which the clutch will break and jump.
  • #3 13109665
    robokop
    Help: 1762
    Rate: 6357
    Alternatively, in better, stronger hand drills, it prevents breaking hands when the tool is jammed in the hole.
  • #4 13115658
    dreslak
    Help: 5
    Rate: 34
    I would like to add that if, for example, a hammer drill or an ordinary cordless screwdriver "grinds" and the spindle stops, it means that this clutch worked. A useful thing for both screwdrivers and impact hammers.
